[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Komplizierter vertikaler Einbau im Fractal Design Meshify. Die Karte ist zu breit, stößt am Rahmen an und lässt sich nicht richtig festschrauben. Egal, Riser etwas locker gemacht und mit Draht dabei. Wo sind wir denn hier.
Anhang anzeigen 802476 Anhang anzeigen 802474 Anhang anzeigen 802473 Anhang anzeigen 802475
Kein Spulenfiepen, auch sonst alles Top bisher. Gebencht wird später ;)
Achso, Powerlimit der TUF non-OC ist auch bei 600 Watt.
Non-OC bei 600W PL? :oops:(y)
Aber 45MHz weniger, als die TUF OC - richtig?
Warum so heiß auf die Karte? ich mein, ich finde die auch geil, aber hast du einen speziellen Grund?
Ich hoffe, dass sie die Software für das Display mittlerweile in den Griff bekommen haben. Meine erste 3080 Master hatte mit dem Display echt große Probleme. Konnte nichts steuern und dann ist das Display irgendwann eingefroren und hat immer das selbe angezeigt.
Sorry wenn das schon beantwortet wurde, aber es ist sehr schwer bei dem Tempo hier mitzulesen :fresse:
Kann man mehr Spannung freischalten? Mit dem Afterburner geht nicht mehr als 1.1V auf der Suprim, das reicht leider nicht um das Powerlimit auszuschöpfen und 3 GHz gamestable zu bekommen.
Hat jemand von euch mit der Suprim X schon die RGB Steuerung hinbekommen? Dieses MSI Center will, wenn ich dort Mystic Light installiert, habe meine GPU anscheinend nicht erkennen. Ich bin mir nicht mal sicher ob Mystic Light richtig installiert ist. Total blöd das man da extra dieses Center für braucht. Eine separate RGB Steuerung wäre besser gewesen.
MSIMysticlight ist das letzte Drecksprogramm. Jeden Tag hab ich nen anderen Bug mit dem Mist. Vermeide ich jetzt wie die Pest.
MSI Afterburner hab ich erst vor Kurzem runtergeworfen weil ich mit manchen Games Probleme hab. World of Tanks startet z. B. nicht wenn das läuft. Manche Games lassen sich zwar starten aber nicht mit OBS livestreamen wenn es läuft.
Doof dass ichs jetzt wieder installieren muss weil mein Netzteil nur 750W hat und ich erstmal nur auf 70% laufen lassen will.
die OC und die non OC sind bis sie fertig montiert sind die gleichen karten. selektion kommt hinterher, aber dann flasht da niemand dran rum - die weniger guten kommen halt in den non OC karton.
tobi
Bei nur +45MHz wird wahrscheinlich nichts selektiert. Das schafft die grottigste GPU
Anderes BIOS drauf und fertig - zack 300€ mehr Deppenzuschlag kassiert
Bis zum Wasserblock erstmal provisorisch drin. Meine hat zum Glück kein wahrnehmbares Spulenfiepen. Besser gehts nicht. (y)
Könntest Du mir mal einen Gefallen tun und messen wie weit es vom Slotblech bis zum Stromanschluss ist? Nur wenn es nicht zu mühsam ist, muss auch nicht super genau sein, würde mir aber bei der Planung helfen.
macht ihr mal mit euren netzteil experimenten ;D
Ich halte mir ehlich gesagt auch schon mindestens ein Auge zu bei dem was da teilweise abgeht ;) Wenn ich mich in Grenzbereiche bewege, dann nur wenn ich weiss wie groß die Reserven sind, wo sie genau liegen, was ich zur Risikominimierung tun kann und wie die Konsequenzen aussehen. Aber hier ist teilweise viel "Yolo" unterwegs, da bekomme ich Gänsehaut ;) Ich bin wirklich dankbar für mein üppig überdimensioniertes AX1600i
Wieso hast du nur 1 Y-Kabel?
In dem fall würde ich das Y-Kabel an PCIe2 anschließen und die beiden Solo-Kabel an 1 und 3, damit dürfte eine gleiche Verteilung vorliegen
Keine Ahnung. War wohl nur 1 dabei. Ohje. Jetzt wieder doch anders. Jeder erzählt was anderes. Jetzt habe ich
das einfache kabel an Pcie1
die Cpu an Pcie2
und das y kabel an Pcie3
Also um die RGB zu steuern habe ich ein 2tes Windows. Die Software von Asus müllt dir das System komplett zu. Und wenn die mal nicht funktioniert. Was oft vorkommt. Dann bekommst du den Fehler nicht mehr weg.
Jo. Deswegen auch Signal RGB. Kann das RAM und die mainboard RGB Header erkennen und angeblich alle alten TUFs. Bloß diese findet er nicht
HDD Käfig ist draußen? Wenn deine TUF passt, müsste meine Windforce auch passen.
Ne. HDD Käfig ist drinnen. Aber die beiden festplatten sind unten so dass die GRAKA drüber geht. Dachte zuerst ich bekomme die wegen der Käfigblende gar nicht rein. Aber geht.
Knapp 24cm
Muss ich für die 4090 die neueste bezahlversion von HWinfo nehmen? Bis zur 3090 ging noch die kostenlose 6.42.4360
die Cpu an Pcie2
Verstehe eh nicht wie du das angeschlossen hast. Die oberen Anschlüsse sind doch für die PCIe-Kabel, du hast irgendwie das P8/P4-Kabel in die PCIe-Buchse gesteckt
Die Aorus Master scheint wohl keiner bekommen zu haben?
Hier im Forum sehe ich auf Anhieb nix und auch auf YT testet die bis auf der Bauer kaum wer.
Na mal schauen ob ich die reingekommen. Hatte extra die suprim liquid genommen, da die anderen Karten bis auf fe zu lang sind. Jetzt könnte es jedoch mit dem Radio Einbau knapp werden.
Hoffe auf nen baldigen Block zum bestellen.
MSI RTX 4090 Suprim X 8K
Lg
Meine 4090 FE ist angekommen und ich kann die Frage beantworten, wie viele Karten NBB hatte: 200.
Steht außen auf der Verpackung (Package count: XXX of 200), Total Delivery Quantity: 200.
Das P4/P8 KJabel passt ja nur in einen der 3 PCIE Buchsen? Wo soll es sonst hin?
Oh lol, 200 ist nichts...
Ähnliche Themen
