• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
wie funktioniert das? Ein paar von meinen Kumpels sind natürlich auch an der FE interessiert
Musst dich vermutlich für den NV Newsletter zur 4090 angemeldet und GeForce Experience installiert haben.
@Dampfkanes
Habe gesehen, dass du mit dem MSI Afterburner DEV gesprochen hast. Weißt du, wie das jetzt geht mit der Voltage und bringt es was? :)
Also ich konnte nur eine in den Warenkorb packen.
Vielleicht können ja andere mehrere hinein packen keine Ahnung. 🤷‍♂️
oder man kauft dann beim nächsten drop wieder eine.
Ich bin 100% Gamer und hab nix hier ;)
Steam Account mit über 100 Spielen und über 1000 Stunden, auch schon ein paar Jährchen alt der Account...und Geforce Experience Account von 2017, aber das letzte Jahr lang nicht installiert...NACH der Meldung mal eben installiert :d
Ich habe auch noch nix von Nvidia bekommen...
Aktuell bin ich bei UV 0,900 mit 2600Mhz +500 (15 Metro Runs auf Extrem 4K alles max). Höchstverbrauch waren 320W.
Gibt es noch einen besseren Test oder ist Metro noch verlässlich?
Wenn es noch Drops geben wird. Könnte auch sein, dass Nvidia ihre FEs jetzt nur noch Invite only raushaut.
Würde ich Nvidia irgendwie zutrauen, zumindest solange keine allgemeine Verfügbarkeit gegeben ist.
ich ehrlich gesagt nicht, da entgeht umsatz.
die karten müssen doch raus.
Solange die Nachfrage mit Invite-only groß genug ist, werden Sie das vermutlich beibehalten.
Find ich persönlich keine schlechte Sache, so kann NV seine treuen Kunden belohnen und man hat keinen Stress an die Karte zu kommen.
Wäre auf jeden Fall fairer als das alte System.
So sieht die Priority Geschichte aus:
Und anschließend landet man auf ner individuellen Campaign-Page über die man die Karte in den Warenkorb bekommt.
Weil meine Bestellung aber gerade in Bearbeitung ist, steht da nix:
Bei PL vorsichtig sein und bei UV nicht alles 1:1 nehmen.
Jedes Spiel hat einen anderen Strombedarf. Bei Cyberpunk frisst mit RT viel und die SSs (Screenshots) von @EleCtricStream waren zudem innerhalb eines Gebäudes, dort habe ich z.b. doppelt soviele Frames wie außerhalb. Den Verbrauch kann man dort also nicht wirklich messen. :)
Wenn man ein zu niedriges Pl setzt, können einige Spiele einen FPS-Einbruch erleben, während andere keine Veränderungen zeigen. Vorallem nun bei der 4090.
Daher wäre UV ohne PL eigentlich besser, aber dann könnten Spiele unerklärlicherweise nach zufälligen Intervallen absturzen, wenn diese empfindlich sind. Auch das hatte ich mit Cyberpunk 2077. In dem Fall musste ich die Spannung ein wenig anheben, dann lief es ohne Crash. Und trotz starken UVs kann es sein, dass manch Spiel immernoch 350-400W zieht.
Das einfachste Mittel um Strom zu sparen in vielen Spielen ist ein FPS-Limit. Solange das Limit von der GPU erreicht wird natürlich. :)
Am Ende heißt es einfach ausprobieren. :d
Metro ist schon sehr verlässlich aber man sollte immer etwas diversifizieren. Bei der RTX 3090 galt the Division 2 auch als OC/UV Profil Killer.
bezahlung bei NBB aber only kreditkarte right?
Wie testet ihr das Fiepen? Habe bei meiner bei 240fps kein Fiepen gehört, womit kann man testen ab wann es kommt? Gibt es schon Vergleichswerte?
high load + high fps
rocket league uncapped raustabben ist bei mir ganz gut als test :d ist bei epic f2p
aber solange die karte bei deinen wunsch fps nicht fiept oder so dass du damit klarkommst, isses egal ob sie bei 250 fps nervt
Hab mit PayPal gezahlt, meine Bestellung am 12. und die erste mit Invite-Link wurden jedoch beide mehr oder weniger instant storniert.
Hab jetzt meine zweite Bestellung mit Invite über PayPal Express gemacht und die ist jetzt seit ner halben Stunde in Bearbeitung :fresse2:
abtrittserkärung möglich und vom händler akzeptiert? dann kann man das schon machen, gerade wenn die nicht fiept. sofern duz für ne gamerock 2200 bezahlen willst
Gerade bei #eBayKleinanzeigen gefunden. Wie findest du das?
Hier gibt es einen der will sie losfahren
Lg
Einfach ein bis zwei Wochen chillen und eine Karte beim Händler kaufen.
Lass die EKA Boys auf ihren Karten sitzen,gibt vielleicht einen Lerneffekt für die Zukunft.
Schon 'ne feine Sache! Wird man denn auch per Mail benachrichtigt oder muss man tatsächlich immer mal bei Experience schauen?
Würde mich interessieren, nach welchen Kriterien die das überhaupt verschicken oder ist es komplett Random🤔
oder auf die glocke warten.
Ich hatte eine 3080FE und eine 3090FE. Beide hatten fiepen...allerdings war die 3080FE nur am fiepen, wenn sie kalt war. Und die 3090FE hörte auf zu fiepen, nachdem die einiger Zeit eingebrannt war. :d
Ich habe auch gelesen New World soll ein guter Stresstest für eine GPU sein...so gut sogar, das die Fetzen geflogen sind...
Das ist echt krass, ich frag mich was die Board Partner davon halten. Mittlerweile ist die FE so gut dass es kaum noch gute Gründe für Custom Karten gibt und jetzt noch dieser direkte Vertriebsweg über den Priority Zugriff. Gefühlt muss die Luft doch immer dünner werden.
wie lang ist die fe nochmal?
Diese Mail hier kam bei mir am Donnerstag um 14 Uhr rein:
Hab ich aber ignoriert, weil da von Best Buy die Rede war und ich dachte das wäre nur was für die Amis.
die boardpartner sind faul 2x 120er auf den kühler zu schnallen und die karte fiepfrei zu machen.
Manche haben wohl das Geschäft sogar hingeschmissen. :unsure:
Ähnliche Themen
