[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich hab nen 12700k, ich hoffe mit dem wird Cyberpunk noch halbwegs laufen :fresse:
Krass ist der Energieverbrauch der 4090 suprim bei mir 400-500watt 2k pathtracing all in :) hätte ich da noch 100- 200w cpu zu kühlen würd mein itx 850w Netzteil sicher aufgeben.
Warum sollte? Habe mit meinem 850W keine Probleme festgestellt, da komme ich auch mit dicker Wakü nicht ran und ein gutes Netzteil hat auch noch Reserven.
Das ist so, aber den heftigsten Verbrauch hatte ich mit 4090 und 13900K mit Metro Enhanced Edition.
4090 ins PL gelaufen und 13900K bis 231 Watt Peak. Da war bisher CP 2077 genügsamer.
@Powerplay hast du den Bann schon kassiert?? :lol:
Wenn du testen willst, was deine 4090 schafft, muss du Dead Space Remake nehmen und in 6K einfach die Story spielen.
Alle Settings auf Max + DLSS SR Quality.
6K erreichst du über nen 4K TV / Monitor + DLDSR 2.25, aber zuvor muss du die 4096 mit CRU killen.
5K ist nicht ausreichend zum Testen.
Ich lösche die 4096er immer mit CRU
Und ja habe schon in 5760x3240 gezockt aber nur blind eingestellt gehabt. Will aber noch ausloten was geht.
Werde aber kein Max OC oder so machen sondern nur schauen was mit 2700Mhz & 2800Mhz läuft.
Habe das aber so schon immer gemacht weil ich ein absolut stabiles System haben will.
Mich würde aber auch interessieren was mit min Volt geht
Bin ich richtig in der Annahme, dass es in der Praxis auf realistischen Auflösungen (also nicht dieser 1280x720 Benchmark quatsch) kaum Unterschiede geben wird da die 4090 eh ins Limit läuft?
Ist Dir noch nie aufgefallen, dass Du das selbst in der Hand hast, und jeder der erzählt, dass seine 4090 sich langweilt im Grunde genommen nur zu faul/blöd ist, sich mit den Reglern zu beschäftigen?
Ohohoh, meine 4090 langweilt sich in FHD
Ups .. das Game hat ja Regler.
Dazu braucht es nicht mal "realistische" Auflösungen. FHD reicht völlig aus 8-)
Also, ich meine, wenn man seine Regler nicht bedienen möchte, oder nur eine einzige Reglerstellung kennt/will, dann braucht man sich am Ende natürlich auch nicht beschwehren^^ (Soll solche Leute ja geben, und das ist kein Angriff, bitte nicht böse sein).
Im Notfall hat man immer noch DSR/DL-DSR :-)
Selbst das freie FG läuft mittlerweile richtig gut. Allerdings schauen GamePass User in die Röhre, da SFSE (script extender) nicht unterstützt wird.
Also der DLSS und FG Mod funktioniert auch in der Gamepass Version, ebenso die LUT/Texture Mods... sonst hab ich noch keinen ausprobiert...
hat hier jemand schon das galax bios auf ne manli gallardo geflasht? gibts was zu beachten? danke :)
edit: würde noch das 12vhpwr cable von seasonic dazukaufen und dann sollte es klappen, oder? karte läuft mit bykski kühler und ist komplett mit k5pro eingekleistert :angel:
Weiß jemand wann der Cyberpunk Patch heute kommt? Wollte gerade in der Mittagspause reinspielen aber bei GOG wird noch nichts geladen.
Ok also für mich dann erst spät wenn das Kind im Bett ist :fresse:
Hier lohnt sich wenigstens mal die 4090 :fresse2:
In Bezug auf Cyperpunk gibt's jetzt auch im Treiber Neuigkeiten:
The new version is: 537.52 WHQL
Download it here
New in this version:
Game Ready
  • Cyberpunk 2077: Phantom Liberty
  • Warhaven
  • Witchfire
  • Party Animals
Komisch Experience hat mir den 537.42 Runter geladen.
Auf der NV Seite sehe ich den 537.52 nicht.
An alle Cyperpunk-Spieler:
Hat denn der neue Treiber merkbare Verbesserungen gebracht oder ist das nur eine Beruhigungspille?
Der Patch 2.0 vom Spiel selbst fehlt noch damit der Treiber greifen darf.
Bei mir ist noch kein Patch da.
Ich kann mit dem neuen Treiber HDR nicht mehr nutzen...Wenn ich in den HDR Mode wechsle bleibt das Bild schwarz. Wenn ich per Win+Alt+B zurückschalte geht wieder alles. Hat hier wer den Treiber und kann das bei sich mal testen? Ich hab Windows 11
Ähnliche Themen
