[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
DLSS 4 OneDrive:
DLSS 4
Installation :
Step 4: Find the game folder of the game you wanna update to the new DLSS, and replace the old DLSS DLLs with the new ones you downloaded. Regular DLSS is called nvngx_dlss, framegen is called nvngx_dlssg and ray reconstruction is called nvngx_dlssd, search for those in the game install folder and replace them. (make sure to backup the old files in case the game wont work with the new ones, you can also just verify the game install to have it replace the files back to original again) Keep in mind that you are unable to replace dlls in most games with anti cheat however there is a workaround (see in important notes further down)
Step 5: Place the XML file you downloaded, so that its next to nvidiaprofileinspector.exe (the xml file adds the setting you need for the new preset)
Step 6: Open Nvidia Profile Inspector and scroll down to section 5 on the long list of settings. Now you should see the "DLSS 3.1.1+ FORCE DLSS PRESET" setting - now select Preset J in the dropdown box and hit apply changes in the top right corner of Profile Inspector. Make sure you are on the "global_driver_profile" on the top left side, you should be on that per default when opening the app.
Step 7: Every game now forces the new preset J for every quality level, as long as you have replaced the DLL's of the game folder
Wird aber nicht mehr benötigt werden wenn Nvidia sein CP/APP aktualisiert. Dann soll man das über den treiber forcen können
DLSS 4 OneDrive:
DLSS 4
Installation :
Hab das ganze mal bei Marvel Rivals und OV2 getestet und muss sagen DLSS 4 sieht schon Besser/Schärfer aus und ich habe 4-500MB weniger Vram belastung
Soo Robocop ist durch, hat die 4090 teils extrem gefordert. Es war viel länger als ich erwartet habe und auch viel besser.
Was für eine wunderschöne Perle, was für markige Sprüche, alles auch noch komplett Vollvertont und ein Waffensound der einem die Socken auszieht, wow.
Selbst die Story war richtig gut gemacht.
Ein echter Geheimtipp das Game 🤘
Moin,
weiß jemand, ob man für eine Zotac 4090 Trinity OC eine Dualslotblende einzeln bekommt?
AC hat eine bei den Kühlern bei, die habe ich mal angeschrieben, ansonsten habe ich im Netz (AliE) nur etwas für Asus gefunden :/
(Oder ich bin zu blöd zum googlen...)
Moin,
@Ickewars hat mehrere ZOTAC AIRO und hatte auch nach einer Blende gesucht. Ich weiß nicht mehr wie er es gelöst hat, ich meine auch dass 3D Druck mal im Gespräch war, wie auch die originale zu schneiden. Beides wurde aber verworfen, als irgendwie der Stein der Weisen aufgetaucht ist, aber ich kann Dir nicht mehr sagen wie der aussah, vielleicht meldet sich ja der Meister selbst zu Wort :d
Nö, kein Stein der Weisen, sonst hätte ich mich hier schon gemeldet. Hatte mich dann damit abgefunden, dass es keine gute Lösung gab. Wollte die Originalblende dann auch nicht zersägen.
Evtl. hast Du in Erinnerung, dass ich beim Granzon -Block dann ne 2er dabei hatte? Da hatte ich Regok glaub auch nochmal nach weiteren gefragt, allerdings erfolglos.
Schon installiert und getestet?
treiber und app sind installiert, der override funktioniert allerdings in keinem einzigen spiel. flightsim 24, metro exodus enhanced, hogwarts legacy, forza horizon 5, six days in fallujah, witcher 3, far cry 6 etc pp: überall ausgegraut und "nicht unterstützt". in stalker 2 taucht das entsprechende menu nichtmal auf 😂 super start :d
vllt. testet das jmd anders noch gegen, bei mir läuft's nicht. ich nutze dann erstmal weiterhin den global override in verbindung mit nvidia profile inspector 👍
Wie sollte es denn theoretisch funktionieren? Man enforced DLSS4 quasi im Treiber höher priorisiert als im Spiel? Und wie erkennt man ob es funktioniert?
Hab den neuen Treiber noch nicht drauf, aber auch bei mir alles "nicht unterstützt". Eventuell aktuell nur 5000er Karten?
das wusste ich nicht mehr
Der Neue Treiber wird nun auch in der App angezeigt. Allerdings ist der Aufbau gerade extrem langsam, wohl leicht Server überlastet.
Bei mir kann ich auch nichts auswählen. Auch nach nem Neustart nicht. Also manuell die dlls tauschen.
mit dem script und dem nv profile inspector kann man es ja auch global einstellen, dass immer selbst zur verfügung gestellte dlss4 dlls und das neue profil j (transformer model) genutzt werden. nutze ich so und funktioniert ganz zuverlässig.
mit dem reg file im anhang kann man dann noch ein dlss overlay anschalten wenn man möchte, das einem dann zeigt, welches preset genutzt wird.
ja, ähnlich: du benötigst dafür die nv app.
  • DLSS_Indicator_reg.zip
In den ausführlichen Changelogs kann ich beim DLSS Overwrite auch nicht finden, dass das 5000er exklusiv wäre. Bug?
muss bug sein, mMn auch, ja. schade, wäre ja auch zu schön gewesen; aber das wird schon, irgendwann wird's dann mal funktionieren :)
in cities skylines 2 z.b. geht dlss 4 nicht. da steht dann links im bildschirm eine fehlermeldung die nicht weg geht. paradox ist einfach schrott
es geht halt einfach GAR nix mehr auf deren seite 😂👌 die nvapp bekommt den treiber nicht mehr heruntergeladen und auf der website einfach nur noch "... ... ... ...loading... ... ... ..." hehe
ganz schön verbockter start würd ich mal so behaupten mögen :shot: paperlaunch, viel zu hohe preise, softwareseitig auch ein fehlschlag, was will man mehr... :)
So, neuen Treiber und App auch installiert. Ich nenn meine 4090 dann ab jetzt 4590. :)
Bekommt sie jetzt auch Beschleunigungslöcher?
Warum steht denn da bei DLSS Model Override überall not available? Bei FG klar, das geht nicht mit Lovelace. Aber DLSS4 müsste ich doch aktivieren können?
Oder anders gefragt, wie aktiviere ich DLSS4 in der App?
Gar nicht? Darum geht es doch die ganze Zeit hier, dass das aktuell nicht geht. :d
doch, geht schon ;) allerdings nur mit "kontroll-übergabe"...
scheinbar muss man bei der installation des gpu drivers "neu installieren" wählen und beim starten der nv app "automatische optimierung" aktivieren. was mich ziemlich nervt, wenn nv andere settings in den games einstellt. aber so funktioniert es nun bei mir: treiber neu installieren lassen mit löschung aller einstellungen und in der nv app beim ersten start die optimierung erlaubt.
Ah verstehe. Beim Treiber mach ich eh immer die komplett neue Installation, aber automatisches Optimieren hab ich natürlich ausgeschaltet. Ich hoffe also wirklich dass die das noch ändern. Seh ich gar nicht ein dass der mir da Dinge anpasst, ich die nicht verändern möchte. Dann bleib ich erstmal bei DLSS3. Also Kommando zurück, meine Karte heißt wieder 4090. :fresse:
Ja, das mit automatisch optimieren hab ich noch nie genutzt und mag ich auch nicht. XD
Vielleicht findet ja noch Jemand über den NVidiaInspector einen Weg das freizuschalten ohne automatisch optimieren aktivieren zu müssen?
Ich hab bei EKWB angefragt, die Blende vom Pro soll angeblich nicht passen.
Alphacool ebenfalls gefragt, haben keine einzeln.
D.h. damit DLSS4 ohne den Käse funktioniert müssten die Hersteller das nativ implementieren? Ist mir glaub zu nervig das über den Treiber zu machen, hoffe das ist einfach nur buggy und wird noch gefixt.
Aber selbst wenn! Man kann oben den Balken komplett auf Qualität schieben und dann optimiert er eh schon alles auf Max Out. Dann hätte man ja DLSS4 und kann wieder manuell nachjustieren. Sehe darin jetzt ehrlich gesagt kein Problem, da dass nicht mal 3 Minuten im Grafikmenü bedeuten 🤷🏻‍♂️
Ähnliche Themen
