[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hier auch mal von meiner PNY XLR8 4090 (non OC Variante) ein GPU-Z Screenshot
Interessant das wir verschiedene Bios Versionen haben.
Meine Karte geht auch nachdem zocken in 2-3 Minuten auf 0rpm. Im Multimonitor Betrieb zieht die Karte laut Gforce Experience ~11W. Im Single Monitor 6W.
Hatte mal mit der KFA2 4090 das "Problem" das die Karte Anfangs auch nicht im Multimonitor Betrieb auf 0rpm gehen wollte, da sie dabei laut Gforce Experience an der 30W Grenze kratzte. Glaub ist eines der beiden UND Verknüpfungen (Watt & temp) das die 4090 auf 0 rpm geht. Nach paar Neustarts und DisplayPort rein und raus, gings dann auf einmal.
Hab jetzt mal das Bios auf meine PNY geflasht, interessant ist das du bei 30% nur knapp 1000 RPM hast was deutlich leiser ist, meine Karte dreht mit 1500 RPM, auch interessant das wirklich nach 2-3 Minuten die Karte in den Zero Fan Mod geht, während meine je nach Gutdünken 5-10 Minuten braucht.
Am Idle Stromverbrauch hat sich nicht viel geändert, liegt wohl auch an meiner Auflösung. Allerdings lief die Karte nicht stabil, ich merkte schon im 2D Modus das die Edge hing und auch der Explorer reagierte träge. Vielleicht sind die verbauten Komponenten bei PNY doch je nach Board unterschiedlich...
Hab mal wieder auf mein altes Bios zurückgeflasht den 3D Modus wollte ich jetzt nicht testen wenn schon unter Windows Betrieb die Karte Faxen macht.
@EleCtricStream :
Du hast doch auch die Non-OC Variante der XLR8 , oder ? Laut dem GPU-Z Screenshot von dir, hast du auch wie ich einen Boost Takt von 2520 MHz. Ein Freund von mir (habe seinen neuen PC 13700k+4090 zusammen geschraubt), der hat die XLR8-OC und bei ihm drehen auch die Lüfter auf mind. 1500rpm. Dachte das wäre bei der OC-Variante eine "spezielle" Eigenschaft. Schon komisch was da PNY treibt und welchen Hintergrund das hat... zumindest scheinen warum auch immer unterschiedliche Bios Versionen einen "Sinn" zu machen.
Bezgl. Stromverbrauch. Ja ich glaube mich auch zu entsinnen das bei meinem Freund der Stromverbrauch der GK im IDLE auch wesendlich höher als bei mir ist und die Lüfter auch so gut wie nicht ausgehen. Ihn störts aber nicht, er ist da schmerzlos. Er hat einen UWQHD Monitor @144Hz ... Scheint wohl mitunter an der Auflösung zu liegen.
Interessant ist das alles doch irgendwie, bin mal gespannt ob der eine oder andere Foren-Member hier ähnliche Erfahrungen gemacht hat und wie das mit der unterschiedlichen rpm und dem Stromverbauch technisch zustande kommt, außer das es halt im Bios der GK so hinterlegt ist.
Achja mein WQHD lüft auf 144Hz. der 2. FHD auf 60Hz. Gestern nach einer kurzen 2h Stunde Runde BF2042 :-), habe ich mal extra geschaut , wie lange es dauert bis die Lüfter ausgehen: 90 Sekunden (im single Monitor Betrieb, den 2. schalte ich nur an wenn ich z.B. im Discord bin)
@Roadi
so wie ich das sehe gibt es mehrere Branches
95.02.18.80.CF in dem Fall .80.
Dein Bios hat nach der 18 die .00
Die OC Version und die non OC gibt es jeweils mit dem 80er Branch
das deutet schon auf eine andere HW hin
@EleCtricStream
Ja das könnte schon sein mit unterschiedlichen HW Versionen. Aber ob sich das wirklich so an der Bios Version ablesen lässt ?
Bei Techpowerup in der Datenbank findet man zur PNY XLR8 noch einige weitere "HW Versionen"
z.B.
95.02.3C.00.50
95.02.3C.40.3A
95.02.18.40.14
Das man wirklich soviele HW-Varianten (Layout oder Schaltung oder wichtiges BE wo anderst angesprochen werden muss) hat ? Da würde eine anderes Bios durchaus Sinn machen.
Aber bei Bestückänderungen-/ optionen , also andere Zulieferer vom Widerstand/Elko, FET usw. bei gleichen techn. Eigenschaften oder neue/andere Sammelnummer vom Bauteil müsste dann ja nicht gleich in einer neue HW Variante münden und dann auch nicht in neuer SW(Bios)
Aber weiß die Himbeere was so ein GK Hersteller treibt :-).
Hab jetzt die Tage doch mal die PNY auf +45 Mhz gestellt um ein OC Modell zu simulieren, eigl wollte ich ja nicht aber das RGB Tool von PNY bietet es ja quasi geradezu an. Ist schon cool, die Karte boostet bei Avatar stabil auf 2780-2790 MHz, bei nicht so anspruchsvollen Spielen auf 2820 MHz, bleibt weiterhin sehr kühl und leise und der Stromverbrauch ist quasi gleich.
Am Ende des Tages bringt es natürlich, wenn überhaupt, ~1FPS, weshalb es jetzt wieder mit normalem Takt läuft. Gut mehr Luft nach oben ist halt nicht,
die SuprimX konnte man auf über 3Ghz prügeln oder auf 2640@0.89mV im UV betreiben.
Bzw. sie lief auch schon mit 2950 Mhz und +1300 Mhz Ram rockstable und das dauerhaft, ohne Erhöhung des PT, mit etwas mehr kam diese eigl immer auf über 3Ghz im boost in manchen Games, wäre das Kabel nicht durchgebrannt hätte ich sie natürlich weiter verwendet. Bekomme die Karte diese Woche doch schon von Mindfactory zurück, bin gespannt ob es die gleiche ist oder ein Austauschmodell, werde aber jetzt bei der PNY bleiben, da diese Karte auch besser in mein Gehäuse passt. Die SuprimX würde ich dann hier im Forum für einen guten Preis anbieten ;)
Das war wieder mal unkontrollierter Basteldrang :ROFLMAO: Bringt quasi nichts, außer mal wieder der Beweis das OC Karten meistens Nepp sind.
Bei der PNY geht ja Erhöhung des PT sowieso nicht wirklich, bei der Suprim machte es aber schon einen Unterschied, zwischen UV Profil 2640 und OC Profil von 2950 Mhz, waren es ja nach Spiel zwischen 5-10 FPS.
Vor allem wenn FG zum Einsatz kommt, oder etwas mehr RTX-Bums, sind die FPS dann doch etwas mehr. Klar ob einem dann ~300 Watt zu ~500 Watt die FPS dann wert sind muss jeder selbst wissen.
Bei UV ist eben so ne Sache, der Crossbar Takt sinkt damit auch geringfügig, 2310 Mhz liegt der max. bei der PNY. so um die ~1210 Mhz waren es bei der SuprimX mit UV.
Wenn UV bei der PNY dann würde ich diesmal auf Max-Taktstufe gehen dann bleibt das auch mit der Crossbar synchron. Blos dann mit einer schönen Kurve, ohne ne steile Buchhalternase, muss ich in Ruhe kommendes WE ausloten.
@EleCtricStream während du auf eine 2000€ grafikkarte von der RMA gewartet hast, hattest du dir in der Zwischenzeit eine 2te 2000€ grafikkarte gekauft?
Wir sind im luxx, da hat man immer 2-3 auf Halde für unerwartetes liegen :d
Jetzt heulen alle wieder rum das sie keine Karten bekommen oder zu teuer. :fresse:
da zähle ich mich nicht dazu, hab ja mehr als eine hier, aber eine weiße Strix fehlt halt noch
Bin echt auf die 5090 gespannt, Leistung fast egal, eher wie die Kühler, Spulen und der Stromstecker werden, das ist ja mittlerweile viel wichtiger. ^^
da geb ich Dir recht 👌
Und im PCGH gab es auch kurz das Gerücht über eine 4090 Super, aber in dieser Runde war sie ja nicht dabei und die Chancen schwinden halt dass da nochwas vor der 5090 kommt
ist halt wirklich ein Haufen Asche für ne GPU, mancher kauft für weniger nen ganzen PC
kann da schon manchen verstehen dass er das boykottiert oder sich nicht leisten kann/will
zumal bei solchen Fehlern wie der 12VHPWR Stecker und dem Spulen-Chor
Jo geht mir auch so, aber selbst die weißen Strixen sind ja unbezahlbar, aber die will ja eh keiner, außer Leute mit Hörgeräten. :fresse:
Also meine wollten genug Leute dass ich mit einem Gewinn da rausgekommen bin. Timing ist alles. :)
Das fiepen hat die Leute auch damals bei der 970 z.b. nicht abgehalten herzhaft zuzugreifen. Das Problem ist so alt, wie es Grafikkarten gibt und wird sich wohl auch nicht mehr ändern :d
Schon ganz cool aber all das um ein einziges Kabel zu sparen? Vor allem wird man die Karte im Wiederverkauf wenn dann nur mit Mainboard zusammen wieder los weil das Ding sonst niemand betreiben kann.
Und man ist vorerst auch an bestimmte Gehäuse gebunden...
Wie viele aktuelle Gehäuse haben denn überhaupt den entsprechenden Platz auf der Rückseite, um die Stecker ins Mainboard zu bekommen?
Von den Preisen will ich gar nicht reden... :rolleyes:
Ich denke, da wird es auf dem Markt bisher kaum passende Gehäuse geben. Und ASUS traue ich zu, hier nur wieder exklusiv passende Gehäuse zu verkaufen. Man müsste also nebst ASUS-GPU und ASUS-Mainboard auch ein ASUS-Gehäuse kaufen, um in den Genuss eines "kabellosen" Systems zu kommen. Geschickt eingefädelt $$$
Man merkt aber, dass die Leute keine Lust mehr auf diese teure Scheiße haben.
Es wäre halt schön, wenn das irgendwann mal ein ordentlicher Standard wäre...
Ist mit Sicherheit auch anwenderfreundlicher, als das Gefummel mit den Kabeln, wenn man nur noch die Karte einstecken muss und fertig. Aber bis wir soweit sind, lassen sich Asus und Co. halt fürstlich von den early Adoptern bezahlen und jeder macht erstmal seinen proprietären Scheiß. (überspitzt formuliert)
Und was bringt mir eine kabellose Karte, wenn es am Ende spulentechnisch wieder das singende klingende Bäumchen ist? :shot:
Im Artikel wurden einige Partner genannt, die in Q1 entsprechende Gehäuse anbieten wollen.
"Asus nennt als Mitglieder der „BTF Alliance“ die Firmen Aerocool, be quiet!, Cooler Master, Corsair, In Win, Lian Li, Phanteks, Silverstone und Thermaltake."
Der Ansatz ohne Stecker/Kabel ist interessant aber es müsste einfach ein Industrie Standard werden, dann wäre das kein Thema, gibt es ja im Serverbereich auch schon so.
Jedes Kabel was gespart wird, ist eine potenzielle Fehlerquelle weniger.
Das dieses Zeug von Asus proprietär eingesetzt wird, steht außer Frage.
Dann kommt dann noch MSI ums Eck usw. Die wittern eben schon den Zusatz gewinn, als ob 1000+ Euro Mainboards und überteuerte Strixxen und Suprims nicht schon die Spitze des Eisberges wären..
Das ist alles andere als kundenfreundlich. Nvidia oder AMD bzw. Intel könnten auch auf einen neuen Standard bestehen, dann würden auch alle bekannten Hersteller mitziehen.
Damals war das gar kein Problem.. gefühlt wurden Standards schneller etabliert.
