[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Und jeder PIN bekommt den Namen eines Luxx-Users…? :d
Ich meld mich mal für PIN #1 an. Wer ist Masse? :fresse:
Masse hab ich (100 Kg), also meld ich mich mal für die Masse.
Hoffentlich kommen da Verbesserungen an dem Anschluss oder im Idealfall bei einem Nachfolger. Ich denke man kann das Ding schon noch "retten" (Pins etwas massiver, Steckergehäuse anders ausgestalten für mehr halt und andere Platzierung auf den Boards). Und bis dahin oder bis zu einer ganz anderen Lösung muss man eben recht vorsichtig sein. Wie mehrfach geschrieben: jetzt seit über einem Jahr im Einsatz und kein Problem damit gehabt. Vermutlich aber auch weil ich am Anfang echt Respekt hatte und immer peinlichst auf alles geachtet hatte.
Man muss da halt nix retten sondern einfach korrekt stecken und ausreichend große Gehäuse nutzen um dem Kabel genügend Raum zu geben. Und wie auch schon im anderen Thread (oder sind es 4 andere Threads inzwischen?) geschrieben, vielleicht einfach Drittanbieterprodukte vermeiden und entweder die NVidia Adapter oder ein Kabel des Netzteilherstellers nutzen. Romans Video mag vordergründig neutral wirken, der Header und das Thumbnail machen aber klar, worum es ihm geht. Hat halt mit seinem Produkt auch in Stake in der Sache. Aber gut, bei den ganzen Fehlinformationen hier zum Schuldigen schreiben die meisten wohl einfach nach ihrer Agenda.
Naja, offensichtlich kriegt das ja nicht jeder hin. Das halte ich dann für optimierungsbedürftig bei einem Massenartikel. Aber vielleicht hätte man den Stecker einfach erstmal bei günstigeren Grafikkarten einführen sollen, damit man beim harten Lernen in der Realität nicht so viel Kohle auf einmal in den Sand setzt.
Die Aussage dazu gab es bei Igorslab in einem Video von Igor.
Ob man diesen Aussagen noch trauen kann weiß man halt nicht :d
Da Igor aber eher pro AMD ist und die Aussage zugunsten für Nvidia ausfiel würde ich persönlich das mal glauben...,
Igor ist allgemein pro AMD/Alphacool und Bequiet. Mal einfach für die die es interessiert.
Nach eigenen einschätzen nach, weil ich viel Inhalt von dem angeschaut oder gelesen hatte.
Aktuell meide ich seinen Kanal.
Hast Du das Video vollständig gesehen? Er spricht ja an, das es bei Verwendung des Wireview auch Probleme geben kann. Seiner Meinung nach ganz einfach deshalb weil der 12Pin-Stecker/Buchse auf Kante genäht ist.
@X Cellence
Beim Core und der 4090 FE konnte ich den Wireview nicht verwenden, da ich ihn nicht vollständig aufstecken konnte.
Roman erwähnte in seinem Video auch noch einen einzigen Schadensfall, bei dem der User wegen dem Wasserkühler den Wireview nicht vollständig aufstecken konnte.
Kann man, Igor verfügt über umfangreiche Kontakte zur Industrie, spricht ein Duzen Sprachen und mit ein wenig Glück hält er die Lösung bereits in seinen Händen.
Nvidia wollte aber einen kompakten Stecker, um die kompakten Platinen umsetzen zu können.
Und generell finde ich die Lösung bedeutend angenehmer, hinsichtlich Kabelmanagement und auch Optik. Die Sicherheit muss natürlich gegeben sein!
Aber auch sich im kommerziellen Bereich ist es sicherlich angenehmer, wenn pro GPU lediglich ein Stecken erforderlich ist.
Im Prinzip weiß man doch was als Nächstes kommt, ein "12V-2×6" Stecker ist doch bereits durch.
Es werden nur die Sense Pins gekürzt bzw. neue Karten haben das schon.
Besser wäre ein größerer Anschluss wo die Pins etwas dicker wären als aktuell, weil Probleme gibt es nicht nur durch das nicht tief genug eingesteckten Stecker.
Trotz des komplett eingesteckten Steckers hat man bei Roman seinem Video gesehen als das Kabel bewegt wurde Probleme mit der Stromverbindung gab was man anhand der LED der Strix gesehen hat die
dann anfing zu leuchten was darauf schließt , dass es Probleme mit der Verbindung gibt. Was stabileres wäre zu empfehlen .
Es sollte ein komplett neuer Anschluss gemacht werden für die next Gen. Dann muss man halt wieder ein Kabel kaufen.
Dann hat Nvidia bei 3 Generation drei neue Anschlüsse gemacht , aber besser wäre es. Meine güte die Karte kostet ein haufen Kohle und die 5090 wird eher teurer.
Da invenstiere ich lieber nochmal 20-30€ für ein neues NT Kabel.
Wobei es für mich etwas so wirkt, als wäre da ein Spalt:
Bei meinem CableMod V1.0 ists es so gewesen, das man diesen trotz eingerasteter Nase ein gutes Stück aus der Buchse ziehen konnte, da zu viel Spiel vorhanden in der Verrastung gewesen ist.
Ich hab dann neben dem Adapter auch noch ein NT-Kabel (be quiet oder Corsair) und da ist auch Spiel vorhanden gewesen. Aber geringer als beim Cablemod-Adapter.
Beim beiliegenden nVidia-Adapter, den ich mir dann noch zum Vergleich angesehen habe, lag gar kein Spiel vor. Da ists dann eher das Problem gewesen, das der Haltearm nicht vollständig über die Nase gerutscht gewesen ist, wenn man nicht weit genug aufgesteckt hat.
Ok kann natürlich sein. Habe bei meinem Corsair Kabel kein Spiel.
Das sitzt optimal. Habe auch nur eines bestellt gehabt. War eh schon glück vor release dieses zu bekommen.
Bei dem Nvidia Adapter war auch alles ok bei mir. Allerdings habe ich das Kabel nicht mehr.
Mich stört bei diesem Adapter, dass dort für die 12 Pins 8 Kabel angelötet sind.
Hätte immer die Sorge , wenn eines der Lötstellen sich irgendwie löst es zu einem schmoren kommt.
Man kann da halt nicht reinschauen wie es verarbeitet ist . Daher von anfang an mir das Corsair Kabel deutlich lieber.
Ich persönlich schätze Igors Arbeit sehr.
Igorslab schreibt lediglich, dass man zwar zunächst tatsächlich die Verwendung bereits existierender EPS-Anschlüssen abgewogen hat, das Vorhaben aber dann doch aufgrund des "Spieltriebs" seitens Nvidia verworfen hat und eine andere Lösung wollte:
"Warum man diesen Stecker perspektivisch dann doch verworfen hat, liegt sicher auch in gewissem Maße am Spieltrieb des Grafikkartenherstellers und wahrscheinlich auch an der Schwierigkeit, diesen Steckverbinder ohne Lizenzprobleme einfach umzufrickeln."
Das widerspricht nicht meinen Aussagen. PCI-SIG-Dokumente sind nicht frei zugänglich, ich selbst möchte dazu auch nichts posten. Aber wer Interesse hat und mal nach den entsprechenden Schlagwörtern googelt (12VHPWR Nvidia Dell), sollte auf Auszüge bzw. Screenshots daraus zu dem Thema stoßen.
Ich lasse mich aber auch wirklich gerne korrigieren. Aber eben mit belegbaren Fakten und nicht mittels Meinungen. Es geht mir auch nicht darum, Nvidia ungerechterweise zu bashen. Das bekommt man in der heutigen Forenkultur von Fanboys ja schnell unterstellt. Ich nutze übrigens seit meinem Umstieg von meiner damaligen Voodoo II auf Riva TNT privat ausschließlich Nvidia-Karten. Man könnte mich daher durchaus als Fan bezeichnen. Als Endnutzer nehme ich mir aber dennoch die Freiheit, Kritik zu üben wo nötig.
Ich hatte es auch, dass mein Rechner einfach ausgegangen ist. Ich hatte es damals auf eine nicht ausreichend starke Pumpe geschoben, da es passiert ist, nachdem ich den Mora420 mit in den Kreislauf aufgenommen habe. Nach Romans Video, war es vermutlich ein nicht richtig sitzendes Kabel (Ebenfalls Corsair). Nachdem die Pumpe umgebaut war, ging es wieder. Liegt wohl da dran, dass der Stecker dann wieder richtig saß. Temps hatten damals nämlich gepasst und ich konnte mir nicht erklären, wieso das Ding einfach aus geht. Würde daher vorsichtig bestätigen, dass ich exakt das Verhalten auch schon hatte.
Genau das sage ich doch. Sein Produkt ist halt auch "in Gefahr" durch die Beschaffenheit des Steckers. Aber alle die damit meinten Geld verdienen zu müssen, wie eben Roman oder Cablemod wussten das vorher und brauchen jetzt nicht den sterbenden Schwan mimen.
Die WireView Versionen mit 12VHPWR sind mMn nicht brauchbar. Da sollte man sich lieber die 3x8pin Version kaufen, und das mit einem vernünftigen 12VHPWR-3x8pin NT-Kabel an die Grafikkarte anschließen.
ich habe meine matrix mit dem wireview 12vhpwr-3x8pin plus strimer am ax1600i angeschlossen, bis jetzt ohne probs :)
Ich wünsche dir das es auch so bleibt. Nur dem Glauben daran fehlt es mir.
Spätestens wenn der Spannungsabfall bei Last größer wird, sollte man die Kontakte mal einer Sichtprüfung unterziehen.
ne 4090 am anschlag bei unter 300w. das schafft nur ubisoft :lol:
1a spaghetticode
Aber schade, dass man keine Software nutzen kann…
Wer sein gesamtes System extern „durchmessen“ will, für den ist evtl. „BENCHLAB“ das Richtige. Ist brandneu…
1a spaghetticode
Mit DLSS nehme ich an
Was alle nur für ein Problem haben kauft euch das Kabel : https://www.moddiy.com/products/ATX...-12VHPWR-Native-16-Pin-Gen-5-Power-Cable.html
bei meiner ersten 4090 habe ich das genutzt ohne probleme damals aber als 16pin auf 3x8pin und jetzt habe ich es direkt gekauft wo ich mein BeQuiet 12m verbaut habe mit dem 16pin anschluß und der hersteller hat bis heute NICHT 1 RMA!!!!!! gehabt mit ihren kabeln oder steckern
Das kannst du nicht wissen ob der Hersteller ein RMA Fall dazu hatte ^^. Zumindest wahrscheinlich nicht so viel wie bei cable mod.
Für Benchmarks oder für den Dauerbetrieb hätte mir das Benchlab im Stromkreis auch zu viele Kontaktübergänge. Da würde ich auch erstmal die Header auf dem Benchlab auslöten, und gegen angelötete SteckerKabel tauschen. um annähernd gleiche Kontaktwiderstände wie mit einem nativen Kabel zu schaffen.
Benchen ist ja keine 24/7-Sache…
Natürlich kann man auch sein NT öffnen und dort Strippen anlöten und das Gleiche nochmal an der 4090 machen :d
BTW:
Hab nur den „kleinen Bruder“ (PMD-USB) mit 10x 8-PIN. Hatte ich aber eine zeitlang die ganze Zeit dran. Als alter Energie-Elektroniker hatte ich da keine Bedenken
Was bringt ein Messgerät beim Benchen, wenn nicht gleiche Bedingungen wie ohne dem Messgerät herrschen?
Ähnliche Themen
