[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nr200 mit 4090fe
Temps absolut i. O.
Müsste heut Abend nochmal schauen wie warm des ding wird aber nachdem alles leise und fast unhörbar ist kanns nicht so schlimm sein
Die Temps bei dem P-ATX sind ziemlich gut, da die Karte quasi für sich liegt und die Luft rein zeiht und direkt wieder aus pustet. Aber genaue Werte habe ich nicht.
Hab mich damit noch nicht richtig befasst...
Würde Wakü in so einem kleinen Ding überhaupt Sinn machen? Oder besser alles bei Luft belassen?
Nur wenn du einen Mora an die Wand dübelst.
Bei den effizienten amd cpus geht beides. Ich hatte mit der standard wakü und dem 7950x3d gute Temperaturen. Wichtiger ist die Belüftung der 4090 deshalb hatte ich das Glas demontiert um ein sehr leises system zu bekommen. Es gibt gelochtes blech oder gelochtes Plexiglas als Ersatz. Es ist sehr wichtig sich vorab zu informieren welche gpu Länge bzw Breite rein passt.
Schon klar... :d
QD3-Pärchen hätte ich genug, aber sollte schon eigenständig sein
Glas ist zwar nett, sieht aber bei der "HW-Drängelei" nicht gut aus, finde ich. Und hat null Löcher
Großzügig gelochtetes Blech oder Gitter wäre für die GPU-Temp sinnvoller
Würde ja gerne 2-3 ITX-Cases testen und das Beste behalten, aber das artet in Stress aus. Zumal ich FAG ungerne nutze :rolleyes2:
gibt es da einen unterschied?
Ist "standalone" und "nur" ~200MB groß. Genaue Unterschiede zu Armoury Crate weiß ich jedoch nicht, da ich Armoury Crate noch nie verwendet habe.
Ich hol mir demnächst den nvidia ai Desktop für ca 40000 :)
Ja die hat auch 15 statt 18 Phasen.
Ist ne billig Version womit Asus Geld sparen will. So würde ich das mal sehen. Habe auch das Gefühl , dass die nächste Gen. nicht mehr so geil von den Kühlern her wird.
Einzige was sicher bleibt ist mit Sicherheit das Spulenfiepen ^^.
Die hat ein komplett abweichendes PCB, genau wie die Strix LC.
müsste das 3090ti-Design sein, hatte ich, glaub ich, mal gelesen (TUF OG)
Die wollte ich mir übrigens eine Zeit lang holen, wegen ITX Case, aber die FE war dann doch die naheliegendere Variante
Igor ist sicher dran... investigativ und hoch wissenschaftlich. :coffee2:
Bitteschön :d
Uff! Sieht super aus. War aber bestimmt ganz schön friemelig, oder? Wurstfinger sollte man nicht gerade haben, wenn man sowas bauen möchte? :haha:
Danke Dir. Find ich auch, schon schnieke das Ding.
Bis zum Stecker reinflanken war alles okay.
Aber ab dem Stecker war es eine reine Fluchorgie ^^
Hatte danach dann auch erstmal keinen weiteren Bedarf an neuem SFX :fresse:
Nur das NR200P Max würde mich noch reizen, weils da relativ leicht ist, wenn man sich an die Maße hält.
Temperaturmäßig und lautstärketechnisch ist das auch alles sehr gut. Bekommt ja auch überall Luft.
Würglich? :cry:
Und ich dachte, ich könnte mir endlich eine pixel-schubsende Wärmepumpe einbauen lassen :fresse:
amwjoy0ie3661-jpg.1262435
Ja das nr200p max ist easy und auch relativ günstig abunzu im Angebot.
cablemod will ja ein Bild haben - hast Du mit dem Hammer drauf gekloppt und das fotografiert und bei cablemod im Formular hochgeladen?
Jep genauso hab ich es gemacht
Die 4090 TUF non OC ist heute angekommen.
Ist wirklich riesig, super leise, super kühl, fiept nur n bisschen. 600W Powerlimit ist auswählbar.
Einfach mehr als doppelte Leistung zur 3080 10G, geile Karte :d
Da wirst du ziemlich sicher davon ausgehen können. Denn soweit ich das verstanden habe waren die Kühler die wir für die 4090 haben dem Umstand geschuldet, dass die ursprünglichen GPUs eigentlich hätten heißer laufen müssen. Irgendwas wurde in letzter Sekunde geändert (Fertigungsverfahren und/oder nicht mehr bei Samsung irgendwas war da...) Da wohl die Kühler alle schon fertig entwickelt und in Produktion waren, war hier eine Umstellung nicht realistisch.
Sowas wird uns wohl bei der nächsten Generation nicht mehr treffen. Schade eigentlich, wenn man bedenkt wie gut diese Kühler sind. Sicher, sie sind damit auch schwer wie ein Gullideckel und die Karten müssen unbedingt gestützt werden, wenn sie horizontal betrieben werden. Aber naja, irgendwas ist ja immer.
Ich denke diese Monster werden in Zukunft einen gewissen nostalgischen Kultstatus bekommen.
Kultstatus glaube ich eher nicht weil zukünftige Top Karten sicher genau so groß sein werden. Bei der 5090 werden wir bestimmt 500W TDP oder so sehen, sprich der Kühler wird nicht wieder kleiner werden. Ist zumindest meine Vermutung.
jemand von euch ne idee waurm eine 4080super von gigabyte mal auf anschlag rennt und mal im voltage limit hängt?
er hat ne zweite 4080super da(asus tuf) und die rennt einwandfrei.
nur die gigabyte scheint wohl mal bei 233w und mal bei 300w+ zu laufen
mal voltage limit, mal power limit
Kennt sich jmd mit "Fan Control" (oder bei Github hier) aus? (die ausgelesenen Temp-Sensoren mit den gewünschten Fans zu verknüpfen) - edit: ich glaub, ich hab´s...
Wusste zb garnicht, dass man die beiden Lüfter an der Strix/TUF separat steuern kann. Wahlweise auch komplett aus (glaube Afterburner kann´s nicht)
Habs mir grad gezogen, weil ich von von der Bloatware "AI Suite 3" (für FanExpert) los will. Das Ding installiert zig Server, die irgendwohin tel. wollen :rolleyes2:
Fan Control kann die Lüfter der Inno3D Karten nicht anders ansteuern als der Afterburner. Wenn die Firmware 30% Drehzahl vorgibt, drehen die Lüfter hoch, auch wenn in Fan Control der Override Modus aktiv ist. Das gleiche gilt für die anderen Firmware Vorgaben ab gewissen Temperaturschwellen.
Ähnliche Themen
