[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mit DLSS nehme ich an
nein das spiel hat kein upscaler. und selbst wenn würde das nichts ändern. das spiel kann die karte nicht komplett nutzen, das ist das problem. da liegen 200w brach
Meiner hat einen Anschluss, aber wofür der ist keine Ahnnung
Wie am EVC2...
Nur, dass das EVC2 noch eine USB-C-Buchse hat, um an den PC anzuschließen
Evtl. wäre es möglich, das Wireview über ein Adapter-Kabel per USB anzuschließen - k.A.
So, zurück aus dem Urlaub und die Hardware entsprechend umgebaut.
Meine SuprimX hat es ja gefickt, da der Nvidia-HPWR Adpater nach ca. einem Jahr abgefackelt ist.
Der PC lief noch mit Onboard GPU, was ok war, so konnte ich wenigstens noch ein bisschen surfen und die RMA vorbereiten.
Ich bin von der PNY sehr positiv überrascht, konnte diese noch vor Weihnachten für 1750 Euro schießen, aktuell liegt der Preis bei ~2250 Euro.
Die PNY macht was sie soll und das gut, hat zwar nur 17+3 Phasen und das Powerlimit bei 450 Watt+2% viel weniger als die SuprimX. Aber oh Wunder, die GPU ist extrem leise, kein Spulenfiepen und der Lüfter dreht dezent seine Runden. Zero Fan gibt es auch, allerdings dreht der Lüfter ca. 5 Minuten nach Last noch auf 30%, für mich nicht störend. Ich finde das sogar gut, es wird eben nochmal mehr Wärme von der Karte abtransportiert.
Mit Avatar und aktivierten Max Einstellungen pendelt sich die Karte bei 2740 Mhz ein, bei eben 420-450 Watt.
Bei anderen, weniger anspruchsvollen Spielen wie Anno boostet sie auf 2780 Mhz.
OC habe ich noch nicht ausprobiert, werde ich auch nicht tun, da es für mich wenig Sinn macht und ich erstmal wieder froh bin, dass alles wieder funktioniert.
Die Karte bleibt kühl, in meinem kleinen ATX Gehäuse werden bei geschlossenem Gehäuse max 64 Grad erreicht, bei geöffnetem Gehäuse max 60 Grad.
Die SuprimX kam in meinem geschlossenen Gehäuse schon mal auf 72 Grad. Im Idle zieht sie bei 4k+HDR@165 Hz ihre 21 Watt. Auch hier war die SuprimX durstiger und gönnte sich 30-40 Watt.
Zudem ist die ganze Kühlerkonstruktion wesentlich leichter, was die Karte weniger durchhängen lässt und zu guter Letzt ist die Karte auch noch schmal, was wegen des HPWR-Steckers gut ist, wenn das Gehäuse geschlossen ist, so biegt sich das Kabel auch nicht unnötig durch.
Ich habe auch vorsichtshalber ein neues Netzteil mit HPWR Stecker eingebaut, wollte eigentlich wieder ein Seasonic, da das Netzteil einen guten Job machte und es auch nach Kabelbrand soweit noch lief, aber es hatte einen PCIE Anschluss verkohlt, war mir dann doch zu heikel. Löblich ist Seasonic dennoch, RMA wird anstandslos akzeptiert, ich sehe die Schuld auch nicht beim Netzteilhersteller, dennoch sehr kulant, sollte mal was passieren.
Habe mich dennoch nach langen Jahren wieder für ein FSP entschieden, da die Tests für das Titanium Netzteil mit ATX 5.0 extrem gut ausfielen und dieses auch preislich mit ~250 Euro im Rahmen war. Ein vergleichbares Seasonic hätte 350 Euro gekostet. Das FSP-Netzteil selbst ist sehr leise und wirkt sehr gut verarbeitet.
Ein paar Bilder:
Links zu den Tests:
Netzteil--> https://www.anandtech.com/show/21148/the-fsp-hydro-ti-pro-1000w-psu-review
PNY --> https://www.tomshardware.com/reviews/pny-rtx-4090-xlr8-rgb-review
Na dann: pannenfreie Zeit.
Vielen Dank :) Wobei ich nach dem Video von Roman doch noch etwas besorgt bin.
Die Stecker sind scheiße und bei geschlossenem Gehäuse und der neuen Generation von Spielen jetzt so wie Avatar,
die ja unter 4K immer an die 450 Watt saugen und das dann auch noch für mehrere Stunden, ich weiß nicht....
Der Innenraum wird heiß, das Kabel wird von innen zusätzlich heiß und die Kühler der Karten blasen die Luft noch nach außen und penetrieren zusätzlich das Kabel.
Ich denke, da wird es sicher noch mehr Fälle geben.
Und nicht jede Karte ist so schmal wie die PNY, sobald das Gehäuse zu ist, wird das Kabel durch die Seitenscheibe gebogen und dann hat man solche Klopper wie die Gigabyte GeForce RTX 4090 AERO, in welches Gehäuse will man die dann einbauen? Dann nur mit Riser und das ist auch iwie Mist wegen der Signalqualität zusätzlich dann eben Big-Tower. Oder Umbau auf Wasser und das Kabel dann mit nem extra Gehäuse Fan anblasen lassen ^^
Also die Gigabyte Aero wie auch Asus Strix passten z.B. wunderbar ins H7 Flow ohne dass das Kabel bedenklich geknickt werden musste. Mit einer 4090 würde ich mich einfach vom Gedanken des kompakten Gehäuses verabschieden.
@EleCtricStream Ich weiß schon was du meinst. Meine GB Gaming OC macht ja auch keinen schlanken Fuß. Im Fractal Torrent geht es sich gerade so aus. Vorteil von so einem Durchlüftungscase (und einer der Gründe warum ich es gekauft habe) ist, dass in dem Bereich der Grafikkarte ordentlich Durchzug herrscht. Von Vorne die Lüfter vom Radiator, von unten 3x 14 cm. Und bei mir ist das nicht auf Silentbetrieb. Mit dem gut sitzenden Seasonic/Asus Kabel habe ich bis jetzt keine Probleme gehabt.
Also mach dir nicht soviel Kopf. Wird schon halten diesmal.
Das FSP NT habe ich mir auch geholt. Ist wirklich super leise, weshalb ich den Lüfter auch laufen lasse und nicht auf semipassiv stelle. Aber das 12VHPWR-Kabel vom NT ging so straff rein, dass ich kein Einrasten wahrnehmen konnte. Das war mir nicht ganz geheuer, weshalb ich wieder mein Adpterkabel mit 4x8Pin angesteckt habe. Das rastet richtig ein und hat jetzt schon ein halbes Jahr mit dem alten NT funktioniert. Da hätte ich eigentlich auch mein gutes altes Enermax Revelution 85+ 1050W behalten können. :drool: Gut das neue NT ist effizienter, aber gebraucht hätte ich es nicht.
Der ausschlaggebende Grund für mich war das Kabel, das scheint schon ziemlich solide zu sein, beim Einbau lag das Gehäuse auf der Seite und ich hab das Kabel von oben auf die Karte gesteckt, das ging schon etwas schwer klickte aber dann letztendlich. Stand auch wie ein Depp im Bad mit nem Föhn und hab das Kabel dann auch minimal gebogen, hab mich da an Seasonics Tipp gehalten, nach 3,5 cm leicht nach unten knicken
Von dem Adapter halte ich gar nix mehr xD
Das NT selbst ist wohl mit das Beste, was man in der Watt-Klasse aktuell kaufen kann, haben ist besser als brauchen :d
Ja FSP soll wohl auch ziemlich gut sein.
Mit Corsair bin ich aktuell auch sehr zufrieden . Die hatten auch die letzten Jahre immer wieder gute Nts.
Damals zuletzt ein DPP11 war ich selbst mit Bequiet sehr zufrieden, aber mittlerweile würde ich kein Highend oder für Highend Systeme Nts von denen kaufen. Nur welche für Budget Systeme.
Ich meine nicht den originalen Adapter. Denn habe ich nie angefasst. Ich habe mir so einen Adapter mit einzelnen Kabeln gekauft, welcher flexibler ist, als der original Adapter mit seinen verbundenen Kabeln. Dadurch kann man das Kabel besser biegen.
Vielleicht starte ich noch einmal einen Versuch und verbaue das originale Kabel vom NT.
Ah ja, was ich noch erwähnen wollte, bei MSI gab es mit der SuprimX und in Verbindung mit dem MSI Board im MSI Center die APP, Frozr-AI.
Diese synchronisierte die GPU-Fans mit den Case Fans. War in dem Fall gut, weil meine CPU bzw. die AIO komplett andere Kühlparameter aufweist.
Leider funktioniert dieses Tool nur in Verbindung mit MSI Karten :(
Habe jetzt testweise den Argus Monitor am Laufen, scheint auf den ersten Blick eine ziemlich mächtige Fan-Software zu sein.
Konnte auch damit die Case Fans mit der GPU syncen, bzw. eine Individuelle Lüfterkurve bzw. ein Start-Profil festlegen.
Auch werden sämtliche Fan-Controller und auch der RGB-Bums anstandslos erkannt, beißt sich auch nicht mit der Icue Software, da man diese Schnittstelle auch deaktivieren kann.
Das Programm kostet nach dem 30 Tage Test, 30 Dollar
Wie macht ihr das?
aquaero. Durch Custum Wakü ist da nicht viel zu machen. Ein Kanal für die Pumpe, zweiter Kanal für 4x140er auf dem Radi (laufen immer), dritter Kanal 5x140er auf dem Radi (Wassertemp-abh. zugeschalten) und dann noch am vierten Kanal 3x120er Gehäuselüfter um etwas Luftzug im Gehäuse zu haben.
Das gute daran ist, dass ich das einmal eingestellt habe und jetzt schon quasi beim dritten PC so nutze. Das Profil ist ja im aquaero gespeichert.
@EleCtricStream
Viel Spaß mit der PNY 👍🏼
Deckt sich der Erfahrung meiner PNY.
Was aber definitiv anders ist:
Die Lüfter meiner Karte laufen keine 5 Minuten nach.
Magst du mal in GPU-Z ein Screenshot vom Bios machen?
Schon UV getestet? Da ist meine nicht so gut wie andere. Brauche für 2740mhz 0.975v
Edit: Thema Lufterkurven: FanControl 👍🏼
Weiß nicht ob du dort auch Synchron schalten kannst aber ist ne Top Software für verschiedene Scenarien.
Dort kannst du zum Beispiel auswerten ob die Case Fans behandelt werden sollen wenn GPU Temp über X oder CPU Temp über X.
@EleCtricStream
Sobald ich wieder an meinem Computer bin, poste ich dir den screenshot.
Laufen die Lüfter an der GPU bei dir gar nicht nach und gehen sofort auf Null?
Ich dachte zuerst, dass es an der Temperatur der Karte liegt, aber das ist nicht der Fall.
UV habe ich bei der Karte noch nicht eingestellt, weiß auch nicht, ob ich mir da die Mühe machen soll. Mit der SuprimX habe ich zwei Wochen lang herumgedoktert, sie lief mit 2620@0,89 mV.
Was zunächst stabil erschien, war es dann bei nem anderen Spiel wieder doch nicht usw.
Dafür bekam ich zumindest ein Achievement im 3D Mark xD
Mit Max Takt habe ich es noch nicht getestet, Power-Limit habe ich testweise auf 85 Prozent gestellt, da bleibt die Karte bei Avatar knapp unter 400 Watt. Switched aber ziemlich stark von 2600 bis auf 2740 Mhz.
Ich weiß nicht, ob das auf Dauer so gut für die VRMs ist... Jedenfalls laufen die Shaderdomains syncron, wenn man das PT senkt, beim UV weit unter der max Taktung eben nicht.
Bei dir spielt es keine Rolle, da dein Takt ja schon in der Max-Taktstufe ist.
Bzgl. Programm, sieht ganz vielversprechend aus, wenn sich die Case-Fan Kurve anhand der GPU Temp anpassen lässt, wäre das genau das was ich brauche.
Bei 58° Grad GPU Temp hab ich die Anwendung geschlossen.
Da liefen die Lüfter mit 30%.
Sobald die GPU Temp 32° erreichte gingen die Lüfter aus. Das hat ca 2 Minuten gedauert.
Weiß nicht ob die Karten nach GPU oder Hotspot gehen. Hab auf den Hotspot +10°
Hier der Screenshot: Ich beobachte gerade mal ob die Lüfter bei 32 Grad ausgehen.
Also die 32 Grad scheinen es nicht zu sein, Hotspot ist auch +10 bei mir.
Wie macht ihr das?
Corsair icue commander core xt. Dazu passende RGB Adapter aus China, da Corsair hier ja einen eigenen Stecker hat..... Funktioniert einwandfrei und zusammen mit einem beliebigen tempsensor fürs Wasser ne gute Geschichte
Es sollen 4080, 4070 Ti und 4070 Super Karten kommen. Als 4090 Besitzer vollkommen uninteressant.
Hier auch mal von meiner PNY XLR8 4090 (non OC Variante) ein GPU-Z Screenshot
Interessant das wir verschiedene Bios Versionen haben.
Meine Karte geht auch nachdem zocken in 2-3 Minuten auf 0rpm. Im Multimonitor Betrieb zieht die Karte laut Gforce Experience ~11W. Im Single Monitor 6W.
Hatte mal mit der KFA2 4090 das "Problem" das die Karte Anfangs auch nicht im Multimonitor Betrieb auf 0rpm gehen wollte, da sie dabei laut Gforce Experience an der 30W Grenze kratzte. Glaub ist eines der beiden UND Verknüpfungen (Watt & temp) das die 4090 auf 0 rpm geht. Nach paar Neustarts und DisplayPort rein und raus, gings dann auf einmal.
Die scheint ein besseres Idle Verhalten zu haben als meine. Gut gegenüber der SuprimX dennoch sparsamer aber 11W im Multimonitor ist stark, kannst du uns das Bios speichern und zur Verfügung stellen? Bzw. es gibt bei Techpower-Up nur die Version: https://www.techpowerup.com/vgabios...&version=&interface=&memType=&memSize=&since=
bzw. ich kann euch gerne auch mein Bios zu Verfügung stellen, scheint auch das aktuellste zu sein.. Hab nachgedacht, bei ner 4K@165hz + HDR zieht es vielleicht auch mehr als wie unter 2x1440p z.b welche Auflösung nutzt du?
Habs per GPU-Z versucht hochzuladen:
Keine Ahnung warum Techpowerup meint, das das file schon da wäre.
Vielleicht sind die errechnte Hash Werte gleich ... ?
Habe das rom hier mal hoch geladen:
Und danke für dein Angebot mit dem Bios file, aber ich passe. Ist mir zu heikel das da was schief geht.
Edit:
Hab den Grund für den "Fehler" für den anscheinenden upload gefunden. Der Post hat mich darauf gebracht:
Auf der VGA Bios Übersichtsseite, wie folgt auswählen:
Vielen Dank, top :-)(y)
Ähnliche Themen
