[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mal was Neues von meiner Seite.
MSI Suprim Liquid X für einen Kollegen am Start. Ist ein ganz neues Batch, leider mit der 301er GPU.
OC ist daher sehr dürftig, aber Coil Whine deutlich geringer als bei meiner SuprimX damals.
Pumpe und Lüfter dafür sehr ruhig, der kleine auf der GPU ist minimal lauter als die auf der Air-Cooled Suprim, läuft aber sehr selten an.
Beste Grüße
Der Chip ist die neue Nvidia Batch welche auch schon auf den FE Karten gesehen worden ist.
Ist ein AD102-301 und nicht AD102-300. Bedeutet max. 1,07V für die GPU zum Beispiel.
Beste Grüße
Wieso, sonst würde da halt 301 und A2 stehen? @kmwteam kann das ja mal beim Kollegen auslesen.
Hey Leute, ich hoffe ihr könnt mir weiterhelfen (wollte jetzt auch nicht extra einen neuen Thread öffnen).
Ich bin auf der suche nach einer 4090. Zur Auswahl stehen m.M.n (bis 1699€) die "Palit 4090 Gamerock OC" und die "KFA2 4090 ST".
Bezüglich Wasserkühlung, OC (Powerlimit und normales OC über Afterburner), VRM und dem ganzen, bin ich mir unschlüssig.
Könnt ihr mir sagen, welche man nehmen sollte, oder ist das komplett egal.
Einige schreiben das die VRM bei den Palit GPUs zu schlecht sein soll, die KFA2 soll da schon besser aufgestellt sein.
Stand doch mal in den News.
Habe auch kurz auf mein Foto geguckt und habe noch die alte Revision AD102-300. Die Tools zeigen leider nichts eindeutiges. HWiNFO:
@DarkKey Das mit den VRM's ist ja eigentlich "nur" relevant, wenn du dort dauerhaft 600 Watt durchjagen und das Maximum beim benchen/overclocken rausholen willst.
Mit UV oder Default Specs, ist das eher nachrangig.
Wenn die Programme das nicht kennen, lesen sie das auch nicht aus, oder? :d
@kmwteam wo hast du es ausgelesen? Oder nur gesehen das nicht über 1.07V geht?
Relativ simpel, 1.07v und eine neue ID, aktuelle Biose aus techpowerup können nicht geflasht werden.
Beste Grüße
Ich hab seit Dezember 2022 die KFA2 und war noch mit keiner GPU so glücklich wie mit der. Kein Spulenfiepen, leise Lüfter. Traumkarte
Dauerhaft 600W zu nutzen, wohl ehr nicht aber für OC versuche wäre es interessant. OC beim Zocken bringt eh nicht mehr viel.
Die Palit und die KFA2 haben aber nur ein kleineres Powerlimit.
Ob es sinn macht, mehr auszugeben und z.b. auf eine TUF zu gehen ? :unsure:
Hast du diese auch mit einem WaKü Block versehen? Bei den Blöcken ist leider immer nur die SG Variante gelistet.
Zudem habe ich irgendwo im HWLuxx gelesen, das jemand einen Alphacool Block auf die ST? Variante geschnallt hat und 1 bis 2 VRM nur halb
bedeckt waren.
Zudem habe ich irgendwo im HWLuxx gelesen, das jemand einen Alphacool Block auf die ST? Variante geschnallt hat und 1/2 VRM nur halb
bedeckt waren.
Sind die KFA² SG und ST so verschieden das der Gelistete ALC block nur auf der SG passt? o_O
@Körperklaus Warum ist die VRM nicht so wichtig wenn ich auf WaKü umbaue?
Ich gucke eigentlich explizit nach den Preisen.
Die GameRock (OC) ist am günstigsten und der Block ist auch vohanden. - Das einzigste was mich abschreckt (evtl unbegründet, ist das die VRM schlechter sein soll)
Die KFA2 ST V2 wäre ca. 20€ teurer - Frage ist hier, ob es sich lohnt und ob die Blöcke da auch passen, da immer nur die SG Variante gelistet ist.
Alternativ wäre die Asus TUF da mit besseren VRM und größerem Powerlimit. Diese Kostet aber auch ~170€ mehr. Dafür hätte ich theoretisch auch die GameRock inkl WaKü.
Ich möchte jetzt nur nicht bei der finalen Entscheidung wegen 100€ auf die Schnau*e fallen. -Wahrscheinlich mache ich mir zu viele Gedanken und die 4090 unterschieden sich eh kaum.
Naja, also selbst die Gamerock ist für 800 Watt ausgelegt trotz der schwächeren VRMs. Reicht also dicke, da kommst du mit max. 1,1v bzw. 1,07V bei den neuen Rev. nie hin ohne hartes Modden.
Beste Grüße
Wenn du schon weißt das die TUF die bessere wäre , und du nicht wegen 100€+- Differenz falsch investieren willst , warum kaufst du sie nicht ? Bei der TUF gibt es ja auch EK kühler statt Alphacool . Wäre vllt bessere Kombination .
Gegenfrage: Was erhoffst du dir davon, "bessere" VRM's zu haben?
Die Karten laufen auch alle unter Luft ohne Probleme kühl und relativ leise. Das einzige Ärgernis ist das Spulenfiepen und für den ein oder anderen, dass manche Modelle kein 600 Watt BIOS haben... im Vergleich zu anderen Generationen sind das Allerweltsprobleme, wenn man mal noch davon absieht, dass manch einer den Stecker nicht gerade reingesteckt hat.
Bei deinem genannten Einsatzbereich sind die VRM's absolut sekundär... Ich würde schauen, mit welchem Modell + Block ich am Ende Preis-/Leistungstechnisch am besten komme bzw. welcher Hersteller Umbau auf Wasser ohne Garantieverlust erlaubt und dann ab dafür.
Ähnliche Themen
