[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Dieses Problem war aber locker vermeidbar. Maße waren bekannt. Zollstock und Maßband sollten in jedem Haushalt vorhanden sein und sorgfältig messen ist doch nicht so schwer. Die Maße waren schon Tage vor dem Launch hier im Startpost vorhanden, man hätte sich also in Ruhe vorbereiten können. Oder hattest Du keinen Zugang zu Deinem Gehäuse in der Zeit?
Natürlich weiß ich dass ich 26, Max 33cm Platz hab und deshalb ne FE möchte ;) Aber es hilft ja nix, wenn nur diese Riesenteile deren Kühler ich dann eh nach zwei Wochen im Schrank verstauen verfügbar sind. Immerhin, das Asus PCB ist kurz, das passt dann zumindest mit Wasserkühler. Muss ich halt vorher ohne Gehäuse aufbauen. Mainboard wieder ausbauen bääh...
Aber vielleicht klappts ja noch mit der FE. Lieg noch zwei Wochen in der Sonne, dann wirds ernst 🤣
Es wird langsam.
Also echt.. manchmal wünsche ich mir ein Mainstream-System ohne Wakü und mit nur einer SSD. Irgendwann reichts mit der Bastellei.
Aber jetzt gehts. Juhu. Passt, Wackelt, und hat keine Luft.
Hat jemand schon diese rote LED bei der TUF ausgeschaltet bekommen und hat jemand sie in Signal RGB steuerbar gekriegt ?
hier wird nicht gehandelt, dafür gibt es den marktplatz!
habe keine lust hier sperren zu verteilen deswegen ;)
@SH
kannst du den hinweis noch in den threadtitel aufnehmen!
Die tuf led ist sehr pfiffig verbaut. 🤣
Und die stütze ist ein witz. Passt nichtmal farblich. Mein alter halter passt nun gar nicht mehr drunter.
Es wird langsam.
Staubputzen xD zum Glück habe ich Staubfilter sonst sah mein PC auch immer nach paar Wochen so aus. Bohr sieht das Mega aus die Graka ist gefühlt so groß wie das Gehäuse
Funktioniert der MSI Afterburner wenn ja welche Spannung habt ihr gesetzt ? Wenn ich das so sehe was in Games anliegt sollten 0.85 locker für 2800 MHz ausreichen.
Nicht wundern das Bild war mitten im Umbau, Ständer plus Strom fehlen auf dem Bild.
Hast Du Dir vorsorglich schon mal die neueste Beta gezogen?
Hatte ich auf den letzten Seiten irgendwo verlinkt.
@Zock
Meine TUF ist heute auch gekommen, ist zur 3090 Suprim noch mal in alle Richtungen ein Stückchen größer.
Hab nicht viel Zeit zum Testen, muss noch zur Nachtschicht gleich.
Den Brocken erstmal nur so reingeworfen Die Kabelpeitsche nervt gewaltig, muss man direkt 90° am Stecker biegen sonst geht das Fenster nicht zu.
Bequit Leitung ist aber schon bestellt. Hoffentlich taugt das mehr...
Kann die leichte Spannungserhöhung im AB nicht freischalten, weiß jmd. woran das liegt?
Die Gainward ist zum glück nur ca 3 cm Länger als die RX6800Xt TuF und ca fast 1 cm dünner.
Frage an die bequiet straightpower kenner. Habe nur 1 y kabel dabei.
Habe 3x pcie anschlüsse.
Am pcie3 ist die cpu.
An pcie 1 habe ich nun das ykabel
Und an pcie 2 ein einfaches kabel.
Somit ist der 4. Stecker der tuf leer.
Wie habt ihr das gelöst?
Ähnliche Themen
