sudo smartctl -a /dev/sdb
smartctl 7.0 2018-12-30 r4883 [x86_64-linux-5.2.21-1-MANJARO] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke,
smartmontools
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Raptor
Device Model: WDC WD740ADFD-00NLR1
Serial Number: WD-WMANS1515479
Firmware Version: 20.07P20
User Capacity: 74.355.769.344 bytes [74,3 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA/ATAPI-7 published, ANSI INCITS 397-2005
Local Time is: Fri Nov 8 10:33:20 2019 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 2391) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 39) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0007 167 166 021 Pre-fail Always - 2683
4 Start_Stop_Count 0x0032 100 100 040 Old_age Always - 80
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x000a 100 253 051 Old_age Always - 0
9 Power_On_Hours 0x0032 001 001 000 Old_age Always - 73231
10 Spin_Retry_Count 0x0012 100 253 051 Old_age Always - 0
11 Calibration_Retry_Count 0x0012 100 253 051 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 80
194 Temperature_Celsius 0x0022 118 096 000 Old_age Always - 25
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0012 200 200 000 Old_age Always - 0
199 UDMA_CRC_Error_Count 0x000a 200 253 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 051 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
