[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ehrlich gesagt weiß ich noch gar nicht was ich mache, wenn die nächste Gen raus kommt. Die 4090 wird ja dann erst mal immer noch ordentlich Geld wert sein und so würde ein Aufrüsten nicht ganz so teuer werden. Aber naja, wären sicher immer noch einige hundert Euro. XD
Bitte nicht diese Dame auch noch in einem Hardwareforum. :fresse:
dachte das isn hässlicher kerl
Einfach mal nicht kaufen wie wärs damit? Wird sowieso nur so gekauft und nicht weil die fps nicht reichen
Das brauchst du jetzt auch noch nicht zu wissen. Bis das Ding erscheint, ist noch lange hin und bis dahin ändert sich deine Meinung sowieso noch 10-mal.
Istn Hobby. Wer da mit dem spitzen Bleistift unterwegs sollte mal über n Tapetenwechsel nachdenken.
Kann hier jemand etwas zur FE berichten? Wie ist der Lüfter macht der komische Geräusche? Hatte gehört der soll ein nerviges Brummen haben
Die TUF STRIX Master sind bei 1000RPM klar leiser fast lautlos würde ich sagen je nach Abstand bei etwa gleicher Temp ca 62 C wie eine FE die etwa 1250 RPM drehen muss.
Rattern konnte ich bisher nicht wahrnehmen ...höre aber ganz klar das Rauschen das ist jetzt nicht leise aber für mich okay bei 3m Sitzabstand.
Wenn die Anlage läuft oder Kopfhörer drauf sind erst Recht nicht
Dafür war die TUF am Rasseln Pfeifen wie Sau ich dachte das Teil kriegt gleich nen Kolbenfresser die Strix war auch am Poltern wenn auch ein wenig ruhiger als die TUF aber trotzdem noch viel zu laut.
Die Spulen meiner FE sind da aber erheblich zurückhaltender.
Das sind Erinnerungen aus dem Januar 2023.
Ich hab meinen Frieden mit der FE gemacht bei 0.975V 2760/1000 bei ca 1200 RPM.
Lust auf Wasser umzubauen hatte ich bisher nicht.
Das fiepen und Rasseln der anderen beiden Karten war für mich aber das größere übel.
Ich überlege mir jeden Tag, wie Dein Interesse daran wecken könnte :)
Auf Wasser umgebaut wirkt die so winzig ich störe mich irgendwie daran.
Hab mir ja das Mini Air geholt aber selbst da würde die auf Wasser wie eine Einsteiger Karte wirken.
Ja mir gefällt es besser wenn die gpu größe deutlich zu erkennen ist und der große Kühler macht auch high end itx Systeme ohne kompromisse realisierbar
Wenn Temp Probleme da wären dann hätte ich das schon gemacht .
Aber so tue ich mir echt schwer das schöne Ding zu zerlegen .
Die LuftKühler sind schon Top geworden bei der 4090.
Mal sehen ob man das bei der 5090 bei behält weil angeblich mit 600W gerechnet wurde seitens der Hersteller.
Dann wäre man wohl auch bei um die 83C+ rausgekommen und hohen Lüfter Drehzahlen.
Der "Flow Through Lüfter" "hinten" auf der FE ist einfach bei 30% schon nervig m.M.n. aber ich lebe damit, weil ich beim spielen immer Kopfhörer auf habe.
Dabei könnte er sehr sicher mit weniger als 30% angesteuert werden... wenn ich z.B: im UEFI abhänge, dreht er auch permanent, aber man hört ihn dann nicht so, d.h. er kann theoretisch auch langsamer, man darf nur nicht...
Ja der rechte Lüfter geht einfach gar nicht. Allerdings gibt es dafür auch einen recht einfach umzusetzenden Ghetto Mod, der den Lüfter etwas anhebt. Damit reduziert sich das Brummen um einiges. Der User hier hatte dazu sogar n YouTube Video gemacht.
War ansonsten mit der FE zufrieden, sie ist einfach krass wertig. Aber die Strix White passte nun mal besser zum Build.
Hab ich gemacht... hilft nur marginal, ist immer noch nervig :d egal ob 3, 4 oder 7mm höher
Das ist natürlich shite. Ich zocke mit Boxen, daher war es für mich inakzeptabel. Wollte aber eh was weißes also am Ende dann eh wurscht. :fresse:
  • Danke
Reaktionen: hwk
kann es sein, dass die 4090 die RAMs ordentlich heizt? Ein Grund für mich wieder auf WaKü zu setzen.
Ja der Vram wird auch bei mir immer etwas wärmer als der Rest.
Bei der 3090 lag es aber eher daran das auf der Rückseite noch welche saßen die nur mit der Backplate passiv gekühlt waren.
Per ab + 1700 nichts besonderes also
Also zumindest bei mir bleiben die VRAM-Temperaturen immer unter 90°. Ich sehe da keinen Grund für eine Wakü!
Zumal es der vram gerne etwas wärmer mag für hohen Takt.
[Bild]
Und ich überlege von der wassergekühlten MSI 4090 SuprimX auf die FE mit Wakü umzusteigen, weil mir die SuprimX vom PCB her zu groß ist. :fresse:
Allein, dass das PCB nun größer als das Board ist nervt mich tierisch.
Ähnliche Themen
