[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, das mit dem Link-Kabel anschliessen ist mir schon bewusst. Aber bei mir erscheint das "PSU-Modus (Single/Multi)" nicht.
Bei mir kommt das:
Diesen Switch (rechts) gibts bei dir nicht?
Part 4
Es gibt sowas, das nennt sich Anleitung, gibt es zu jeden Produkt und sollte man lesen, dort steht alles drin. :fresse:
Ich liebe solche Beiträge...:kotz:
Hier kannst du sehen, wie viel "alles" zu dem Thema da drin steht. Kein einziger Inhalt zur Software selbst.
Hast Du die ICue Software installiert? Wird das Netzteil darin angezeigt? Dann ist der unterste der drei Punkte links der für Single/Multi Rail Umschaltung.
Habe ICue und zwei verschiedene Versionen Corsair-Link probiert. Bei keinem gibt es die Single/Multi Rail Umschaltung. Nur die OCP der einzelnen Rails lassen sich einstellen und das geht laut Foren nur, wenn es im Multi-Rail Modus ist. Im Single-Rail Modus wäre es ausgegraut.
Leider nicht, warum auch immer (siehe Bild).
Bei einem User in einem Forum von 2017 war der Switch vorhanden (ebenfalls AX1500i) 🤔
Ach, sehe jetzt erst, dass Du das AX1500i hast, nicht das HX. Wenn ich das richtig verstehe, dann hast Du dort über die einzelnen OCP Regler (die ich beim HX nicht habe) die Möglichkeit Multirail darzustellen, da ja die Absicherung für jeden Anschluss individuell einstellbar ist. Wenn alles rechts auf Anschlag steht, ist es demnach funktional wie Single Rail, oder habe ich da nen Denkfehler.
Hier mal 2014 angesprochen:
Ansonsten mal im Corsair Forum nachfragen, da kommt meist schnell Feedback.
Immer diese selbsternannten Ordnungshüter 😅
In jedem Thread landet hin und wieder offtopic und von den meisten auch komplett unnützer Spam.
Vegeta Pyjamas waren hier auch schon ein riesen Thema, so what 😜
Danke für deinen Beitrag, aber das war ja auch nicht das Ursprungsthema.
Es ging um die 12v Spannung. Thunderburne hat durchgehend über 12v mit Single Rail. Ich habe durchgehend unter 12v mit Multi Rail. Darum wollte ich testen, ob es einen Einfluss hat, wenn ich von Multi Rail auf Single Rail umschalte. Aber dabei ist aufgefallen, dass ich es nicht umschalten kann.
Ob es sinnvoll oder überholt ist, war nicht das Thema 🤷🏻‍♂️
Ich habe auch ein Single-Rail Netzteil und habe je nach Last bis zu 11.925V. Kann irgendwie die Werte, welche konstant auf 12V sind, nicht nachvollziehen. Etwas Spannungsabfall ist doch immer da und auch normal oder nicht?
Das stimmt, habe das Seasonic TX 1600 3.0 und nutze ausschließlich das Seasonic Kabel und der Abfall ist ca. 100mV. Denke es ist eines der besseren Netzteile, daher kann ich nicht verstehen, wie manche keinen Spannungsabfall haben, mit teilweise qualitativ "schlechteren" Netzteilen.
Die 4090 hat ja teilweise hohe Spannungsspitzen, weshalb der Abfall meist nur sehr kurz anliegt.
Ich habe einen Spannungsabfall natürlich nur nicht unter 12V laut HW Info und auch den Daten die vom Corsair NT selbst ausgeben werden.
Das Problem wird die kommenden Wochen aber behoben :whistle:
Völlig Egal ihr wollt das Thema hier nicht also lassen wir das doch einfach .
Reden wir lieber den ganzen Tag über Spontane Selbst Entzündung der Stecker. :wink:
Wollte hier keine schlechte Stimmung machen:wink: es hat mich einfach nur interessiert wie es sich verhält und ob man überhaupt da von etwas ableiten kann.
@RediMischa
Ich hab das bei mir auf Multirail zurück geschaltet und verglichen .
Habe keine Abweichung zwischen beiden Modis feststellen können.
:btt:
Es ist nicht das offtopic was stört, sondern der Mist Single vs Multi-Rail.
Single-Rail ist seit Jahren überholt! Bietet keinen Mehrwert, sondern nur Nachteile auf technischer Ebene gegenüber Multi-Rail.
Single-Rail lohnt höchstens bei Extreme-Overclockern, die LN2 verwenden und Weltrekorde fahren wollen.
Wenn ein NT beide Modi anbietet, würde ich den Standard verwenden und nicht auf Single umschalten.
Wenn es Probleme geben sollte, kann man immer noch wechseln.
Gab doch nur eine ganze Zeit lang Multi-Rail von Bequiet oder?
Hatte zuletzt das DPP 11 von denen wo man auch umschalten konnte.
Danach halt das AX 1000 Titanium gekauft , weil es halt so gut abgeschnitten hat in allen Tests.
Zudem war ich zumindest mal der Ansicht wegen den Lastspitzen damals bei der 3090 auf ein Single Rail zu setzen wäre ggf. sinnvoller.
5080/5090 eventuell schon Sep 2024. Würde für die GamesCom wieder sprechen um die Karte zu präsentieren. Oder Computex.
So Leute bin jetzt ganz offen, weil das garnicht mal so witzig ist.
Habe gerade am NT selber die zwei 8 Pin Stecker geprüft.
Davon war einer nicht komplett eingerastet ! (ganz minimal war das)
Siehe jetzt kein Spannungsabfall mehr. Die Karte jetzt extra @ Stock getestet und jeder der bisschen Ahnung hat
sieht , dass diese auch ins Powerlimit läuft. Also richtig last auf die Karte.
Also Leute Anwenderfehler Punkt aus Ende !
Vorstellung wahrscheinlich aber ob auch verfügbar ist noch die Frage.
Hat sich ja Ende gelohnt dran zu bleiben bei dir wen das nicht mehr schwankt mal schauen was die anderen jetzt berichten.
Und zur 5090 @***** hat extra dafür nen Thread aufgemacht .
Da können wir schön News Sammeln.:wink:
Thema 'Blackwell Smalltalk Thread (RTX 5000er Reihe)' https://www.hardwareluxx.de/community/threads/blackwell-smalltalk-thread-rtx-5000er-reihe.1352430/
@SH
Ich verlinke das mal dort.
Ja habe jetzt gerade ganz normal ne Stunde gezockt.
Ist jetzt alles inordnung. Da kann man mal sehen.
Denke durch das UV ist halt auch nichts passiert.
Gott sei dank.
Also im prinzip gibt es dann nur zwei Fälle in der Regel.
Entweder Pin zu kurz am Kabel selber durch schlechte verarbeitung vom Hersteller
oder halt Anwenderfehler , weil entweder am NT oder an der Karte nicht tief genug eingesteckt.
Bisschen dauern wird das schon.
Meinen WC Block hatte ich 1 Tag vor Heilig Abend bei der 3090.
Ich war da Vorbesteller. Der 4090 Block hatte glaube länger gebraucht.
Denke die ersten werden ALC und EKWB sein.
Wenn du die ganze Zeit auf Alternate bist um 15 Uhr, schaffst du es locker irgendeine Karte in den Warenkorb zu legen.
Im Endeffekt ist es doch wieder egal, welche Karte man nimmt. Undervolting und dann ist der Kühler auch egal.
Außer man will eine Wakü :) Dann ASUS wegen der Garantie.
Also beim RTX 30 Launch war da nichts möglich für die meisten. Vor allem 3080 damals keine Chance weil viele Shops den Warenkorb nicht reserviert haben. Hatte 3 Bestellungen durch und keine war am Ende tatsächlich lagernd.
Es dürfte auf jeden Fall wieder spannend werden bei Release. Ich gehe auch davon aus, dass man als Normalo nicht gleich an eine Founders Edition rankommen wird. Wird bei Proshop nicht anders laufen als bei NBB.
Aber bei Release der RTX 4090 erinnere ich mich, dass es durchaus möglich war, an eine 4090 zu kommen. Man muss halt schnell die Shops abklappern. Und eine Manli Gallardo war auch sehr lange zu kaufen ;)
Anderes Beispiel...
Hatte über eine längere Zeit sporadische BSODs. Insbesondere beim Löschen von vielen bzw. großen Files und beim Videos konvertieren. Am Ende wurde es so schlimm, dass ich nach Neustarts nicht mal mehr bis zum Anmeldescreen kam
Im UEFI/BIOS (dort war ich länger nicht gewesen) waren die einst 3,3V gerade mal 2,9V (in roter Schrift - ist normal weiß). Ich schwöre bei Gott, dass ALLE Stecker zu 100% richtig gesteckt waren. Hatte ich auch extra VOR dem Abziehen geprüft.
Kurz NT-seitig und MB-seitig, den 24-PIN-Stecker abgezogen und wieder gesteckt. Seit dem läuft die Kiste ohne BSODs. Sowas hatte ich schon mal vor mehr als 10 Jahren, aber der ARC-1261ML hat da sofort angefangen zu herumzupiepsen, lange bevor es BSODs gab
Kann jetzt nicht sagen, ob mir das in HWinfo aufgefallen wäre. Aus Zeitmangel und Unwichtigkeit hab ich ehrlich gesagt nicht danach geguckt
Daher Anwenderfehler "nein" (Stecker waren ja zu 100% drin)! Eher die "HWinfo-Aufsicht" unterlassen :d
Gott sei dank.
Immer richtig tief reinstecken, damit der "Saft" gut fließen kann :fresse:
Ich bin auf jeden Fall dabei.
Hoffentlich schafft es watercool bis dahin, einen Kühlblock zu bauen.
Dein Wort in meinen Ohren :)
DIe Wahrscheinlichkeit im Lotto zu gewinnen, ist statistisch höher :fresse:
Heilig Abend 2021 meinst du wohl ;) Denn Blocks haben da recht lange gebraucht
Bis dahin hatte EK und BS den Markt mit Blöcken geflutet
Nope ich hatte Oktober 2020 die RTX 3090 im Ref. Design gekauft.
War ne Gainward Phoenix GS 3090 und Heilig Abend 2020 hatte ich die Wakü zusammen.
Ähnliche Themen
