[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
K.A. ob´s am aktuellen Treiber liegt oder an der neuen NV-App, aber es gibt massive Probleme mit VMware :rolleyes2:
Wie ich lesen musste, scheint die gesetzte "Max. Bildfrequenz" dafür verantwortlich zu sein, denn vor paar Wochen lief VMware noch einwandfrei
Bei "Programmeinstellungen" war VMware nicht mal aufgeführt. Musste es manuell hinzufügen und bei beiden Settings "Max. Bildfrequenz" auf AUS stellen. Scheint wieder zu laufen
edit:
Am NV-Overlay, der neuen NV-App scheints nicht zu liegen
Mit einem Treiber vom Dez. ist es sogar noch schlimmer. Oben konnte ich zumindest eine VM laufen lassen. Mit 546.33 geht nichts mehr
Dabei hab ich lange vor 546.33 auf 120FPS limitiert... :rolleyes2:
ja hab ich auch schon gelesen.
mehr wert als amazon, 20x mal mehr zuwachs als die gesamte commerzbank.
einfach nur irre
laut statista intel weniger wert als amd?
Jo, ist stark gestiegen in letzter Zeit, Server-/HPC-Gedöns…
Intel macht eine Achterbahnfahrt durch:
Juhu - die PSVR2 wird demnächst offiziell PC-fähig...😍
Wenn Apple nachzieht, raste ich aus... :oops:
"Jacke, wie Hose" (Jen-Hsun Huang und Tim Cook) sollten zusammenarbeiten :ROFLMAO:
Na super. Habe meine vor einigen Monaten verkauft, weil ich kaum zum Zocken an die Playstation gekommen bin. Und den Rest hat die Motion Sickness besorgt (müde am Abend in VR-Welten eintauchen ist nicht ganz so optimal...).
"Na super", weil du den Verkauf bereust? :oops:
Kommt leider nicht jeder damit klar...
So lange VR2, wie vorm Moni sitzen, kann ich auch nicht. Hängt aber stark vom Game ab. Aber im Showroom von GT7 kann ich "ewig" abhängen
VR ist schon cool. Bereue den Verkauf allerdings nicht. Hätte allerdings die PSVR2 gerne mal mit der 4090 betrieben. Rein aus Neugier.
Und für die nächste Generation von Nvidia-Karten würde ich mir einen USB-C Anschluss wünschen, speziell auch für solches Equipment.
Apropos USB-C:
Vermutlich funktioniert die PSVR2 dann nur mit AMD-Grafikkarten. Oder irre ich hier?
An der 2080TI läuft sie ja schon "lange" mit "iVRy"
Wie es genau laufen soll, weiß ich grad nicht, aber hier steht...
Außerdem freuen wir uns, euch mitteilen zu können, dass wir derzeit die Möglichkeit für PS VR2-Spieler testen, auf zusätzliche Spiele auf dem PC zuzugreifen, um zusätzlich zu den über PS5 verfügbaren PS VR2-Titeln noch mehr Spielvielfalt zu bieten. Wir hoffen, diese Unterstützung im Jahr 2024 verfügbar machen zu können. Bleibt also auf dem Laufenden, um weitere Updates zu erhalten.
Ohne weitere Umschweife…
Wie ich das verstehe, bedeutet es, dass man die PS5 mit dem PC vernetzt, damit man PC-Spiele über die PS5 an der PSVR2 zocken kann. Also kein iVRy-Treiber, wie bei Steam
Im Nvidia Controlpanel gibt es die Einstellung zum ECC Speicher. Die Funktion ist mir grob bekannt und das diese für den Gamer nicht aktiviert werden sollte hab ich soweit auch gelesen. Möchte dies aber dennoch gerne mit euch diskutieren bzw. teilen. Mein System läuft meiner Ansicht gut, X670E Board, 7800X3D, 64 GB Ram, 4090 von Gainward. Mir gehts um das Thema Microstuttering, welches jeder wohl subjektiv wahrnimmt.
Durch ECC aktiv verliert man etwas an Videospeicher, der wird wohl für ECC reserviert. Hab aus Interesse dann mal 3DMark laufen lassen, dabei ist die 4090 mittels Afterburner Curve auf 2640 Mhz mit einem Powerlimit von 80%.
Hier mal das erste Ergebnis aber warum so wenig Punkte dazu komme ich später. ECC ist aktiviert:
Hier das Ergebnis wenn ECC deaktivert ist:
Round about also 500 Punkte weniger. Während dem 3DMark war das neue Feature RTX HDR aktiviert, hier noch das Ergebnis ohne RTX HDR.
RTX HDR kostet also ca. 2500 Punkte. Jetzt aber zu dem was mich interessiert und das ist ggf. subjektiv. Mit aktiviertem ECC ist mein persönliches empfinden, dass die Frametime stabiler ist und Microstuttering deutlich besser ist. Getestet aktuell bei Hell let Loose und No Mans Sky. Wie seht ihr das? Viel zum Thema ECC finde ich nicht.
Der Herkelmann schimpft. Der ist doch nicht mehr bei AMD, oder?
Aber ich kann mir schon vorstellen dass Nvidia die vorhandene Vormachtstellung ausnutzt. Das wirst aber nur durch alternative, mindestens genauso gute Produkte verhindern können.
Gibt ja aktuell zwei, AMD und Intel ....
Vor dem Hintergrund, dass AMD aktuell im GPU Bereich nicht mit halten kann, sind solche Anschuldigungen immer mit Vorsicht zu genießen.
Vom Herkelmann ist alles mit Vorsicht zu genießen. Als der noch BFG Boss war, war er immer eher für Nvidia als für AMD. Trotzdem finde ich die Story schon glaubhaft.
Wie heißt es so schön: wer einmal an der Macht ist neigt dazu alles zu tun damit das auch so bleibt. Und NVidia ist jetzt auch nicht bekannt dafür ihre Technologien mit anderen zu teilen. Im Gegenteil, sie versuch mit jeder neuen Technologie eher sich noch mehr zu festigen und es möglicher Konkurrenz noch schwerer zu machen.
Wie kann ich eigentlich den Nvidia RTX HDR Modus für Spiele einschalten ?
Habe nur die Option für Videos gefunden.
Würde gerne den Windows Auto HDR Mode gegenüber dem Nvidia RTX HDR vergleichen.
Klare Empfehlung für RTX HDR
Kostet aber auch Leistung
Du musst dir hier die App runterladen
Und das Spiel dann dort hinzufügen. Über das Overlay kannst du dann den HDR Effekt zuschalten und noch konfigurieren. Das geht on the fly.
Windows Auto HDR muss dafür aus sein.
Und ist es besser als Auto HDR? Bin mal interessiert es auszuprobieren aber so ne Beta App will ich irgendwie nicht unbedingt
Tja, wenn denn "RTX HDR" bei mir vorhanden wäre, da wo es im Netz bei den Screenshots angezeigt wird fehlt der Eintrag bei mir komplett (neuster Treiber). Das setzt nicht Win11 voraus, oder?
Edit: Japp, setzt Win11 voraus, dann eben nicht für mich. 🤷‍♂️
Es ist etwas besser, aber nicht "Welten". RTX HDR hat weniger banding in dunklen Bereichen und geht angeblich besser um mit black levels. Außerdem hast du bei RTX HDR 3 "sinnvolle" Regler, während es bei AutoHDR nur "Intensität" gibt, was in etwa einer Gesamthelligkeitsregelung entspricht.
RTX HDR hat aber auch Nachteile: Es funzt nicht mit +2 Monitoren an einer Graka und auch nicht mit DSR-Modi. Damit ist das Teil für mich sowieso unbrauchbar. Ich vermute mal, dass erst in 8-12 Monaten nachgebessert wird, wenn die 5090 rausgeballert wird.
Ansonsten die üblichen Schwächen von Pauschallösungen. Alles was weiß ist in SDR, wir mit Helligkeit raufgeknallt, egal ob Lichtquelle oder ein Blatt Papier.
RTX HDR muss in der Nvidia app akti4t werden in den globalen Einstellungen. Dann im Spiel mit Alt+Z kann man die HDR-Regler schieben bis das Bild passt.
Troloololooollllooo jetzt bin ich auch dran. (y)
Habe mich schon gewundert, wieso gestern die 95°C am Gehäuse des Steckers noch keine Probleme machen. Heute roch es komisch, dann mal nachgeschaut. Ging auch nicht sofort runter, musste mit einer Zange das Teil aushebeln (y)
Kann mir das aber nicht erkären im Endeffekt, da ich am PC seit Monaten nichts mehr gebastelt habe. Passiert ist es nun bei Guardians of the Galaxy bei ca. 400-500W ingame, meist 460-480W.
Anhang anzeigen 962400 Anhang anzeigen 962401
So, wer repariert noch das Teil außer Kriswichs? :o
So, die Sache wurde nun bearbeitet. Die Geschichte ging dann so weiter und hat etwas gedauert, habs selbst irgendwie nie eilig gehabt, nur die letzten Tage war ich etwas nervös ohne RTX 4090. Immerhin insgesamt gute 5 Wochen ohne 4090 durchgehalten. Das funzt sogar irgendwie, war selbst überrascht. :o
Habe also die Graka zu Kriswichs :o geschickt, bzw noch während die Graka bei Kriswichs :olag, mit CableMod ne Kulanz ausverhandelt. Zunächst wollte CM die Reparaturkosten nicht ersetzten mit der Begründung, dass die warranty von der Version 1.0 auf die Version 1.1 des Steckers übertragen wird. Dann ballert CM ne E-Mail über den offiziellen Rückruf der Stecker (v1.0 und v.1.1) raus in der auch erwähnt wird, dass die Reparaturkosten übernommen werden ohne genau zu erwähnen, welche Version des Steckers gemeint ist. Habe also CM nochmal angeschrieben und begründet, dass durch einen Wechsel auf v1.1 ein Schaden nicht zwangsläufig hätte verhindert werden können nach deren E-Mail über den Rückruf beider Versionen. Danach wurden beiden Augen zugedrückt und die Reparaturkosten werden per paypal erstattet.
Kriswichs :oselbst hat gute Arbeit geleistet, kann man nicht meckern. Besser gehts wirklich nicht, kann empfohlen werden. Es wurde von ihm nun die Verson H++ verbaut.
Hier seine Arbeit:
Ich werde den Stecker in v1.1 noch verwenden. Diesmal mit Temperatursensor auf 70°C Alarm (und der Shice von der aquaero 6 LT Lüftersteuerung schrillt wirklich extrem).
Ein Test von ca. 5min und 525W brachte schon mal ca. 64°C. :o (y)
Temperatursensor wurde auf die Innenseite (also auf die Platinenseite) geklebt. Das entspricht etwa der Temperatur auf dem Stecker seitlich (im Bereich des power connectors auf der Graka), wenn man dort mit nem Infrarotsensor draufhält.
Was soll eigentlich dieser zwanghafte Kriswichs Blödsinn?
Ähnliche Themen
