[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Doch das habe ich schon oft gesehen.
Path Tracing haut schon rein.
Die Taktsenkung hielten sich aber in grenzen.
Max. 45 MHZ, aber 450 Watt heizen halt auch derbe das Gehäuse auf.
Selbst mit dem Corsair 7000D Airflow was echt nicht schlecht ist für Luftgekühlte Systeme merkt man doch schon ,
wenn man an warmen Sommertage zockt. Deswegen für mich gehts primär um Lautstärke und Hardwareschonung beim UV.
0,975V mit leichten OC ist für mich ein kompromiss aus Leistung und Lautstärke/Kühlung.
Ja, da kommt viel Wärme zusammen, die erstmal abgeführt werden muss.
Bei mir liegen die max. 2670Mhz/Stock aber immer an. Ob warm oder kalt, viel Last oder ganz wenig.
Guten Morgen!
Ich brauch mal bitte einen Rat von Euch.
Hab mir vor einer Woche den Wireview geholt, (12vhpwr auf 12vhpwr).
Seit dem ich den Verbaut habe, zeigt er mir die Spannung mit 11.8v auf dem Wireview an und in HWInfo sogar teilweise auf 11.77.
Ich hab ein Straight Power 11 850W Netzteil mit dem Be Quiet Kabel dran (also nicht die Peitsche). Vor dem Wireview wars nie unter 12V.
Soll ich den wieder ausbauen, oder meint ihr, passt das?
Ich hab ne PNY 4090 XLR8 und läuft meistens eh mit UV. (Hab die schon über ein Jahr)
Der Wireview macht die Kabelführung in meinem Torrent XL deutlich leichter als ohne, da das Be Quiet Kabel, wenn ich es hinten im Gehäuse verlege, zu kurz ist...
Was ich noch probieren könnte wäre die Peitsche zu verwenden und zu testen.
Habt ihr einen Rat für mich?
Vielen Dank!
Grundsätzlich ist von Adaptern ab zu raten.
Eigentlich braucht doch auch niemand mehr Adapter, jedenfalls nicht wenn man 90° Stecker an der GPU haben will.
Das bieten doch inzwischen (fast?) alle Netzteil Hersteller selber mit entsprechenden Kabeln in ihrem Portfolio an.
Wollte ich zuerst auch, allerdings gibt es (zumindest hab ich nur dieses Kabel gefunden) von Be Quiet den 90 Grad Stecker nur mit 2x 12vhpwr. Ich hab kein ATX 3.0 Netzteil.
schaut für mich hässlich aus und kann jetzt nicht der "Überflieger" sein
Kann mir aus physikalischer Sicht kaum vorstellen, dass eine solche Karte mit integrierter AIO-Kühllösung effizienter kühlen soll als wenn man gleich mit Luft kühlen würde.
Wie hoch ist eigentlich bei euren Karten das Delta zwischen GPU und GPU Hotspot und welche Karte + wie lange habt ihr eure Karte?
Also bei Speedway @ Benutzerdefiniert 4k bei über 400 Watt Board Power Draw kam ich auf 21 kelvin.
Bei BF 2042 bei ca. 260 Watt Board Power Draw war max. laut GPU Z 15 kelvin dazwischen.
Bei 350 Watt waren es ca. 18-20 kelvin je nachdem wie lange ich gezockt habe.
Karte Asus TUF RTX 4090 seit Release. Die verwendete WLP wird auch immer schlimmer bei den Karten.
So teuer ist das Zeug auch nicht...
Ich habe ein Delta von knapp 10grad bei 400watt+ bei über 530watt sind es dann ca 15-16°C
WLP Kryonaut Extreme auf meiner 4090 TUC OC (Seit Release)
Ja gut hast ja dann schon die WLP erneuert.
Möchte das natürlich nicht machen so lange die Karte noch Garantie hat.
Der Hotspot bewegt sich von 78-88°C. Das geht ja noch.
Zudem die Pads sind ja ziemlich weich.
Könnte dann sein , dass man diese dann gleich mit erneuern muss und daher schiebe ich es bisschen auf.
Weißt noch was für Pads du von der dicke her gebraucht hast bei deiner TUF OC ?
Die Pad dicke auf dem für Spawa und Ram auf dem original Kühler weißt nicht oder ?
Auf einem Wakü Block kommt das drauf was sich halt der Hersteller gedacht hat beim konstruieren^^
Bei der Tuf sind es ziemlich dicke Pads, wenn man die Bilder sich zu Teardowns anschaut.
Die waren Relativ Dick müssten locker 2mm gewesen sein für Ram und spawa müssten 3mm gewesen weil die ein hauch dicker waren als RAM
Aber nur geschätzt habe nicht gemessen
Hier mal ein Bild von einer Tuf mit angaben aus reddit : https://imgbb.com/FYzGF9s
Hab ich garnicht mal schlecht geschätzt xD
Ja vielleicht bekommt man das dann doch noch hin ohne die Pads zu killen bei der dicke.
Nur schlimm was da Asus für eine schrott WLP verwendet. Bei AMD sind ja 20 kelvin normal, aber bei
Nvidia normal deutlich weniger. Naja noch ist es im Rahmen..
Wobei das so eine Panik mache ich es gibt genug YT Videos wo leute locker 2 Ziegelsteine auf eine GPU gelegt habe und sie unfassbar gebogen hat und zum schluß ist die GPU aus dem Slot hausgerutscht und weder das PCB war gebrochen noch war der PCI Slot defekt und das ganze war ein billig board mit den normal verstärkten PCI slot aus aktuellen Mainboards gibt es überhaupt keine probleme mit aktuellen GPU´s
Aber mit Panik mache verdient man eben das beste Geld :ROFLMAO:
Einfach die GPU diagonal zur Slot-Blende stützen und gut ist. ;)
Und selbst wenn nicht, die Teile kosten nicht die Welt. Muss ja nicht dieses ASUS-Teil sein...
So eine reicht dicke aus und kommt bei mir selbst zum Einsatz:
Amazon-Link
Hätten wirklich alle ein E-Autos, dann hätten wir glaube schon diverse problemchen mit dem Stromnetz und wahrscheinlich paar alte Tiefgaragen
eingestürzt :d
Ähnliche Themen
