[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Lt. Beschreibung neu, von daher dürfte der neue Stecker entsprechend verbaut sein. Bei mir wird dann die Zotac entsprechend weitergereicht.
Ein kleines Einhorn, da kein Spulenfiepen, Lüfter keine Ahnung, da Granzon Wasserblock verbaut. Hoffe die Founders macht da mir keinen Strich durch die Rechnung.
Dann würde ich den Wechsel aber ganz sicher nicht machen :d von den sechs 4090 die ich hier hatte (TUF, Gainward Phantom, FE, Gigaybte Gaming OC, Suprim X, PNY) war keine frei von Fiepen/Rasseln.
Manche müssen halt erst selber auf die Fresse fallen, manch andere sogar in Dauerschleife 😏
Da hilft auch kein Rat und Tat, die heiße Herdplatte muss ums verrecken selbst berührt werden 🤣
Eben verfügbar, ganze vier Stück. :LOL:
Dann bin ich mal gespannt ob es die mit neuen Stecker sind oder Rückläufer.
Ich hätte ja auch Interesse, nochmal den Kauf einer FE zu wagen. Aber eine derart geringe Stückzahl könnte durchaus auf Rückläufer oder Restposten schließen lassen. Ehrlich gesagt hätte ich auch etwas Bauchschmerzen, ein solch teures Produkt bei einem Shop mit Sitz außerhalb Deutschlands zu kaufen. EU hin oder her. Gewährleistung, Versand, usw.
Interessant wäre ja auch, weshalb die nicht mehr über NBB vertrieben werden.
In der Lautheit gibt es aber teils eklatante Unterschiede.
Meine Tuf klang richtig schlimm beim rasseln als wen die gleich auseinander fällt.
Die Strix war da etwas besser aber immer noch viel zu laut mit der FE komm ich klar .
Hab ja nichts anderes gesagt, aber warum sollte man von einer (nach eigener Aussage) lautlosen Karte wieder in die Lotterie wechseln? Macht keinen Sinn
TUF und Suprim waren bei mir die lauten Kandidaten, die anderen klangen mehr oder weniger gleich.
Für mein DK05F-Projekt mag ich es eben gerne wagen eine FE mit Watercool Block einzusetzen.
Für alle die, die jetzt nochmal eine 4090 kaufen wollen, besonders auch unter dem Gesichtspunkt, dass die 4090ti gestrichen ist, rate ich auf die Asus 4090 Matrix zu warten.
Stellt euch nicht so an wie alte Waschweiber :) ich hab eine hörbare suprim behalten anstatt einer lautlosen gaming oc und lege mehr Wert auf die Verarbeitung und ingames 3000mhz
Ja gut meine Suprim war auch nicht stabil Ingame mit Stock Settings, und die PNY schon auf dem Desktop nicht :d Und was Verarbeitung angeht ist die FE ja ganz nett.
Kann ich sehr gut nachvollziehen. Ich habe meine hinsichtlich des Spulenfiepens wirklich sehr, sehr angenehme RTX 4090 Aorus Master unter anderem auch aus dem Grund retourniert, weil für mich die Qualitätsanmutung und Konstruktion einfach nicht mit der Preisklasse in Ordnung ging.
Ja die fe ist die beste Karte wenn es um Verarbeitung geht.
Ja bei ca 2000€ war mir das Plastik zu billig :)
Ist aber schon n seltsamer Zufall. Hatte ja auch einige 4090 hier ( :fresse: ), aber derlei Problem hatte keine. ;)
… rate ich auf die Asus 4090 Matrix zu warten.
Kommt mit ner ollen AIO daher, uninteressant!
Ein bisschen schade, dass es von den RTXen nicht so etwas wie die Liquid Devil oder Aqua gibt. Gebinnter Chip, feine Platine, knackiges BIOs und oben auf ein Wasserblock…
meinst du wegen dem plastik chassi?
Ja, das auch. Ich hatte nach den ersten Tests damals im Fiep-Thread eine Einschätzung hinterlassen:
"Insgesamt ist mir auch die billige Konstruktion der Karte negativ aufgefallen. Die große schwarze Kühlerabdeckung ist komplett aus billig anmutendem Plastik. Die Konstruktion mit 2-Slotblende wurde durch keinerlei zusätzlichen Rahmen verstärkt. Daher ist die Montage der mitgelieferten Anti-Sag-Lösung dringend empfohlen. Oder eben eine Alternativlösung, falls die von Gigabyte nicht passen sollte."
Auch war die dünne Backplate sowie das PCB verbogen. Vermutlich durch einen nicht ganz ausnivellierten Kühlkörper. Da PCB und Backplate recht nachgiebig sind, hat sich das bei der Montage im Werk wohl beim Anziehen der Schrauben verzogen, so meine Vermutung. Da es eben auch keinen zusätzlichen Metallrahmen gibt (wie. z.B. bei Asus Strix, MSI Suprim, PNY, Palit, ...), um das PCB von der Vorderseite zu stützen, kann das eben leicht passieren, wenn irgendetwas nicht 100%ig passt. Hätte mich bei der Konstruktion nicht gewundert, dass die Karte irgendwann ausfällt, da das ganze PCB und damit auch Lötstellen unter Spannung steht. Gerade auch im Hinblick auf die Berichte von brechenden PCBs bei Gigabyte-Karten hinterließ das keinen vertrauenserweckenden Eindruck.
Nachdem ich die verbogene Backplate bemerkt hatte, war mir dies dann auch in einigen Review-Videos der Karte aufgefallen.
Dazu noch die furchtbar dilettantische Lüftersteuerung samt Lüfter-Spikes und falsch gemeldeten Lüfterdrehzahlen, schlampige Firmware, die schlechte Software (GCC) und dann noch der inkompetente Kundenservice, welchem ich verzweifelt versuchte, klare Antworten zu entlocken.
Mein System schließe ich aus, da alle anderen problemlos liefen und die FE das bis heute auch noch tut ;)
spätestens beim Bezahlen bekommst du eine Fehlermeldung.
True, also hat Proshop das definitiv besser im Griff, auch sehr schick mit den NVIDIA Branding, für das Lederjacken feeling.
Ein kleiner virtueller Jensen Shopping Agent wäre auch hübsch. :LOL:
Ob eine 4090 TI oder olle Matrix, was willst du eigentlich damit? Du zockst doch eh nix - im Gegenteil, schreibst gefühlt jede Minute einen Post im Luxx oder weiß der Geier wo noch.
Why not ... wenn er daran seinen Spaß hat, who cares. :unsure:
Morgen nen Date mit einer Ukrainerin (und was für eine 8-) ) ausgefasst. Irgendwelche Tipps für nen Nerd der nur Shice und 4090 im Kopf hat? Also mit 4090 und Wakü prallen ist wohl nicht drin, soweit bin ich auch schon gekommen. :o Englischkenntnisse: Die, video graphics array, organic light-emitting diode, raytracing, ...
Ich weiß schon jetzt wie das enden wird. (y)
Ähnliche Themen
