• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Schon möglich. Aber die Wakü ist ja schon da. Wäre blöd die nicht zu nutzen.
Ich will erstmal kucken was die Master macht das Teil ist ja das Mega Monster siehe Roman youtoube Video.
Roman sagt ganz klar das Problem ist nicht die Kühlung sondern zu wenig Spannung!
Man könnte meinen, Galaxus hat nen Azubi hingesetzt der Karten einzeln zu Apotheker-Preisen freigibt :fire:
Diesem Shop wünsche ich alles, nur nichts Gutes...
Denk an das Cashbake
Welchen würdest du nehmen den Schwarzen oder mit Guckloch.
Ich hab für meine Aorus 2365 bezahlt und bekomme 70 Cashback.
Bei MF gibts kein Cashback, oder? :d
Ihr macht mir das echt schwer den neuen PC auf Custom Wakü zu bauen nachdem ich mich erst ne Weile selbst zu der Entscheidung breitreden musste. 😂
Hat jemand ne Empfehlung für ein HDMI 2.1 Kabel? Mir wurde das hier empfohlen: https://www.caseking.de/Club-3D-Ult...0Hz-48Gbit-s-2m-ZUHD-162.html?tplview=desktop
Aber 8€ Versand nur für n Kabel, kommt mich dann auf über 30€ 🤔
Kauf doch nen Lindy Kabel 20 ocken auf Amazon und gute Quali
Für die Gigabyte Karten!
Falls es von Interesse ist, habe heute meine Rog Strix 4090 bekommen und Spulenfiepen ist deutlich hörbar. Weit mehr als bei meiner MSI Trio 3090. Die hatte das auch aber erst bei wirklich extrem hohen FPS. Bei der 4090 hört man im Prinzip schon bei 100FPS was wenn man es drauf anlegt. Beim Spielen dann mit Sound und Lüfter plus Pumpe der WaKü an geht das dann unter zwischen dem Rest. Aber ich dachte ja weil mein Monitor 240FPS kann das ich in einigen Spielen da hinkommen würde. Geht auch, bei Destiny 2 zum Beispiel, aber da ist das Fiepen dann doch deutlich zu hören. Die Leistung der Karte ist Top, auch was Lüfterlautstärke angeht, aber das Fiepen ist schon blöd. Muss ich mal über das WE gucken ob ich damit leben will/kann. Vermute mal das ist nicht bei allen Karten so laut oder setzte erst bei höheren FPS an.
Für DLSS darf die CPU nicht zu schwach auf der Brust sein.:coffee2:
was auch logisch ist. denn wenn eine cpu bei 50fps dicht macht und man will mit dlls dank 4090 aber 144 oder mehr erreichen dann sind 100 fake frames sicherlich nicht das gelbe vom ei
power limit mal auf 80% gesetzt?
Hat schon jmd. Auf seine Supreme X ein 600watt bios geflasht?
Schon auffällig, dass Saturn sämtliche 4090 (bis auf eine) aus der Seite genommen hat. Kommen wahrscheinlich neue Preisschilder drauf...:cautious:
Hat Intel die bezahlt oder was ?
9900K oder höher mit 5Ghz + und DDR 4 4000 sieht sicher anders aus als 8700k 4,3 GHz und ddr 4 2666.
Oh hat NBB doch Custom Karten verkauft die nicht lieferbar waren?
In der PDF der AB steht "Liefertermin noch nicht bekannt"
Noch wer der sowas drinstehen hat? oder gar wer der das drin stehen hat und die Karte schon unterwegs ist?
Ja das ist ein Monster, aber 2 Mora 3 sind das größere Monster :d
Ja nur wenn da nichts rüber kommt bis auf 30mhz ist halt die Frage ob sich das lohnt .
Habe ja auch 4+480Er Radis drin :wink:
Das ding ist halt das den Karten die Spannung ausgeht .
Also VMod oder sowas müsste dann her halten.
Bin Gespannt was Roman sich bei der Aorus Master einfallen lässt!
Er hat da was im Video angedeutet!
Der eine Kollege bei mir im Büro macht den High End Rechner Quatsch noch mit, ich bin ja vor Jahren zu 1080er schon ausgestiegen. Der hat heute seine 4090 FE ins Büro geliefert bekommen. In den Videos kommt ja wirklich null rüber wie abartig groß die Teile sind. Hilfe, das sind ja Welten zu früher. :fresse:
Die Dinger sind mittlerweile auch echt relativ leise, sprich mit ohne WaKü ganz gut zu betreiben.
Keine Vergleich zu dem Düsenjet von einer 1080TI damals. Wirklich ruhig, aber auch extrem riesig 🤪
Wobei größer nicht immer besser ist. Hatte eine 3080TI Aorus mit Display etc., die 3090 FE ist leiser obwohl ne Spur kleiner.
Na "evc2" ;)
Ähnliche Themen
