[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich erinnere mich noch an die ersten Videos von LTT. Damals noch Unboxing auf ner Parkbank 😂
Die heutigen Videos von LTT sind doch 90% nur Show und Unterhaltung. Kaum Praxisnahe Berichterstattung...
scheint ja aber zu klappen :hmm:
Was will man mehr?
Könnt ihr bitte hier mal prüfen, ob ihr das Problem mit dem MSI AB auch habt?
Ich gucke gern LTT Videos aber nicht für die Reviews von Hardware, da gibt es bessere Alternativen. Die haben aber oft echt interessante und teils witzige Projekte. Es ist halt "nur" Entertainment für die Mittagspause aber das machen sie echt gut.
Inzwischen sind das einfach nur noch dumme Videos für noch dümmere Menschen.
Und an dummen Menschen gibt es nie einen Mangel, kein Wunder das hier Kohle ohne Ende erwirtschaftet/gescheffelt wird 😏
Eingestellte MSI Afterburner UV und/oder OC settings greifen, bis dein PC ausgemacht bzw. neugestartet wird. Das Programm muss nicht zwingend laufen. "Start mit Windows" Option ist auch nicht notwendig, sofern dein UV/OC Profil mit Startup (unten links im Cyborg Red skin) geladen wird. Kannst ja mal ausprobieren und mit HWInfo die GPU Werte auslesen.
So ist es. Für mehr sind die einfach nicht mehr zu gebrauchen.
Naja er hat nen Prototypen eines Wasserkühlers versteigert statt zurückzuschicken nach dem er das ding falsch getestet und aus dem grund schlecht geredet hat.
so hab ich das verstanden. richtiger arschlochmove :d
Ja, Solar Bay läuft nicht mit dem RTSS. Der muss vorher beendet werden.
Wenn man den beendet geht der gleich wieder auf, weißt du einen Weg RTSS zu beenden ohne den Ab schließen zu müssen?
Leider nicht. Aber wie kannagi schon schrieb, muss der auch gar nicht laufen. Takt ändern, Haken für übernehmen klicken, AB beenden -Takt bleibt.
RTSS "Stealth Mode" hilft nicht?
Overlay deaktivieren im after seinem burner?
Also entweder hat Cablemod massiv mehr Kabel verkauft, oder die taugen wirklich nicht so wirklich. Da liest man ja von einigen Problemen. ModMesh hat leider auch diesen Nylon Überzug, den ich nicht will und nicht zum Rest passt, also kein Paracord. Den gibt es nur bei der ModFlex Serie, die man hier aber nirgends kriegt, nur im EU Shop bei denen selbst.
90° gewinkelt gibt es da leider nichts, d.h. ich muss diesen Adapter kaufen und das Kabel? Also mehrere dieser Problem Stecker. Klingt super.
Da Fasgear ja anscheinend besser ist (oder kaum gekauft?):
Kennst jemand diese Stecker?
Ich brauche halt 90 oder alternativ 180°.
Dachte dafür gibt's tiktok🙈
Welche Temperaturen erreicht Ihr mit der Wasserkühlung im Delta Wasser zu GPU?
@TurricanM3
was dabei zu beachten ist:
beim Heatkiller lässt sich der Wireview vermutlich nicht montieren, da es beim Core auch nicht ging.
Und nicht zu vergessen: Wenn die Graka vertikal eingebaut ist, dann ist das Display natürlich auch fürn Arsch. @TurricanM3
Sind nur noch 10 Watt über PCI E , aber wird sich nächste Gen. wohl wieder ändern bzw. kann sich wieder ändern. Gab mittlerweile paar Änderung bzgl. der PCI SIG. Igor hatte das ausführlich dazu was gesagt. Dann kann es auch bis 675 Watt PL geben bei einem Stromanschluss .
