[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Auch das Netzteil schließe ich als Ursache noch nicht aus. Ist zwar ein gutes, aber wer weiß ob die Lastspitzen nicht irgendwas killen.
Echt nervig sowas. Hatte schon ewig kein PC Problem mehr, wo die Ursache so unklar war.
Dann versuch doch mal die 4090 auf 350 Watt zu limitieren bzw. zu undervolten. Damit sollte man ja dann sehen ob das Netzteil etwas damit zu tun hat.
ich habe das selten mal beim Booten, dass mein oller Samsung C32HG70 schwarz bleibt beim Windows Login Bildschirm. Da hilft dann nur Monitor ausschalten, oder zweiten Monitor anschalten. Dann ist er sofort wieder da.
Mich stört das jetzt nicht sonderlich, weil das nur mein Zweitmonitor ist, der halt für statische Inhalte und deshalb auch fürs Homeoffice herhalten muss. Allerdings muss ich sagen im laufenden Betrieb hat er das noch nie gemacht. Vielleicht trotzdem wirklich irgendwas Samsung typisches.
Ich hatte bei meinem zwei letzten Samsungs eher das Problem das alle paar Monate mal der Bildschirm gar nicht erst an gehen wollte, auch auf die Knöpfe am Monitor wollte er nicht reagieren. Musste ihn dann kurz vom Strom trennen. Könnte also wirklich ein Samsung Ding sein. Da es aber so selten vor kommt, kein Problem. Und meine 4090 läuft auch einwandfrei mit meinem aktuellen Samsung zusammen. Solche Sync Aussetzer hatte ich nur mal mit meiner PS4 vor Jahren, da wars aber das HDMI Kabel.
Ich hab bei mir eine 2 TB für Windows und eine 4 TB für Games eingebaut, also jeweils SN850X.
Windows bootet noch deutlich schneller als mit einer 970 Evo Plus und selbst der Edge Browser öffnet sich schneller als man blinzeln kann.
Mehr Frames habe ich auch
:o
nicht!!
____________________
Echt der Wahnsinn, dass alles noch schneller geht.
4 TB für Games ist nice, da ich gerne Games auch mal modde.
Da bin ich mal gespannt, ob ich da auch etwas feststellen werde. Ich mach im Prinzip genau das gleiche. 1 TB 970 Evo Plus durch 2 TB 990 Pro ersetzen und 1x 4 TB SN850x für Games und 1x für extern.
Laut diversen Tests gibts zwischen PCIe 3.0 und PCIe 4.0 nahezu kaum Unterschied, zu SATA hingegen schon.
Sorry, für nochmal OT... :d
Hatte vor einem 3/4 Jahr meine 970 EVO Plus gegen div. Laufwerke antreten lassen. Aus Zeitgründen hatte ich nur RDR2 genommen...
Wer RDR2 hat, kann ja mal nachbenchen (mit Stoppuhr)...
Ab drücken von "Spielen" bis zm Erscheinen dieses Screen´s...
...dauert es beim ersten Start (nach Neustart des PCs) ca. 41,5sek. und bei jeder Wiederholung 39,5sek. (immer gleich bis auf +/-0,1sek)
Maßgebend ist der erste Bench nach dem Neustart des PCs, weil da noch nichts gecached wurde.
Und wenn ich es richtig in Erinnerung hab, dauert es ab drücken von "Story" weitere 35 oder 39sek ? (bin grad nicht sicher, was von Beiden)
Also insgesamt bis zu ca. 80sek. bis ich spielen konnte
Hab nochmal RDR2 durchgebencht...
Mit 970 EVO PLUS = 80sek. (41,5 + 38,5sek.)
Mit WD80EMAZ = 107sek. (44 + 63sek.)
Mit HD204UI = 154sek. (54 + 100sek.)
In Klammern...
Ab drücken von "Spielen" bis zum ersten Screen + ab drücken von "Story" bis man zocken kann
Jedes Laufwerk wurde 3x gebencht,
Ich war auch neugierig, was die 840 EVO (SATA) im Vergleich zur 970 EVO PLUS (NVMe) leistet
Es sind insgesamt 83sek. bzw. 44 + 39sek. (siehe oben)
Auch hier (wie alle Laufwerke oben) war das Laufwerk mit Bitlocker verschlüsselt
Eig. müsste ich das alles nochmal ganz ohne Bitlocker benchen. Ist aber zuviel Aufwand + Zeit
Die 970 EVO Plus ist also gerade mal 3 Sekunden schneller, als die 840 EVO. Bei einem Zeitfenster von 80 Sekunden also NICHT spürbar schneller
Vielleicht ist das bei anderen Games anders. Würde mich interessieren, was ihr da (unverschlüsstelt) mit Stoppuhr herausbekommt
Sachen gibts...
Hm, ja, why not? Nur hat die Grafikkarte dann auch einen Vorteil was Datenzugriff angeht?
P.S. das ganze SSD Gerede hier hat mich gerade erinnert, dass ich mein System hier noch updaten musste (256GB gegen 4TB getauscht). Witzig, jetzt habe ich 2TB + 4TB jeweils als SSD und HDD. XD
So dann noch einmal ein abschließender Bericht zu den kurzen Blackscreens:
Es muss irgendwas mit GSync zu tun haben. Entweder im Zusammenhang mit dem Monitor und/oder dem Treiber.
Ich habe einen älteren Treiber getestet, mit dem im Winter noch alles ok war, allerdings bekam ich damit auch Black Screens. Dann wieder den neuen drauf und GSync im Treiber ausgestellt, "Adaptive Sync" am Monitor an. Damit gibt es keine Blackscreens, egal ob vsync an ist oder aus.
Da ich den Monitor aber nun schon gut über ein Jahr habe und diese Probleme erst seit kurzem auftreten, kann es nicht nur am Monitor liegen.
Egal. So lasse ich es erstmal. Ich denke "Adaptive Sync" ist dann Freesync von AMD? Funktioniert jedenfalls dem Anschein nach.
Ne Adaptive Sync ist halt die allgemeine Einstellung um die Bildwiederholfrequenz an die GPU anzupassen.
Seit dem neusten Treiber habe ich auch keine Black Screens mehr auf dem Desktop.
Aber ist ja super das es bei dir jetzt auch so funktioniert. Wobei ärgern würde mich das schon weil wenn ich nen Gsync Monitor habe will ich das natürlich auch nutzen.
Ok aber dann funktioniert jetzt irgend eine dieser Techniken ohne das Gsync läuft? Womit macht der Monitor das denn?
Irgendwo hier im Forum habe ich aber auch mal gelesen, dass "gsync compatible" auch generell Probleme macht. Ist halt kein Modul drin. Vielleicht hatte ich also bisher nur Glück.
Hätte ich mal Windows nicht neu aufgesetzt. :fresse:
Freesync geht ohne Controller...
Für G-Sync braucht es nen Controller, wie zb den hier für Ultimate G-Sync...
img_951212ktk-jpg.516348
img_9517mzkir-jpg.516349
GSync im Treiber aus, heißt eigentlich kein Sync, egal was am Bildschirm eingestellt ist.
Ich weiß aber welche Technik läuft dann? Oder anders gefragt, von wem ist Adaptive sync?
Es läuft gar kein Sync der Monitor läuft einfach mit der eingestellten Frequenz... Adaptive Sync, Freesync, VRR, GSync (Compatible) sind am Ende unterschiedliche Begriffe für die selbst grundlegende Technik.
Stellst du Adaptive Sync am Monitor an, und Gsync (Compatible) im Treiber an, hast du GSync (Compatible) und damit variable Bildwiederholraten je nach FPS (VRR). Die Einstellung Adaptive Sync am Monitor alleine macht nichts (außer der GPU/dem Treiber zu sagen, dass der Monitor es unterstützt).
Also ich verstehe, was das ist, nur halt ob es reicht, dass man es im Monitor aktiviert oder eben auch im Treiber etwas passieren muss war die Frage. Ich dachte dass man auch auf NVidia Karten adaptive sync ohne gsync zum laufen bringen kann. Gibt ja auch Monitore, die das nicht haben. Aber wenn das dann alles unter gsync "compatible" läuft dann ist das eben so.
Ich seh zwar kein Tearing aktuell obwohl gsync im Treiber nicht aktiviert ist, aber das muss dann wohl ein placobo Effekt sein.
Mal was anderes, hat man am Anfang immer versucht die 7900xtx mit der 4900 gleichzustellen, so zeigen aktuelle Tests(Gaming) dann doch klar wie überlegen die 4090 doch ist.
Fazit nach paar Monaten, einfach ein geiles Stück Hardware, wenn auch zu einem unvernünftigen Preis.
Wurde das hier schon gepostet?
Es war ja ein langes hin und her, aber das ist ein fairer und richtiger move.
*edit*
Long Story short: Es gibt für early adopter die die erste Version vom 90° Adapter gekauft haben Shop Credits von Cablemod und man kann sich davon die aktualisierte 90° Adapter Version kaufen oder das 90° Kabel kaufen.
Hab oben das wichtiges reingeschrieben, aber wenn es dich interessiert, warum nicht den Artikel lesen?
Es soll auch ein "Cabelmod Pro" 90° Kabel kommen
  • CableMod Pro 12VHPWR 90 Degree cable (coming in 4-6 weeks)
Weiß jemand was da der Unterschied ist? Einfach nur, dass es da unterschiedliche Farben gibt?
Versand muss man wohl leider selber bezahlen, man bekommt nur die Credits für den Adapter.
However, some users have expressed that they would feel more "safe" if they instead used a direct replacement cable (ideally a 90 degree one) for their systems due to the fact that there are fewer resistance points connection wise. We also realize that everyone that supported us by purchasing a V1 adapter are probably wondering how they could get a V1.1 version and if there would be any sort of discount extended to early adopters.
To that end, we are introducing the following Early Adopter program to all of our angled adapter customers. Customers who purchased an angled adapter from us will receive a $39.90/39.90€ store credit on our Global / EU / US Stores, which can be used towards the following products:
  • CableMod Basics 12VHPWR 90 Degree cable (available now)
  • CableMod 12VHPWR Angled Adapter V1.1 (coming in 6-8 weeks)
This credit will be applied to the emails that purchased an adapter from our stores. For those who purchased an adapter via other stores like Amazon, feel free to reach out to our support team. Users who are feeling stressed about their V1 adapter can use their credit to order a CableMod Basics 90 Degree cable immediately, wait 4-6 weeks for our upcoming CableMod Pro 12VHPWR 90 Degree cable, or 6-8 weeks for the V1.1 angled adapter.
Was hat dir Cablemod angetan? 😅
Das 90 Grad Kabel kann meinetwegen noch schneller kommen. Für 20€, was ich für das normale Pro Kabel gezahlt habe, hat es wunderbare Arbeit geleistet. Leider wird es im kleinen O11 stark gebogen.
Gibt halt keine Alternativen, die so eine Vielfalt an Produkten anbieten. Abseits vom 12VHPWR Theater empfand ich Cablemod immer seriös und qualitativ hochwertig. Kenne natürlich deine Standards nicht.
Könnte man viel einfacher haben, aber jmd wollte ja am "superduper" 12VHPWR-Anschluss was verdienen
Ein simpler 2 PIN-Anschluss (ähnlich einem "XT60"), wie im Modellbau + Sense-PIN hätte es auch getan
Kein rumgeficke mit 12 PINs, von denen einer am Brennen ist :rolleyes2:
btw:
Gab´s mal Gerüchte über 24V-NTs? Damit könnte man zumindest bei Hochlast-Leitungen den Querschnitt verringern (Kupfer bzw. Alu einsparen, wie im Automobilbereich)
Ähnliche Themen
