[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Roman hat es in seinem Video eigentlich grafisch perfekt dargestellt. Das zusätzliche Powerlimit verpufft oben komplett. Am besten läuft die Karte wohl mit 70-80% Powerlimit oder UV bzw. custom Kurve.
Ist doch immer so, dass es irgendwann ineffizient wird...
Mehr PL lohnt nur zum Benchen. Da geht es ja um 1.000stel
Was ist denn genau eine Wohnadresse? Ist damit gemeint das Firmenadressen ausgeschlossen sind oder das Abholstationen und Packstationen nicht möglich sind? Und wie verhindert NBB das man sein Paket umleitet, das ist normalerweise etwas auf das der Absender keinen Einfluß hat, das läuft zwischen Empfänger und Transportunternehmen. Normalerweise ist die Rechnungsadresse entscheidend und nicht die Lieferadresse. Das ist schon sehr seltsam, bist Du sicher daß Du das richtig verstanden hast? Gibt es einen Link?
Mit Wohnadresse meinte ich einfach normale Adresse, weil man sonst ja z.B. bei Straße auch Filiale xy eintragen kann. Empfangsoptionen kann der Absender zumindest bei DHL und UPS ausschließen. Bei Hermes wahrscheinlich auch. Hier der Link: https://service.notebooksbilliger.de/help/de-de/10-versandoptionen/51-welche-versandoptionen-gibt-es
Weil ich tagsüber arbeite und das Paket nicht annehmen kann. Unterschreiben muss man ja wahrscheinlich auch persönlich.
Wäre mir neu, das ist nur bei einer "eigenhändigen" Sendung notwendig und das ist ein spezieller Versandmodus den man normalerweise extra bezahlt und bei Paketen eigentlich nie benutzt, es sei denn es geht um Artikel welche dem Jugendschutz unterliegen. Ansonsten muss einfach nur der unterschreiben der es an der angegebenen Adresse entgegen nimmt. Anders ist das nur wenn diese Adresse nochmal von der angegebene Lieferadresse abweicht, weil man z.B. in einen Paketshop ungeleitet hat (oder das Transportunternehmen das von sich aus gemacht hat weil man (angeblich) nicht zuhause war). Dann muss man bei der Abholung selbst unterschreiben und im Falle eines Vertreters der es für Dich abholt auch noch einen Kontrollcode manchmal haben. Solange aber an der Adresse an die zu senden Du den Händler beauftragt hast jemand ist, der eine Unterschrift leisten kann, ist das normalerweise völlig ausreichend. Und wenn man eine Abstellgenehmigung erteilt hat, dann ist nicht mal das notwendig. Es wäre mir absolut neu, daß der Absender darauf irgendeinen Einfluss nehmen kann ohne speziellen Auftrag des Empfängers. Aber das ist nur meine Erfahrung, garantieren kann ich das natürlich nicht.
Ahso. Ja, wenn ein Anbieter z.B. kein DHL Versand anbietet (wie NBB für Deutschland zumindest), dann kann man natürlich keine Packstation, Postfillialen oder ähnliches angeben, das gleiche wird bei anderen Anbietern auch gelten. Ein Händler der sich offen hält mit wem er versendet, der akzeptiert natürlich nur "normale" Adressen die jeder Lieferdienst akzeptiert (außer Amazon, die kann man z.B. durch die Angabe einer Packstation zur Nutzung von DHL zwingen).
Normale Firmenadressen an denen irgendjemand sitzt, der die Pakete entgegennimmt gehen da normalerweise immer, der Paketbote bekommt da seine Unterschrift und hat damit seiner Pflicht genüge getan, mehr interessiert die eigentlich nicht. Ich habe schon unzählige Lieferungen in die Firma veranlasst in der Vergangenheit, weil mein Arbeitgeber eine eigene Shipping Abteilung hat, die als Mitarbeiterservice die Entgegenname von Paketen anbietet. Das gibt nur Probleme bei Jugendschutzartikeln, weil da wirklich der vorgesehene Empfänger unterschreiben muss, deswegen habe ich das immer vermieden, ansonsten ging da alles ohne meine persönliche Anwesenheit durch, egal bei welchem Paketwert.
Beim den 3080er und 3090er Karten war das viel dramatischer. Mit nur 2x8pin Stromversorgung sind die ja schon gnadenlos ins Powerlimit gelaufen und haben gedrosselt. Das ist hier ja fast das Gegenteil und überhaupt kein großes Thema mehr. Eher wie geil die 4090 mit z.B. nur 350 Watt läuft.
Kollege schrieb mir eben das er morgen um 10:00 seine Strix bei Caseking abholen kann. Bin gespannt.
Wenn der Ladenverkauf vor 15Uhr startet, dann wäre das echt krass
Hmm über die FE sprechen CB und Roman von eiernden Lüftern und nervigen Nebengeräuschen.
Hat Roman in seinem Video gut dargestellt. 🤨
Ja das Problem mit den Lüftern der FE wurde auch von anderen Videos/Berichten bestätigt.
Das scheint wohl „normal“ zu sein,
sicherlich ein Grund eher auf eine Custom Karte zu setzen.
Da ich auf Wakü umbaue ist mir das aber egal.
In welchem Shop werden die Karten reserviert, die man im Warenkorb hat?
achso, dann für ein paar Minuten geblockt..,meinst DU?
ja also nur um dem Kauf ab zu schließen ...
Sieht aber echt schlimm aus wie der Lüfter da herum eiert. Also ich hätte da auf Dauer kein gutes Gefühl.🤔
Das sah in dem einen Video alles andere, als "normal" aus :rolleyes2:
(finde das Unboxing-Video gerade nicht)
Ich glaub die Wird am Ende des Tages die Karte sein die noch verfügbar sein wird!
Das hoffe ich, denn mir gefällt sie. Und wenn es sie für weniger Geld gibt als was Caseking sich ausgedacht hat, dann wird die Amp meine. Ich find die deutlich besser als in den letzten Generationen.
Verstehe es ja mit den man sollte im Optimalfall nur einmal bestellen, allerdings bin ich damals mit der EVGA 3080 XC3 Black Gaming (oder so ähnlich) und Alternate bei den Geschichten ala es werden Express Lieferungen und Abholungen vor normalen Bestellungen bearbeitet so unters Messer gelaufen. Da habe ich ÜBER 1 JAHR! auf die Karte gewartet. Wenn Alternate sich nicht "erbarmt" hätte mir ne FTW3 LHR 3080 statt der 3080 Black Gaming (die wohl kaum bis gar nicht produziert wird/wurde) anzubieten, würde ich noch heute warten.
Ich hatte sogar auch noch bei Amazon die Trinity bestellt, dir dann aber anscheinend für alle storniert wurde. Und auch als ich paar Monate später ne FE bei NBB bestellen konnte, wurde dies von NBB wieder storniert.
In der Zwischenzeit ist es bei mir dann eh ne 3090 Strixx OC für 2000€ geworden, weil ich sonst bis dahin mit der Intel IGPU rumgekrebst wäre. (2080 Ti in meiner unendlichen Weisheit kurz vor Verkaufsstart für 600 verkauft...)
Von dem her bestelle ich selber auf jeden Fall bei mehreren Händlern und kann jeden verstehen, der dies auch macht. Ich hatte es mittlerweile einfach zu oft, dass alle möglichen Shops einem etwas "wegen unbekanntem Liefertermin" (nicht nur GPUs) stornieren, obwohl bei Bestellung auf Lager angezeigt wurde. Diesmal verkauf ich die 3090 nur nicht vorher.
Wenn sie morgen bei der FE Paypal mit 30 Tage Zahlungsziel erlauben wirds schwierig mich zurück zu halten 🤣🤣
Wahrscheinlich hast du Recht, werde dann Morgen besser auch nochmal mit machen und versuchen eine Karte zu bekommen, die auf Lager ist ....
Mh 🤔
Bin gespannt ob die FE Karten auf NBB Online gekauft werden können oder wirklich nur im Lokalen Laden?
Weiß man da irgendwas?
Die Situation war damals eine ganz andere als heute. Förderlich ist es nicht, wenn jetzt alle wieder mehrere Karten ordern.
Ähnliche Themen
