[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Moin. Ich könnte bei mir in der Gegend ne MSI Gaming X Slim 4090ig günstig bekommen, doch leider finde ich keinerlei Test oder so zu der Karte. Hat hier jemand dieses Modell am Start und kann was dazu sagen. Danke schonmal.
Fan Control kann die Lüfter der Inno3D Karten nicht anders ansteuern als der Afterburner. Wenn die Firmware 30% Drehzahl vorgibt, drehen die Lüfter hoch, auch wenn in Fan Control der Override Modus aktiv ist. Das gleiche gilt für die anderen Firmware Vorgaben ab gewissen Temperaturschwellen.
Ja, hab mich verguckt...
Einzig separates steuern kann AB nicht - FC schon
open rgb. (TUF)
programm starten (sofern für die tuf gepatcht) , rgb auf schwarz und 0% helligkeit, speichern, schließen,
fertig :d
Hoffe das es irgendwann auch für Windows gibt. Derzeit wird nur meine G502 mouse unterstützt von der Windows RGB Steuerung.
meinst du open rgb? das tool ist für windows und mit ein paar plugins gehen da wohl schon einige geräte mit zu steuern.
open rgb. (TUF)
fertig
:d
Modus "off" reicht völlig ;)
Funktioniert 1A und ist mit 26MB ca. 800MB kleiner als Armoury Crate :fresse:
Klasse finde ich auch, dass die Einstellungen Neustart-/Reset- und sogar Power-Off-Fest sind (gerade getestet)
Man kann nach einmal "Aus" das Tool quasi löschen :d
Jetzt noch integrierte G.Skill-Module...
Aber k.A. warum das G915 zwei mal drin ist (wurde so gescannt)
Ich hab mal eine Frage: Wenn Ihr Euch den Screenshot anseht, dann seht Ihr dass der Score mit der Karte mit den höheren Taktraten weit niedriger ist. Auch der Prozesser taktet mit 100MHz mehr.
Wie ist das zu erklären? Der höhere Score ist von einer Strix, der niedrigere von einer Gigabyte Aero. Ansonsten ist das System zu 100% identisch. Bei der Strix war das der Standard Boost, bei der Aero der maximal mögliche Takt ohne das PT anzuheben.
Bei win 11 Einstellungen gibt es unter personalisierung die Option Beleuchtung und da lässt sich RGB steuern von Geräten die unterstützt werden. Das ist mittlerweile in win 11 integriert
Es wurden zwei versch. Treiber verwendet. Kann, muss aber nicht der Grund sein
Grund kann auch ein Update in Windows sein. Ich meine auch, dass die Strix schärfere VMem-Timings verwendet!?
Zum Thema effektiver Takt. Jetzt hab ich natürlich die Strix nicht mehr. Könnte jemand mit einer Strix einmal einen Timespy Run auf 2830MHz / 24000MHz (gesetzter Takt) auf 100% PT machen und mir den avg effektiven Takt nennen? Das wäre cool.
Ja, der letzte Strix Score ist von Sommer 23, da gab es sicherlich einige Updates seither. Aber 1.000 Graphikpunkte weniger bei 100MHz mehr GPU Takt find ich schon heftig. Das liegt nicht nur an Windows.
Ist es die da ... :sneaky:
Willst eine 1600€ Karte ohne Garantieanspruch ? Ich würde mal nach Rechnung und Abtretung fragen.
Kann auch am Windows liegen, da gibt es soviele Faktoren.
Ja, leider...
Ich benche zwar gerne, aber der Zeitaufwand ist enorm
War das oben Time Spy?
Da macht alleine die WIN10-Version was aus. Ob WIN10 oder WIN11 sowieso
Von den Treibern und Settings im BIOS rede ich noch nicht mal
Time Spy...
links WIN11 - rechts WIN10
Je nachdem auf welchen Score wert gelegt wird, nutze ich dies oder das
btw:
Je besser die Kühlung, desto näher gleichen sich "Core-Takt" und "Durchschnittliche Taktfrequenz" an. Im Idealfall sind beide gleich, wie hier zb in Speedway :)
Gib ja auch immo nicht viel neues zu Benchen, daher warten jetzt viele auf 3dMark Steel Nomad .....
Oder einfach nicht kaufen. Wer weiß von welchem LKW die Karte gefallen ist.
Mal im Ernst, bei solch hochpreisigen Artikeln gehört eine Rechnung und eine Abtretugserklärung dazu.
Hab ich mich auch gefragt, dass man bei so einer Karte keine Rechnung hat
Im Zweifel mal nach einem Bild mit der SN fragen. Mal schauen, ob der Verkäufer sich dann noch meldet :d
Hatte ich damals gemacht, als ich nach einer FE suchte. Also die Zeit, wo es KEINE FE zum Normalpreis gab. Alle meist doppelt so teuer :cry:
Da hab ich mir aus Frust den "Meldefinger blutig gedrückt", weil min. 80% der Anzeigen Scam waren :cautious:
Die Karte gibt es und eine Rechnung auf seine Firma, die aber scheinbar zur Abschreibung beim Steuerberater liegt :rolleyes2:
Ich bleib mal dran, ist ja gleich bei mir um die Ecke.
Wie sich da alle wieder (künstlich) bei CB im Forum aufregen und die 5090 wird nun btw für 3–3,5k prophezeit von den gleichen Leuten 🤣
Da im Dezember letzten Jahres leider meine KFA an dem bescheidenen 12VPHWR Stecker abgeraucht ist, war ich auf der Suche nach einer neuen 4090. Ich hatte mir 3 Modelle zur Auswahl bestellt. die MSI 4090 Gaming X Slim, Die PNY XLR8 und die Gigabyte AERO OC.
Die MSI ist deutlich kleiner wie die beiden anderen Karten, und trotzdem noch leise. Aber da die Karte wie alle MSI Dinger einfach den Idle-Verbrauch (bei einem 240 Hz Monitor und HDR nimmt sich das Ding zwischen 32-40 Watt :-() nicht im Griff hat reichte es schon nur im Netz zu surfen und die Karte startete dann immer mal wieder die Lüfter, sehr nervig, auch wenn das trotzdem noch als ok bezeichnet werden kann. Die Verarbeitung der Karte ist absolute Unterklasse, sowas habe ich bei einer 4090 noch nicht gesehen, die möchtegern RGB Beleuchtung mit dem vorgesetzten Plastikglas ist eigentlich nicht mehr zu unterbieten was die Wertigkeit angeht. Die Karte basiert auch auf dem billig PCB was bei den Ventus-Karten eingesetzt wird und hat mit der Gaming X oder einer Suprime nichts zu tun. Spulenfiepen hatte das Modell aber überhaupt nicht.
Die PNY ist eine erstaunliche Karte, liegt von der Größe in der Mitte zwischen Gaming X Slim und der Gigabyte, der Kühler ist unfassbar gut, die Lüfter sehr, sehr leise die Verarbeitungsqualität gut, wenn auch nicht sehr gut. Das PCB ist das Ref-Design was gerne als Minimum bezeichnet wird und sicherlich nicht zum übertakten gemacht wurde. Null Spulenfiepen, Lüfter bis knapp unter 1500RPM was sich viel anhört, aber tatsächlich sehr leise ist. Wenn man Avatar spielt was eigentlich immer 450 Watt bedeutet, bleibt die Karte sehr kühl 62° bei offenem Gehäuse und unter 70° im geschlossenen Gehäuse das ist hier eine Ansage. Wem die RGB Beleuchtung mit dem X zusagt und keine 4090 zum Übertakten sucht, das ist eine wirklich gelungene 4090 die ich empfehlen würde und auch von einem Freund von mir abgekauft wurde.
Die Gigabyte AERO ist dann hier geblieben. Von den 3 Karten ist sie die, die sich am wertigsten anfühlt, am besten aussieht (wie immer Geschmackssache) und für mich den besten Kompromiss aus Aussehen, Performance und Betriebsgeräusch darstellt. Nicht so leise und kühl wie die PNY, aber nah dran, 600 Watt Bios on Board wenn man der mal auf die Fre... geben will und mit Registrierung 4 Jahre Garantie, was vielleicht auch im WV mal eine Rolle spielen könnte. Einen Nachteil hat das Ding jedoch, war die KFA2 schon ein Ziegel, das Ding ist....... ja einfach riesig horizontal hat die nicht in das Case gepasst wenn ich die Klappe zumachen will, Vertikal-Mount von Lian Li hat es dann gerichtet.
So hoffe konnte Dir ein paar Entscheidungshilfen geben, wenn es nicht schon zu spät ist. Die MSI Gaming X Slim würde ich nur einbauen wenn es nichts anderes geben würde ;-).
Auch schon die Tage gemerkt, dass über den MindStar wieder mehrere RTX 4090 für um die 1.850 Euro angeboten wurden. Waren zwar die bekannten "günstigen" Hersteller bzw. Modelle, aber unter 1.900 Euro waren diese Karten die Wochen zuvor nicht erhältlich.
Ähnliche Themen
