[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Stimmt wer kennt es nicht aus dem Mini Media/Office PC :ROFLMAO: mal schnell die 4090 rausholen um paar Benches zu machen
Nicht rausholen - dazustecken :d
Habe die Tage den org. i5-9500 aus dem G5 Mini (1 Liter-PC) gegen einen 9900K getauscht :fresse: Nur schade, dass ich da keinen PCIe-Slot, wie im "ThinkCentre Tiny" (auch 1 Liter) hab
Sonst könnte ich mal spaßeshalber die 4090 anschließen. Natürlich außerhalb des 1 Liter-Cases mit Riser. Ins Case passt mom. leider nur eine gemoddete RTX A2000
Das fette 230W-NT hab ich wegen dem 9900K umsonst aufgetrieben (wurde laut Mini-Forum empfohlen) :d
Wann hattest Du Deine gekauft? Hatte exakt dasselbe Problem (der ganz linke Lüfter drehte sich nicht), aber meine Temps waren nicht ok, daher ging die zurück. Gekauft ebenfalls bei Amazon im Dezember 22.
Anfang Dezember 2022, auch bei Amazon.
Aber ich werd verrückt, ich hab eben das Gehäuse aufgemacht und es dreht auf einmal alle 3 Lüfter. Das haben sie beim Kauf 100% nicht gemacht. Warum das auf einmal funktioniert (gabs ein neues VelocityX, das das evtl. behoben hat?) ist komplett an mir vorbei gegangen.
Falls einer mal Hellblade 2 startet musst ihr mal schauen wie hoch plötzlich der Speicher taktet. Hab normal bei AB 11 GHz eingestellt. Die taktet bei dem Spiel 250Mhz niedriger . Bei CP2077 und allen anderen Games alles normal. Ka warum. Mein erstes UE5 Game .
Verstehe nur nicht warum 😀
Auch wenn ich Stock einstelle 250Mhz weniger. Also statt 10,5 GHz dann 10,25Ghz
Spiel sieht geil aus und mit Max Details ohne FG sind es zwischen 70-80 FPS.
Upscaler DLSS gewählt @ Qualität.
FG teste ich erstmal nicht. Bin kein Freund davon. Bis jetzt war nur CP2077 und Hogwarts FG gut implementiert. Bei anderen Games sieht man, dass die Grafik schlechter wird vorallem irgendwie in Verbindung mit HDR . Bei den zwei Games war es gut , aber sonst eher enttäuscht davon.
Spiel das Game eh mit Controller.
Spiel ist übrigens für 21:9 ausgelegt.
Man hat oben und unten schwarze Balken.
Somit sollten UWQHD Spieler Vollbild haben.
Ah kam doch ein Treiber. Speicher taktet nicht mehr um 250Mhz runter und sind jetzt paar FPS mehr .
Hatte vorhin nach Treiber geschaut. Da war noch nichts, aber spiel läuft trotz allem echt smooth.
Noch 56 Minuten! 🤣🤣
ist nun wohl ladbar über steam, ich warte aber noch :)
Whoop
Jetzt mal ohne UV Handbremse :d
So.
Ich will auch über 10.000!
Fehlt noch n Stück.
Die Punkte unterliegen offensichtlich mal wieder einer cumplizierten :o Formel, fps x 100. (y)
wenn ich mir solche Videos angucke, bin ich mir sicher, dass wir überhauptnicht sicher sind.
Nachricht gelöscht
Hier gibt es doch noch welche die 24/7 am falten sind, keine Ahnung was die Karte da an Watt zieht weil ich das nicht mehr mache aber glaub da gab es auch noch keine Vorfälle.
faltet bei vielen mit 200-250 W und beim Falten hab ich auch noch nicht von Problemen mit dem Stecker gehört
Das Ding ist und bleibt halt ne Fehlkonstruktion, das habe ich seit Release schon geschrieben, hoffe Nvidia lernt daraus, aber ich ahne bei der 5090 wieder schlimmes. :d
da der neue 12V-2x6PIN angekündigt ist wird es wohl dieser werden :wall:
Hier gibt es doch noch welche die 24/7 am falten sind ...
Bei mir durchgehend bei ca. 230-270 Watt mit UV. An den vier Karten ist das Original Corsair Kabel. Das ist unproblematisch seit Anfang 2023.
Mein 24/7 Setting. Anderer Ansatz als UV mit fixer Spannung.
OC (1.1V, +150 GPU +1500 VRAM) aber Power Limit bei ~360 Watt.
Ich behaupte mal kühn das ist der Sweetspot bzw. das Perf/Watt Optimum für eine 4090 8-)
Bei eurem UV, stellt ihr da das PL einfach z.B. auf 80%, statt 100%?
Ich denke die meisten hier stellen die Werte mit dem Curve-Editor in Afterburner fest ein.
Definitiv wird individuell mit dem AB Curve Editor eingestellt. Bei meinen GPUs sind die dauerhaft stabilen UV-Werte sehr unterschiedlich.
Jo definitiv über die Curve.
Hat ja auch den Vorteil das man nicht ins PL kommt.
Meine aktuelle Karte (4090 FE aktuelle Rev.) kommt Stock nie ins Powerlimit. Die taktet dort nur mit 2670Mhz - wobei der Wert wie festgenagelt ist.
Ich kann auch das Limit auf 133% anheben, ohne dass sich etwas ändert. Erst wenn ich die VCore auf 1,07v anhebe (mehr geht nicht) taktet sie etwas höher.
Ist Nvidia da so vorsichtig geworden?
Aktuell läuft die Karte im Alltag nur mit 2550MHz@900mV.
Ähnliche Themen
