[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ist das Teil mal hässlich!
Das sollte bestimmt mal ein Turnschuh werden :ROFLMAO:
Kommt mir irgendwie bekannt vor. 286SX25-Zeiten. Bei den Zotac Karten hilft nur Tüte drüber oder WaKü-Block.
Was ich mich frage und sorry wenn es eine dumme frage ist :)
Wenn Karten Hersteller XY einen 3Pin Adapter beilegt, was passiert wenn ich mir nen 4Pin Adapter besorge. Knallt die Karte mir dann durch ?
Würde nur den Adapter nutzen, der bei der jeweiligen Karte dabei ist.
In den Vorstellungen der 40er Karten haben sie gesagt, dass die 4090 stark beschnitten ist und es noch eine 4090Ti und möglicherweise auch eine Titan geben wird. Bei mir ist es jeden Tag, an dem es neue Infos zu den Karten gibt, immer ein Auf und Ab mit dem Interesse an der 4090. Ich müsste mich mal überwinden und die Karte nicht sofort zu Release haben wollen.
Ja ich frag halt deswegen, weil ich ja noch hoffe das BeQuiet für mein Dark Power 12 1500 nen kabel rausbringt. Und da müssten ja "eigentlich" dann auch unterschiede bei sein. Zwecks wenn es nen 3 pin adapter ist brauch ich dann nen BeQuiet Kabel für 3x PCIE , oder gibts dann nur ein generelles Kabel mit 4x PCIE usw usw :)
Also der Adapter, welcher benötigt wird, sollte bei jeder Karte dabei sein. War bei den 3090Ti auch so und da die Hersteller um die derzeitige Situation wissen, sollten die das im Interesse des Kunden denke ich immer dazulegen.
Vermutlich wird die Karte genauso laufen wie mit dem 3x8Pin. Ich gehe eh davon aus das die 3x8Pin Karten das PT nicht auf 660Watt erhöhen können. Out of the Box.
600W max werden sie laufen. Genau genommen sollten sie knapp 598W laufen. Also 133% PowerTarget. Also so ist es auf jeden Fall bei der Founders :)
Bonus (Aus dem OC UK Forum)
Denkt ihr, dass man die 4090 mit pcie 3.0 noch gut Befeuern kann ohne Leistung zu verlieren? Hab hier noch ein 8086k mit einem z390 Aorus Master. Plan ist 4k zu spielen. Möchte nicht vor Meteor Lake aufrüsten, weil die CPU ja reichen sollte.
Ich denke nicht, dass du aufrüsten müsstest.
Bis zu 10% Verlust sind möglich.
aber die Karten kommen doch mit pcie 5.0 oder nicht?
Da könnte ich mir vorstellen, dass es mehr wie 10% sind ...
10% ist ziemlich hoch gegriffen. mMn
10% mumpitz ..... 2 zu 3 macht auch nu einen nicht merkbaren unterschied ..... ich würde mal behaupten selbst wenn du die karte in einen x8 statt x16 steckt wirste kaum was merken ....
Nein, nix PCIe5 old 4 :)
Ich habe geschrieben bis zu 10%, d.h. in manchen bzw. wenigen Games möglich.
[/URL]
Es kommt halt drauf an ob das "mitgelieferte" Bios die 133% einstellen kann oder nicht. Bei den 3x8Pin wäre es ja gut möglich das es nicht geht ohne BiosFlash.
Der Bykski Block ist schon ein alter Hut 8-) . Kann man in DE schon vorbestellen.
Erstens kommt die 4090 mit PCI E 4.0 .
Zweitens habe ich letztens schon geschrieben zu Holzmann , dass ich bei der 3090 bei PCI E 3.0 schon nur eine Bandbreiten Nutzung von 7-12% habe im Gaming . Habe das seit Monaten im Overlay mit eingefügt . Der höhere VRAM sollte auch behilflich sein . Also mache mir bei der 4090 keine Gedanken und behalte daher den 10900K.
der größte mumpitz sind die winzigen 12 pin stecker ersmtal, dass mehr watt duch weniger kabel gehen . der querschnitt bleibt gleich aber die anzahl der kabel weniger, dazu sieht es auch scheisse aus. so konnte man schöne gesleevte kabel in reihe dort einstecken. nun hat man bescheuerte adapter von 12 pin auf 3 x8 oder 4 x8 pin ..... ohmann ..... leider sind wirklich ALLE neuen karten mit diesem blöden 12 pin ....
also wenn es unter 10% wären, wäre das ja gar kein Problem. Dann könnte ich ja bis Meteor warten. Dachte halt nur das wenn die 4090 jetzt zb die volle Bandbreite von 4.0 nutzt, bei 3.0 dann über 50% verlust wäre.
Irgendwo hatte ich gelesen (ich meine nVidia FAQ zu dem Stecker) das die Spezifikation für die Kabel einen Querschnitt von 15 AWG vorschreibt (alt 16). Somit größer. Und gesleevte Kabel kann man auch schon ordern.
Danke, hatte auch schon etwas Sorgen wegen meinem PCIe 3.0 Riser-Kabel. Leider gibt es von Fractal Design noch kein aktuellere für mein Meshify 2.
deswegen findet man auch immer mehr bilder und videos von verschmorten 12 pin steckern :d klappt gut ! man hätte einfach auf 3 oder 4 - 8 pin gehen sollen
Erstens kommt dir 4090 mit PCI E 4.0 .
Sehe ich ähnlich behalte auch meinen 10900er der reicht noch dicke aus. Ist schließlich ein nativer 10 Kerner und der läuft auch mit 5 Ghz, PCIE 3 ist von den FPS zu vernachlässigen.
Na dann poste die mal. Sind mir nicht bekannt die Erfahrungsberichte.
Edith: Hier das Nvida-Faq zur Stromversorung
auf die schnelle
ab minute 9 !
Ich meinte eigentlich UserBerichte und nicht eine "Berichterstattung" über die Meldung der PCI-SIG
Ähnliche Themen
