[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Einfach wie bei jedem anderen Stecker auch schauen, dass es richtig sitzt, dann passiert auch nix.
Genau das. Hab neulich auch irgendwas gefummelt und muss wohl an den Stecker gekommen sein. Vor dem Einschalten routinemäßig kontrolliert, wieder passend und vollständig in den Sitz geschoben und gut ist.
Mach ich aber auch mit fast allen anderen Stromsteckern immer so wenn ich mal dran war. Genauso wie man nochmal schaut dass nichts in den Lüfterblättern hängt etc.
Hab ja vor kurzem die Hardware in ein neues Gehäuse verfrachtet alles Tutti.
Die weißen Corsair Kabel sind aber gefüllt noch etwas flexibler als die schwarzen.
Ich mach mir da keine Sorgen.
Der Link oben war für die Experimentier freudigen mit Kabelpeitschen und Adapter sowas würde ich mir nicht rein bauen.
Der große Schrecken wird erst kommen wenn die neue Generation raus kommt und viele vergeblich versuchen werdende den Stromstecker raus zu bekommen:)
Facepalm als Reaktion sollte jetzt aber wirklich zeitnah eingeführt werden.
Selbst wenn das so wäre, Seitenschneider regelt. Zur Not der Dremel. Wenns dann zu dem Zeitpunkt fast 3 Jahre gehalten hat, kann man zum Abschluss nochmal für ~200€ einen neuen Stecker an der Grafikkarte aufbringen lassen. Bei Gigabunt frage ich da garnicht erst. Die Garantie ist eh nix wert. War halt damals eine der wenigen Karten mit kaum bis nicht hörbarem Spulenpfiff.
Ich glaubs aber ehrlich gesagt jetzt nicht mehr. Die Karte läuft ziemlich genau ein Jahr und wie gesagt: neulich hat er sich beim Hantieren im Gehäuse leicht gelöst (halber Millimeter oder so).
Hi
Ähm....DER GPU Video Takt in HWINFO ....ist das der ominöse Takt ?
Dachte der soll schlimmstenfalls ~150 Mhz unter dem GPU Takt liegen ?
HWINFO "sacht" GPU 3030 Mhz GPU Video Takt ~2040~2100 MHz ..................
Eben mal cyberpunk Bench laufen gelassen...deswegen.
Ob curve oder einfach +225 Mhz spielt da keine Rolle.
Gruß Bernd
Habs mal Markiert
Beste Grüße
Hi
Joo...Danke.
Also doch kein so großer Abstand. Hatte mich schon gewundert.
alles klar. Danke.
Gruß Bernd
Was soll ich machen?
Wird man die hier überhaupt bekommen?
Ansonsten aber irgendwie unsinnig wenn man einen normalen ATX Airflow aufgebaut hat (vorne / unten rein, hinten / oben raus).
Nur die, die unnötiges OC betreiben, alle anderen mit UV brauchen keine Angst haben. XD
Neee UV ist nur für luftgekühlte Karten. Mein Cablemod Kabel lebt auch noch. :d
Wie verlässlich sind die Angaben von HWiNFO eigentlich? "gemessene" 650W im Peak scheint mir doch recht viel zu sein.
Also wenn man solche Meldungen liest wie "nach einem Jahr Einsatz Stecker geschmolzen" werde ich wohl auch mal nach einer Alternative schauen.
Zum Glück gibt es ja genug Themen dafür hier im Forum.
Gegenüber dem tatsächlichen FE-Kühlkonzept fehlt hier ein wichtiger Aspekt: Die FE befördert zumindest einen Teil der erwärmten Luft durch die Öffnungen in der Slotblende direkt aus dem Gehäuse hinaus.
Ähnliche Themen
