[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Oh mann, die Moderatoren von Nvidia haben den Beitrag gelöscht! Das hört sich sowas von nicht in Ordnung an, eher, dass die Pumpe im Eimer ist oder der Lüfter schleift. Wenn das wirklich Coilwhine der 40er Serie ist, werden alle ihre Karten zurückschicken :(.
Ich nicht, kann nix hören 😄
der Ton verändert sich nicht nur mit FPS sondern auch mit anliegender Last, 100 FPS 250 Watt höre ich fast nichts, 100 FPS 450 Watt gehts ab :)
Ja der Ton ändert sich mit der angelegten Spannung, deswegen ist undervolting auch so effizient dagegen.
öhm ...
Wie kann es sein, dass die RTX 4090 auch im Windows ein Spulenfiepen zeigt? :unsure:
Die knurrt, wenn einfach Windows läuft, vor sich hin.
Hast du zufällig eine Gainward Phantom? Da brummt der Lüfter
Danke Dir.
Dann ruf ich da im Zweifelsfall noch mal an und frag, wie die das handhaben. Mal sehen, ob die Business-Hotline von denen hilfreicher ist. Ist ja streng genommen tatsächlich zwei GPUs für die ArbeitsPCs. Das darauf auch gezockt wird ist nur Bonus. ;-)
Hab auch bei meiner Suprim eine Finne wo ne kleine "Delle" drinne ist. Dachte das wäre ein Einzelfall aber scheinbar nicht. Bei dem Preis wie du sagst kann man Perfektion erwarten. Spulenfiepen hat meine Karte aber nicht.
So sieht es bei mir aus
Premium Qualität sieht änderst aus
Nach paar Benchmarks und 3dMarks Loops wo die Karte warm wurde, ist das Rasseln bessern geworden .. Karte musste wohl eingefahren werden. :banana:
Komisch, hab die TUF 3080 und das einzige mal dass ich sie fiepen hörte war im MSFS in den Menüs, wo die Frames uncapped sind und auf fast 1000 oder so gehen.
Der PC ist allerdings auch ziemlich zu (Fractal Define R6) und steht unterm Tisch...
meine TUF 3080 12GB die ich jetzt verkauft hatte gab es 0 Spulenfiepen. Hatte sie stark UV und beim spielen war alles flüsterleise. Wenn ich das so sehe. Werd ich bald mit der Intel IGPU des I5 spielen. Scorn läuft da auch mit 720p in niedrig mit 40FPs!
mit UV bekommste die 4090 auch leise, aber das ist eher keine Option für mich :fresse:
Also Ich werde meine Karte nicht wegen Coilwhine zurückschicken, für mich persönlich stellt es kein Problem dar.
Das könnte auch die Erklärung sein, warum das bei den 4090ern soviel deutlicher wahrzunehmen ist als bei der Vorgängerserie, die 4090er werden einfach nicht so warm wie die Vorgänger, ergo weniger thermische Auswirkungen auf die Verklebungen und Lagen der Wicklungen oder ähnliches. Die rütteln sich vielelicht erst noch ein und die Fixierungen müssen erst noch in die Zwischenräume kriechen usw. Ist jetzt nur ne Spekulation natürlich, ich weiss nicht genug darüber die die Spulen aktuell genau konzipiert sind.
Hier mal ein Coil Whine Video meiner 4090 Suprim X. Ist ein kompletter Timespy Bench 1 run mit 100% PT. Besonders am Ende wo die FPS hoch gehen hört man es krass. (Achtung Tinnitus Gefahr)
Joa bei mir ähnlich.. Division 2 macht auch so ein Lärm jetzt nach ein paar Bench Loops ist es aber besser geworden..
Hier mal meine Taktraten und Temps unter Last:
Beim Afterburner ist die Y-Achse der Voltage Curve ja auf 3000MHz begrenzt:ROFLMAO:
Oder hab ich einfach die neue Version vom Afterburner übersehen?
dazu habe ich dann gleich noch Unwinder (Entwickler vom Afterburner befragt):
Lässt sich einfach in der "MSIAfterburner.cfg" anpassen:
VFCurveEditorMaxFrequency
Corsair-Kühler für die FE liese sich nun vorbestellen (Erhältlich in 5 Wochen):
Also bin mit der TUF OC ziemlich zufrieden .
Spulenrasseln hält sich in Grenzen .
Lüfter sehr laufruhig und Kühler gut verarbeitet und kühlt gut . Erste Eindruck und habe auch mal ne gute Stunde 2042 gezockt recht positiv .
Bei Port Royal und timespy Extreme bin ich etwa im Bereich was auch in den Reviews getestet wurde . Normale timespy hatte ich jetzt einmal laufen und meine waren nur 26K
Grafik Score . Hatte das nur einmal laufen . Moment auf Nachtschicht. Vielleicht nochmal checken , aber da ist wohl CPU Limit zu stark . Also benchen kann ich mir vorerst schenken, aber Gaming Performance gut in UHD 👍🏻
  • Danke
Reaktionen: A6
Ich hab bock auf ne Aorus Master.. schade, dass da kaum was kommt von denen.
iwie erhält die auch kaum jemand... KP wer es noch bei NBB versucht hat. Die konnte man ja ca5-10 minuten vor 15:00 Uhr schon in Warenkorb legen. Scheinbar wird aber eben nix geliefert versendet :(
Auch auf YT ist sie eher rar. Hat Gigabyte da was verbockt und konnte nicht ausreichend produzieren/ in Umlauf bringen?
Das ist Time Spy Extreme bei offenem Seitenfenster aus ~20cm Entfernung. Ich hab lange versucht, was hörbareres hinzukriegen, aber... will nicht. :d
Gute Frage.. werde die Tage immer mal wieder schauen eine zu bekommen, vielleicht hab ich ja Glück. Dann würde die Suprim X zurück gehen.
Also nur kurz nochmal zu meinen Problem das ich keine PCIE x16 4.0 auf meiner 4090 Tuf Oc schaffe.
Ich habe die Tuf 3090 wieder iengebaut und die funtioniert sofort mit PCie 4.0,dann habe ich die 4090er wieder eigebaut und trozdem nur PCie 3.0.
Sogar mit dem 4x Adapter statt dem Corsair Kabel .....Tzzzzzz das ich wiedermal so ein Pech habe und eine Defekte Karte erwischt habe??
An die TUF Besitzer, war bei euch auch keine Folie auf der Karte außer an der Slotblende? 😅
Ähm auf der Slotblende und auf dem runden Teil der Lüfter war Folie bei mir .
EKELHAFT - Aber Danke für die Info...
Die Luft wird echt Dünn, für ne 4090 ohne Coilwhine die man mit Garantie auf Wakü Umbauen kann...
Kann die Verzweiflung wirklich so groß sein, dass ich zur Inno3D frostbite greif?
Die wirds genau so haben. Wer hat erwartet dass bei dem Verbrauch weniger Geräusche/Schwingungen emittiert werden.
Wenn man zwei Ampere her nimmt mit quasi identischem PCB/VRM RTX 3080 vs RTX 3090, welche davon erzeugt absehbar die geringeren Emissionen ?!
Letzendlich wirds man es nur durch UV verringern können bzw. wenn sie länger in Betrieb waren lässt es oft etwas nach.
Einfach 3-4h 3D Mark Ice Storm und schauen ob sich ein Effekt einstellt, für Rauchzeichen aus dem PC übernehme ich keine Verantwortung. :LOL:
Ähnliche Themen
