[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also VRAM Temps bei mir nie über 75°, der Hotspot ist da wärmer.
Und ich überlege von der wassergekühlten MSI 4090 SuprimX auf die FE mit Wakü umzusteigen, weil mir die SuprimX vom PCB her zu groß ist. :fresse:
Allein, dass das PCB nun größer als das Board ist nervt mich tierisch.
Mmh tauschen :bigok::ROFLMAO:
Spaß die bleibt die FE keine Lust mehr gerade auf basteln.
Allerdings ist ja noch lange hin bis zur 5090 da könnte man schon noch Mal umbauen.
Sei doch froh da hast ein schönes Stück Hardware @Felix the Cat
Ich war im Januar auch kurz davor die SuprimX auszuprobieren
@Gurkengraeber
Bei der FE auch Top Temps beim RAM irgendwas um die 67-70 C.
Ich will nicht nicht beschweren. Es sind Luxusprobleme. ;)
Bei der 3090 lag es aber eher daran das auf der Rückseite noch welche saßen die nur mit der Backplate passiv gekühlt waren.
Weiss ich zu gut...
(110°C bei bestimmten Dingen)
Dafür ist Benchen mit der 4090 bei tiefen Temp nicht so toll. Man muss nen Riesenaufwand betreiben (GPU tief kühlen, aber RAM beheizen)
kann es sein, dass die 4090 die RAMs ordentlich heizt? Ein Grund für mich wieder auf WaKü zu setzen.
ich meine nicht den VRAM sondern die DDR4/5 DIMMS, die die warme Luft abbekommen. :)
EVGA Vorsprung durch Technik.👍
Ja mir gefällt es besser wenn die gpu größe deutlich zu erkennen ist und der große Kühler macht auch high end itx Systeme ohne kompromisse realisierbar
Wie gerne ich mein Nr200p wieder haben möchte.. musste aufgrund der länge der 4090 Zotac Airo(GhettoMod) auf o11 Air Mini wechseln aber der ist mir einfach zu groß, ich denke wirklich darüber nach die Zotac gegen eine PNY oder Suprim zu tauschen und wieder auf nem Itx zu wechseln. :stupid:
Ja die suprim passt bis auf 1-2mm rein und das Design passt super zum Nr200 und ingame packt sie 3000mhz. Ich würde mir jetzt aber lieber eine günstigere fe kaufen die passt auch sehr gut.
Das Ding ist halt man ist auch beim Mainboard und NT flexibler beim Air Mini .
Für mich war das von der Grösse ein riesen Schritt kommend vom vom Corsair 1000D.
Da der Halter aus Stahl für die 140er Lüfter rausgeflogen ist hab ich durch den Mod in der Front noch knapp einen Zentimeter da zu gewonnen für noch größere Grafikkarten.
Da sollte später auch eine 5090 locker ihren Platz finden.
Welche gesleevten Kabel kann man nun bedenkenlos empfehlen? Cablemod?
EDIT:
Achso, passen die Kabel alle beim Heatkiller?
Be quiet, will aber eh keine nativen. Nur Verlängerungen.
Ich will schon was paracord ähnliches, also optisch ansprechend und einfach schwarz. Noname Zeugs auf jeden Fall nicht.
Sind die Cablemod Sachen wie paracord oder ist das eher so harter Kunststoffüberzug?
Der PC ist schon seit Jahren eine offene Dauerbaustelle, ich will das endlich mal in Ordnung bringen.
Fasgear Kabel ftw? ist zwar NoName, aber tut es bisher zuverlässig...
ich hatte schon CableMod kabel die einen defekt hatte. daher nehme ich nur noch die OEM Kabel 😅.
Auch wenn es nicht so schön aussieht
Dann das be quiet Kabel, das ist auch noch okay. Ist aber nicht gesleevt. :fresse:
Ansonsten schwören viele auf diese Amazon China Verlängerungskabel, komme aber auf den Namen nicht.
Fasgear. Hat auch tadellos funktioniert, allerdings gab es das nur in schwarz oder schwarz/weiß. Daher hab ich dann doch das weiße Seasonic genommen. Das Fasgear war aber auch ok, wirkte vielleicht nicht ganz so hochwertig.
Benutze ich jetzt paar Monate, läuft einwandfrei.
LINKUP – AVA Rechter Winkel 600W PCIE5.0 12VHPWR (16-polig/12+4) 16 AWG ummanteltes Hochstrom-Netzteilkabel – 70 cm – (Schwarz) Kompatibel mit allen RTX4000- und RTX3000-FE-GPUs https://amzn.eu/d/30Hbyq5
Bin mal gespannt wieviele beim gpu Wechsel der 4080/4090 bemerken das Ihr 90/180 Grad Adapterkabel oder kabelmod Kabel in der gpu feststeckt da der Adapter verschmort ist. Ich selbst nutze ein teures kabelmod Kabel und melde bedenken an :)
Cablemod produziert wie alle anderen auch in China. Mein Adapter war verschmort und nachdem ich einige Kabel durch habe, muss ich sagen, die China Kabel von Amazon waren alle 1A verarbeitet und haben sich sehr gut stecken lassen. Dazu sollte man noch per HWInfo seine Werte beobachten die am 12VHPWR Anschluss Anliegen. Zu hohe Drops bei Last lassen vermuten, dass irgendwo massiv Leistung als Abwärme abgeben wird.
Habe auch das Cablemod Kabel aber mittlerweile keine Bedenken mehr. Hatte es auch schon 2-3 mal abgesteckt wegen anderer Umbaumaßnahmen mit CPU + Mainboard und SSD und da ist nichts zu sehen und top verarbeitet.
Fasgear Kabel 3x8 Pin auf 12 VHPWR, glaub das ist okay oder? (Paar Stunden Warzone und vorher Idle...)
linus kriegt sein fett weg
Linus zu seinem Staff: "Hey Jungs, folgendes... 🤔 "
GN: "Die schon wieder. Oder vielleicht Absicht? Egal, n müden August kriegen wir so überbrückt. Jungs... 🤫 ".
Linus: "Oooouuuu yeeeeeaaahhhh👹 "
Jay: "Darf ich mitspielen? 😢 "
HWunboxed: "für uns fällt mal wieder nix ab 😐"
Die deutschen Techtuber: "Hmm...👀"
Das Internet: :poop: :poop: :poop:
Ähnliche Themen
