[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Zum Thema Rückgabe/Umtausch bei Alternate. Da würde ich persönlich aktuell eher vorsichtig sein. Ich gebe meine Asus Rog Strix 4090 einfach nur zurück. Da aktuell keine Karten vorliegen kann sowieso kein Austausch erfolgen. Die Preise für neue Karten werden vermutlich auch anziehen, da werden sie also die neuen Karten eher teurer verkaufen und du bekommst dann als Tauschgerät maximal einen Kundenrückläufer. Und mein Karte will niemand haben außer man ist extrem schwerhörig oder kann auf welche Weise auch immer Spulenfiepen was schon ab unter 50FPS hörbar ist ertragen. Das dürfte aktuell allgemein ein Problem werden das viele Karten zurück gehen wegen des Spulenfiepen, das man da einen Rückläufer selber dann zugeschickt bekommt dürfte groß sein.
Die kommen gut aus der Sache raus, egal wie es kommt. Die Handvoll Menschen die sich hier tummeln sind nicht der Nabel der Welt. Und dazu kommt das Sie den Schaden wie üblich reparieren werden und fertig. Ergebnis: Karte geht wieder und alles gut.
Du darfst aber nicht vergessen, welchen Einfluss gerade der Enthusiasten Bereich auf die Produktwahl der "Anderen" hat. Wenn hier eine Karte hochgelobt wird, dann kristallisiert sich das schnell heraus und die Karte wird mehr gekauft, als andere Modelle. Schau dir z.B. den Thread Kaufberatung Gaming PC im CB Forum an. Ich würde den Einfluss hier nicht schmälern. Auch hat dies natürlich allgemein Einfluss auf den Markennamen "Gainward".
Man sieht doch ganz gut an anderen Produktgruppen die mehr als so ne GPU kosten das da keinerlei bleibende Schäden aufkommen. Ist ein absoluter Irrglaube.
Dann hast du nie einen BMW besessen. Hier wird sogar noch innerhalb von 5-6 Jahren auf Kulanz getauscht :-). Was für viele auch ein Grund ist genau diese Marke zu kaufen.
Wenn es richtig laufen würde gar keine, aber leider läuft es nicht richtig. Vielleicht bin auch einfach nur ich einer der sich von sowas null beeinflussen lässt. Und ich garantiere dir jetzt schon, das die nächsten Karte die verfügbar ist, trotz dieses "Fehlers" innerhalb von Sekunden weg sein wird. Denn auch hier gilt, es ist nur eine handvoll Menschen in Foren. Viele lesen keine Foren sondern kaufen einfach.
Habe ich nicht, aber mir war schon klar das du einen Einzelfall nennst. Würde ich an deiner Stelle aber genauso machen, immerhin willst du etwas haben das es so nicht gibt auf der Welt. Also musst du dir das natürlich schön reden. Ich kann das nachvollziehen.
Jo da gebe ich dir Recht, dass das momentan aufgrund der Verfügbarkeit keinen Einfluss hat. Allerdings ändert sich dies ja (hoffentlich) alsbald.
Nein ich muss mir hier nichts "schön reden". Ich habe hier lediglich eine Erwartungshaltung. Wird diese nicht erfüllt, gibt es eine andere Karte zu einem anderen Zeitpunkt.
Mal eine allgemeine Frage? . Wird die Rückseite von eure 4090 auch so stark warm bis heiß ?
MSI hat nie Aufkleber an der Außenseite dran. Wieso man glaubt das man nach gradmal 2 Tagen nach einer VÖ eine Karte bekommt die gebraucht war, ist sowieso fragwürdig. Das zeigt eigentlich wie kaputt hier schon manche geworden sind.
Wie kaputt ich bin machst du daran fest, ob ich mir Gedanken mache, ob die Karte schonmal in Gebrauch war? Wo genau ist dein Problem damit? Finds eher bedenklich, dass du auf Hobbypsychologe machst weil ich ne normale Frage stelle, damit ich im Falle einer bereits gebrauchten Karte diese mir genauer anschaue.
Wo gibt's ein how-to Video über das Entfernen des Kühlers?
Zumindest für die FE
Bin auch nach wie vor pissed, weil ich a) keine Custom in mein Gehäuse bekomme und b) von der Optik her auch nur eine FE will.
NBB hat die Stornos mal wieder komplett random ausgewürfelt. Nach all den Infos die wir hier kollektiv sammeln konnten gibt es kein Schema, das in irgendeiner Weise Sinn ergeben würde. Spätere Bestellungen gingen durch, Zahlungsmethoden egal, sogar Bestellungen über die NV Seite wurden storniert etc. :eek:
Bin schon versucht eine vom Scalper zu kaufen...
Mir geht es hier tatsächlich genauso wie dir. Aufgrund von Länge und Design habe ich mich für die FE entschlossen und keine andere, schade allerdings dass es dafür diesmal aufgrund von RNG nicht geklappt hat. Lootbox halt. Vielleicht gibt die andere Lootbox(Nvidia Geforce Experience Auslosung) mir einen special link für eine FE die wahrscheinlich dann auch storniert wird weil "lol, lmao"
Karton hatte keine Aufkleber aber die Karte war versiegelt in der Folie. Reicht doch.
Verstehe hier die ganze Aufregung auch nicht. Einige veranstalten schon allein ein heftiges TamTam nur über die Zustellung und meinen jedes Update posten zu müssen. 🙄
Frage an die Suprim X Besitzer: war euer Karton von aussen mit einem Aufkleber o.ä. versiegelt? Oder konntet ihr ihn direkt nach oben aufklappen ohne einen Aufkleber zu entfernen?
Wollte ich auch fragen...
Beim Herausnehmen aus dem Versandkarton wäre mir fast der Kram aus dem Suprim-Karton gefallen :d
Verstehe hier die ganze Aufregung auch nicht. Einige veranstalten hier schon allein ein heftiges TamTam nur über die Zustellung und meinen jedes Update posten zu müssen. 🙄
Wir wollen doch, dass du dich mit uns freust :d
Legitim und in Ordnung. Wenn du ein Problem hast und das sitzt, dann kaufst du woanders. Das kannst du verarbeiten wie du willst. Aber du solltest nicht glauben das ein Hersteller jetzt den Schwanz einzieht nur weil er deine viel zu hohen Forderungen nicht akzeptiert.
Für den ganzen Spam gäbe es ja eigentlich einen geeigneten Thread, dann könnte man sich hier auf die "technischen" Dinge beschränken.
Wäre sicher einer besseren Übersichtlichkeit/Darstellung zuträglich.
Was meint ihr, kommt vor dem Release der 4080 16GB am 16.11 noch ein FE drop?
Sorry, aber kannst du bitte versuchen bei der Sache zu bleiben? Hier hat niemand behauptet, dass die Erwartunghaltung diese ist, dass der Hersteller den "Schwanz" einzieht, sondern, dass kundenfreundlich umgetauscht wird. Come on...
Was dieses Geforce Experience Auslosung angeht, ich bin grade dabei einem Kumpel der nun doch unbedingt eine FE will ein Installer für eine VDI zu bauen. Da sind schnell mal 128 vPCs in der VM hochgezogen mit Geforce Experience Account. Einzige Vorraussetzung damit es klappt sind natürlich nvidia Karten die vGPU unterstützen.
Vielleicht ist das ja ein Denkanstoß für den ein oder anderen der auch unbedingt eine FE möchte.
Deine Ansicht und die Tatasache das du dich bereits das dritte mal dafür rechtfertigst. zeigt das du durchaus die Erwartungshaltung hast. Hast du sogar geschrieben im ersten Beitrag.
Geil! Mit wieviel Volt bist du auf die 3,1 gekommen? Meine schafft knapp 3 Ghz mit 1,1v aber alles im grünen Bereich, hatte nur den Wunsch die große 3 zu knacken und das passt ja. Vram geht bei meiner TUF non-oc ganz gut, +1500 läuft. Karte hängt an einem Pcie 3x Riser Kabel, aber scheint ja für die Performance wenig auszumachen. https://www.3dmark.com/3dm/81017180?
In der Speed Way Hall of Fame kommen ein paar Namen sehr bekannt vor :LOL: https://www.3dmark.com/hall-of-fame-2/speed+way+3dmark+score+performance+preset/version+1.0
@SH @TobiWahnKenobi @Brainscan1979 @Holzmann @Don @Dampfkanes
#10 😘 freut mich einfach für dich!
#40 Raffster ist übrigens er hier
@Dwayne_Johnson Im Benchmark nimmt sich die TUF schon bis zu 500W
Dieselben Setting wie bei dir, hab so einen Takt gar nicht erwartet da ich im Silent Bios war, soweit in Ordnung. Tatsächlich rennt mir die Suprim mit den Takt und den Voltages dann aber auch ins Power-Limit 520 Watt werden erreicht.
1. Nein, dann ist die Nachricht bei dir fehlinterpretiert.
2. kannst du bitte die richtige Verwendung von "dass" und "das" erlernen.
3. ich bin raus!
Ich freue mich ja auch für jeden der eine 4090 ab jetzt sein Eigen nennen darf.
Aber diese ständigen Statusupdates von Karte X jetzt zum Zeitpunkt Y an Standort Z haben nicht im Geringsten etwas mit dem Threadtitel zu tun.
Ähnliche Themen
