• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@SH
jetzt wollte ich mal schauen, wo Du bei Port Royal liegst. Aber mir werden da gerade gar keine Ergebnisse angezeigt in der Hall of Fame. Also die Listen sind komplett leer.
@all
3dmark-Server tot? Ergebnisse bekomme ich auch keine hochgeladen.
Noch kein Port Royal gemacht. Aber schau mal Superposition 4K
auch wenn es kleinlich erscheint: handeln ist im luxx nur im marktplatz erlaubt!
den bedingungen hat jeder bei der anmeldung zugestimmt.
Schade ist das so was nicht per Software geht wie bei AMD/:
AMD war auch limitiert in der V dann kamm der XTH Chip mit 1,25V anstatt mit 1,2.
Bei der 4090 kann man max von 1,05 auf 1,1V
Wäre nett, ja...
Kann mich auch nicht erinnern, dass das jemals bei NV ging
Was waren das noch Zeiten, als ich an zwei 8800 GTX Ultra´s ein 10-Gang-Poti gelötet hab :d
(eine hab ich so geschrottet)
Solltest du mal...
Da spielt die CPU keine Rolle
Mit igors more Power Tool kann man die Spannung anheben bis die Karte raucht;)
Wäre nett, ja...
GTX980TI konntest du das Bios selbst bearbeiten sogar die V
Die 6900XT war doch gelogt auf 1,2V oder gab es später eine andere Version?
Aber tracken kannst du sie hofffentlich schon
Meine soll am Sa. kommen. Eigentlich egal, da ich eh erst So. Zeit hab :-)
Tracking funktioniert und das Paket landet in der Packstation, da ich sowieso immer von Freitag- bis Sonntagnachmittag nie zu Hause bin.
Habe es da nicht so eilig wie manch anderer hier mit dem Umbau.
Die Dinger sind mittlerweile auch echt relativ leise, sprich mit ohne WaKü ganz gut zu betreiben.
Keine Vergleich zu dem Düsenjet von einer 1080TI damals. Wirklich ruhig, aber auch extrem riesig 🤪
Wobei größer nicht immer besser ist. Hatte eine 3080TI Aorus mit Display etc., die 3090 FE ist leiser obwohl ne Spur kleiner.
Roman hat der Aorus schon zu gesprochen das sie Etwas leiser ist wie die Founders
Ich hab gestern nach der Arbeit ca. 17:00 mal nach Grakas geguckt - wollte eigentlich die Preisentwicklung von 3080ern sehen und hab zufällig die 4090er gefunden - wusste garnicht, dass die gestern gestartet wurden. Zu demZeitpunkt waren diverse Grakas lieferbar - ich hab ganz entspannt ne Asus TUF bei Asus bestellt - und nun sehe ich, dass hier wieder das Gleiche abläuft wie bei den 30X0 :(
Hab eben die Versandbestätigung für die Graka bekommen :) AM5 Mobo von Asus kam gestern, genauso wie ein 7950X. Nun hoffe ich, dass der Speicher, den ich hab auch läuft. Dann kann am Wochenende gebastelt werden.(y)
Hat hier jemand schon (s)eine Gigabyte Gaming OC verbaut? Wie ist das Spulenfiepen/-rasseln so?
Hat er ja, ich kenne das Video, dann müssen die aber was am Kühler gemacht haben im Vergleich 3xxx zu 4xxx
Ja die wurden alle Überarbeitet der von der FE ja auch!
Die Master hat laut Roman 13 Heatpipes *Vaporchamber.
Bloody hell. Also diese Grafikkarte einzubauen hat mal keinen Spaß gemacht. Obwohl ich bei der Verschlauchung großzügig war und bisher alles locker gepasst hat, musste ich diesmal mehrere Schläuche und zwei Laufwerkskäfige temporär entfernen, um das Teil überhaupt irgendwie reinmanövrieren zu können. Vertikaler Einbau mit Riser war trotzdem unmöglich, jetzt habe ich sie erstmal horizontal drin mit 2-3mm Luft hinten :fresse: Also den Versuch brauchbare Luftkühler zu konstruieren in allen Ehren, aber die ATX Spezifikationen zu reißen ist auch nicht der Weisheit letzter Schluss. Ich kaufe mir doch kein neues Gehäuse nur für solch einen LuKü Scheiß :wall: Wenn das bei der nächsten Gen so bleibt, muss man sich ernsthaft überlegen auf Karten mit fertig montiertem Block zu warten :shake:
Anyway, habe im neuen Treiber gerade zum ersten mal das hier gesehen:
Jemand ne Idee ob man das aktivieren sollte? Für Gaming aber wahrscheinlich komplett irrelevant?
@Kiesel76 für den Preis einer Strix würde ich die Karte nicht behalten, manchmal spielen sich die Spulen etwas ein, wenn es nach paar Tagen immer noch deutlich hörbar ist würde ich die Karte retournieren und mein Glück bei einer anderen Karte probieren. Dann bin ich echt mal gespannt wie meine TUF sich morgen schlagen wird.
Das 12VHPWR-Kabel von be quiet ist vereinzelt auch schon im Handel gelistet, allerdings wird das wohl nichts mit kurzfristiger Verfügbarkeit. Meh. Warum haben die nicht selbst einfach mehr von dem Kabel über den Ersatzteilshop verkauft...
Ich wär gespannt, ob da bei Deiner Karte die gleichen Taktraten gehen wie jetzt in den anderen Benches, die Du schon gepostet hast.
Superposition 4k hab ich gesehn.;)
Gigabyte hat sich bei den 3000er Entry-Level Karten (Windforce, Gaming OC und co.) alles andere als mit Ruhm bekleckert, aber die AORUS Master waren ganz okay.
Schlägt sich sehr gut die kleiner Gaming OC von Gigabyte gegen die RTX Strixx.
Die Aorus Master wird da noch ne schippe drauf packen!
Ähnliche Themen
