[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Frage in die Runde:
Bin letztes Jahr spontan von einer 6800 XT auf eine 4090 umgestiegen. Auf meinem 32GS95 LG 240 Hz OLED habe ich in Hunt Showdown in Mischszenen immer so ein super nerviges Bildschirmflackern.
Ist das bekannt und weiß einer was man tun kann, damit das weg geht?
Mit der AMD Karte und Freesync Premium Pro hatte ich das Problem nicht 👀
Frage in die Runde:
Das ist VRR Flickering. Ist so eine Krankheit von Oled bzw. haben das auch andere Displaytechnologien aber bei Oled ist es am auffälligsten wegen der kurzen Schaltzeiten.
Hunt ist hier leider bei mir auch negativ aufgefallen aber erst seit ich statt in 4K 120 in 1440p 240Hz spiele. Hunt neigt dazu unruhige Frametimes zu haben je höher die FPS sind. Und unruhige Frametimes sorgen für das Flackern. Bei mir geht 144Hz maximal, da flackert dann nichts. Wenn ich höher gehe fängt es an. Habe schon viel probiert und es bleibt nur das 144fps limit oder damit leben. Mich stört es leider extrem und spiele Hunt daher in 144fps auch wenn ich in 1440p mehr erreichen könnte (180-200fps ohne DLSS hohe settings). Vorher auf dem 4K Oled mit 116fps limit war es ebenso nie ein Problem. Passiert erst wenn die Frames höher sind.
Die 6800XT hat wahrscheinlich einfach nicht genug Frames gebracht damit es flackert
Davor werkelte eine 7900XTX an dem Monitor und da war das meine ich auch nicht präsent...
Egal, ich schau Mal ob ich das irgendwie hinbekomme. Eigentlich sind die Hunt frames schon relativ konstant, aber vielleicht probiere ich es mal mit verschiedenen FPS Caps.
Danke dir!
Frage in die Runde:
hast du die fps limitiert oder offen? und kannst du die fps, die du gecapped hast auch halten?
Naja die schwanken in Hunt zwischen 160-200 FPS (da ist das Cap) deswegen wundert mich das Geflacker extrem
wenn die zwischen 160 und 200 schwanke musst du das cap auf 158 setzen^^
Bei mir flackert es allerdings auch wenn ich die settings so einstelle, dass ich 180fps konstant hab. Ich hab jetzt einfach 1440p Ultra und kann so immerhin ohne geflacker zocken in 144fps
Für was kauft man dann einen 240Hz OLED :d
ich teste Mal ein wenig rum... bin aber nach wie vor sicher, dass das nicht der Fall mit 7900XTX und Freesync Premium Pro war... da hatte ich Hunt in jedem Fall auch so eingestellt dass ich auf die FPS komme, natürlich mit niedrigeren Details
in dem du deine settings so setzt dass du 240 erreichst^^
zumal schwankende fps bei aktiven adaptive sync für gummiband gameplay sorgen.
bei freesync und gsync immer fps cappen auf einen wert den man halten kann
Es gibt jetzt btw bei Cablemod 12V-2x6 Kabel . Sogar gewinkelt in beide Richtungen. Geht aber nur über den Konfigurator.
das wäre dann perfekt für mich
Habe mir gerade eins bestellt. Warte auch schon lange auf ein 90 Grad Kabel was für die FE passt mit meinem Asus Netzteil. Bisher gab es nur ein 90 Grad Kabel das Richtung Backplate geht was sehr blöd aussehen wird bei einer FE. Jetzt gibt es endlich eins Richtung Kühler. 68€ mit Versand aber stolzer Preis :fresse2:
ich muss erstmal schauen welche version ich da brauch
60cm klingt hart lang
Also ausgehend von horizontaler Einbau und Kabel Richtung Kühler ist Variante A für Asus und co wo die Sense Pins unten sind und Variante B Sense Pins oben. Ist auch im Konfigurator erklärt wenn du ein 90 Grad Kabel auswählst.
hab die tuf. also müsste das variante A sein.
Gut,
der eu store hat ein anderes konto.
für das kenn ich das passwort nicht mehr
Lost password? > contact support... omg :fresse:
Lol dann halt neues Konto
Lösung war jetzt einfach in Hunt G-Sync zu deaktivieren. Werde das Mal gegentesten mit meiner 6800XT, die kommt auch auf beachtliche Frameraten auf niedrigen Einstellungen und Max OC... nervig ist es alle Mal
Ja, das geht natürlich auch, dann verliert man allerdings auch die Vorteile, die Gsync bietet. Vor allem wenn dann ins Vsync Limit kommt, hat man auch mit Inputlag zu kämpfen
Ne das ist auch aus... Bei einem 240Hz Display ist das alles zu verschmerzen.
Das Geflacker geht mir definitiv deutlich mehr auf'n Sack 😅
Hab ich auch mal probiert aber das gibt dann wiederum sichtbares Tearing, selbst in 240Hz. Irgendwie alles nicht optimal :sneaky:
GameTechBench
A high-performance benchmark powered by Unreal Engine 5 to measure your GPU's power in real-world gaming scenarios and in offline cinematic rendering.
Aus purer Langeweile habe ich nun auch Indy durchgespielt, dass Ende war dann doch wieder recht cool. Hat die 4090 wirklich extrem gefordert
Jetzt habe ich keine Games mehr auf der Liste, werde mal gucken ob ich Age of Mythology Retold oder so zocke.
Kingdom Come Deliverance 2 kommt erst in 2 Wochen und Stalker 2 ist mir immer noch viel zu kaputt.
Stalker 2 startet bei mir gar nicht mehr. Bzw tritt jedes Mal der Fehler auf, dass die Shaderkompilierung fehlerhaft war, woraufhin der Bildschirm freezt😤
Also bei mir läuft es echt gut inkl. FG und DLAA. Da gab es viiieel schlimmere Games die zum Release hart verbuggt waren.
  • Danke
Reaktionen: A6
Nur weil es noch schlimmeren Mist da draußen gibt macht es das Ganze nun nicht besser… halte ich immer für eine seltsame Argumentation.
Man kann die Argumentation ja auch umdrehen: Es gibt viele Games, die gleich zu Beginn um einiges besser laufen🤷🏻‍♂️
Sorry aber ich habe einfach eine andere Erfahrung bisher gemacht. Das Game ist gut spielbar und hindert mich nicht es zu genießen. Bin eigentlich Jemand der sehr kritisch ist aber hier fehlt mir der Grund.
Ähnliche Themen
