[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hier vielleicht auch für die Luft Kühlungs Fraktion Interessant !
Sollte man nicht unterschätzen die 450-600W Biester!
Da müssen manche so richtig in die Tasche greifen Grafikkarte +NT+ Gehäuse
Das Torent scheint da über alles erhaben zu sein bei Luft Kühlung
ENDLICH! https://www.nvidia.com/en-us/geforc...6/geforce-rtx-40-series-power-specifications/
Man braucht kein neues Netzteil für die 4000er Reihe. @Don
Since announcing the GeForce RTX 40 Series we’ve seen an uptick in questions about power and whether your existing systems are compatible.
GeForce RTX 40 Series does not require a new power supply if you already meet the PSU wattage recommendations (more below). The graphics cards come with a power adapter to ensure compatibility with existing power supplies. We have rigorously tested the power adapters across a wide range of conditions.
Answers to common questions are below, including PSU wattage recommendations for each card, the lifetime number of reconnections, and more.
Common Questions about RTX 40 Series Power Supply Compatibility
Do I need to upgrade my PSU for the RTX 40 Series?
The RTX 40 Series doesn’t require a new power supply if you already meet the PSU wattage recommendations. The RTX 4090 TGP is 450 W and the minimum recommended PSU is 850 W. The 4080 16GB TGP is 320 W with a minimum recommended power supply of 750W, and the minimum recommended power supply for the 4080 12GB is 700W.
How do GeForce RTX 4090 and 4080 power requirements compare to last generation?
The power requirements have stayed the same or reduced while delivering substantially more performance. RTX 4090 draws the same power as RTX 3090 Ti, the RTX 4080 16GB draws 30W less than RTX 3080 Ti, and the RTX 4080 12GB draws 65W less power than RTX 3080 12GB.
Do the RTX 40 Series cards require a new type of power connector or a new power cable?
No. The RTX 40 Series cards come with power adapters that allow you to use existing power supplies with existing 8-pin PCIe connectors. The RTX 40 Series cards can also use the PCIe Gen5 power connector which allows you to power the graphics card with a single cable.
If the RTX 40 Series cards can use the existing connectors and power supplies, then why change to a new connector standard?
The PCIe Gen5 power connector is the new standard for PCIe add-in-card power. The standard allows you to power the graphics card with a single cable, which simplifies cable routing and improves airflow inside the chassis, among other benefits.
PCI-SIG warned of potential overcurrent/overpower risk with 12VHPWR connectors using non-ATX 3.0 PSU & Gen 5 adapter plugs. Why did PCI-SIG issue the warning and how does this affect NVIDIA’s new products?
It does not affect NVIDIA’s new products. During early development and testing we identified a potential issue with a prototype connector manufactured from a sole supplier. As a PCI-SIG member, we informed the supplier, asked them to fix it (which they did), and shared our findings to help suppliers who are implementing the new standard. The PCI-SIG was passing along those learnings to other suppliers.
Why is there only a 30 cycle lifetime on these new PCIe Gen 5 connectors?
The 30 cycle spec is the same as it’s been for the last 20+ years on existing PCIe/ATX 8pin connectors, and has not changed with the PCIe Gen5 connectors or power adapters.
Are the RTX 40 Series Adapters “smart” enough to interface with a ATX 2.0 PSU and appropriately regulate the power to the GPU?
Yes. The adapter has active circuits inside that translate the 8-pin plug status to the correct sideband signals according to the PCIe Gen 5 (ATX 3.0) spec.
What’s a ‘smart’ power adapter?
The adapter has an active circuit that detects and reports the power capacity to the graphics card based on the number of 8-pin connectors plugged in. This enables the RTX 4090 to increase the power headroom for overclocking when 4x 8-pin connectors are used versus 3x 8-pin connectors.
If I bend the RTX 40 Series adapter will it cause issues with the connection between my PSU and GPU?
The adapter has been proven to work in a wide variety of conditions. Please follow our compatibility diagram: plan a minimum of 1.4” or 36mm clearance above the top of the graphics card for cable bend and airflow clearance.
Should I be concerned if my PSU only has one power rail available to connect my graphics card (i.e. only have 1 power connection available)?
Please connect the original power supply output connectors and cables directly to the included power adapter. Power supplies typically only supply up to 2x 8pin PCIe connectors per output cable. RTX 4090 and RTX 4080 16GB require at least 3x 8pin PCIe connectors or a 450W or greater PCIe Gen 5 connector.
RTX 40 Series: Prepare your system
Wie gut das bei meinem Case beide 280mm Radiatoren Frischluft ansaugen können und diese direkt rausblasen ;)
So, wir bekommen für ganz europa genau 10 Stück 🤣🤣🤣, 5 trio, 5 suprim x
D.h. einfach 1-2 Monate warten, was in Ordnung ist. Nochmal tue ich mir den Aufwand, wie bei der 3090 oder DDR5 nicht an :d.
Katastrophe, dann wäre halt noch die Frage, ob das nur für die Customs gilt oder die FE auch so knapp ist?
Ja ich denke auch, dass es wie bei den X670E Boards sein könnte, manche sind zuhauf auf Lager und manche sind nur in wenigen Stückzahlen verfügbar gewesen.
Hat vielleicht auch einen kleinen Vorteil wenn man an keine Karte kommt, dann sieht man zumindest noch was AMD bringt, bevor man schon was gekauft hat.
Obwohl ich bei Navi31 noch sehr sehr skeptisch bin, gerade die Treibergeschichte und der Auslastung.
Ich denke dass einige Händler direkt vom Hersteller beliefert werden ala Notebooksbilliger, daher kann der Stock vielleicht doch größer sein
Ok das würde erklären, dass man hier möglicherweise in Kürze Vorbestellen kann:
NBB hat jetzt die 4090 Kategorie um Asus Karten erweitert, keine echten Schnapper :d
Immerhin kostet die OC-Version nur 16Euro Aufpreis.
Hmm, bis jetzt nur Asus mit 2x HDMI2.1, dann muss es dieses Mal wohl ne Asus Karte werden
Bei den 3000ern hatten alle Gigabyte-Karten 2x HDMI, bei den 4000ern leider nicht mehr.
Leider kein DisplayPort 2.0, wird wohl doch ne Arc A770 werden ;)
Wie ich prognostiziert habe, die Custom-Karten a la Strix und Suprim werden ab 2300€ losgehen. Mit Wasserblock landet man irgendwo bei 2500€, das ist schon derbe.
Im Januar hätte die Karte jeder mit Kusshand angenommen. Egal ob Mining oder zocken :) Also passt alles. 80% mehr Leistung als eine 3090 TI und 200-300% RT Leistung passt vom Preis für mich.
Ansonsten halt eine 4090 Founders für 1949 Euro nehmen. Macht man auch nicht viel falsch und die Karte kühlt richtig gut!
Bin mal echt gespannt wer alles ein Reference PCB nutzt, würde gern den Alphacool Block direkt zum Launch draufpacken.....
Wo gibt's Karten mit Wasserblock? :eek:
Ja selber montieren. Die Dinger kosten auch 150€ bis 300€.
Ansonsten hier :
Wahrscheinlich wie bei den 3000er, Gainward, Palit, Inno3D, KFA, PNY
Man kann sich alles schön reden aber ich weiß wie es ist wenn es hart juckt :d
Finde die TUF zu teuer im Verhältnis zur Strix aber gut für die Strix Liebhaber.
Ziemlich sicher die Einsteiger Karten wie die MSI Gaming für 1950 + 160€ für den Alphacool Block bist du dabei.
Diese Generation wollte ich mir den Umbau gerne sparen, da der Luftkühler hier eh nur im Schrank liegen würde. Hoffentlich kommt die Inno3D nicht all zu spät.
MSI Gaming also deiner Ansicht auch? Bei der 30er waren Gaming und Suprim ein extra Block. Die Frostbite ist nice aber dürfte doch noch ne Ecke mehr kosten als die 1950 + 160?
Ähnliche Themen
Antworten
6K
Aufrufe
381K
