[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ist die Artikelnummer der FE via GFE bestellt immer noch: „A 996979“ ?
Nein, ist ne andere als bei der Bestellung von Mittwoch. Bei mir war es jetzt die "A 997429".
Könnte mir vorstellen, dass das unverkaufte Kontigent dann im Verlauf der nächsten Woche gedroppt wird.
Ich würde mal vermuten die bekommt man geschickt, wenn man sich für die RTX 4090 Benachrichtigungen auf der NV Seite angemeldet hat.
Evtl. fließt auch noch die GPU die man im Rechner verbaut hat mit ein, bei mir war das halt ne RTX 3090 FE.
Dito bei mir auch!
Danke!
Ich glaube gar nicht, dass die droppen. Die Links aus den Invites sind bis Montag 15 Uhr gültig. Ich denke eher es wie neue Invites geben.
Die Liste der Leute die nen Invite bekommen werden ist aber endlich, da kein Sign-Up mehr möglich ist.
Also wenn in paar Wochen die Liste durch ist, wird's auch wieder gedroppte 4090er FEs geben.
jetzt weis ich nicht ob ich mich da angemeldet hatte. bei der 4080 16 kann ich mich noch anmelden.
Hat denn jeder der einen Invite bekam, sich auch vorher für die Notification angemeldet?
Ich hatte mich damals für die Notification zur 4090 auf der Nvidia Homepage angemeldet, bisher kam noch nichts ;) Bei meinem Glück wird's dabei auch bleiben, fürchte ich :d
Hab's aber auch nicht eilig, von daher: Viel Erfolg bzw. viel Glück an alle, die eine FE haben möchten, zeitnah, eine Einladung für ebenjene zu erhalten!
Was für ne Karte hast du bei dir im PC verbaut bzw. bist du bei GeForce Experience überhaupt angemeldet?
dass ich GE erst nach der Nachricht installiert habe, da ich das eigentlich nicht benötige.
Daran wird es vermutlich scheitern, da NV da ziemlich sicher vor dem raussenden der Mails entsprechende Datenanalyse betrieben hat.
Da gehe ich auch ganz stark von aus.
Und wer ne AMD im Rechner hat der bekommt schon mal gar nichts.:ROFLMAO:
Habe meine Suprim X gerade durch diverse Benchmarks gejagt (Ergebnisse muss ich noch zusammenstellen). Jedenfalls geht sie recht problemlos über 3 GHz, ab 3.060 MHz fängt es an schwierig zu werden, bei 3.150 MHz scheint dann endgültig Schluss zu sein, höher geht sie nicht.
GPU geht auf +200 - +280 je nach Benchmark, MEM kann ich auf +1500 setzen, absolut problemlos. Ich bin begeistert.
Spulenfiepen habe ich auch getestet. Musste mir erst mal die Videos hier anhören um zu sicher zu sein das auch das gleiche Geräusch gemeint ist. Ja, meine fiept hörbar. Wenn man das Ohr ans Ggehäuse hält. Keine Chance das durch meine Gehäuselüfter durch zu hören. Für mich absolut kein Problem.
Temperaturen und sonstige Lautstärke auf dem Level der hier normal ist. Lüfter habe ich mal auf 100% gedreht um zu testen ob da seltsame Geräusche sind aber nein, einfach nur Sturm im Wald, alles ganz normal. Ansonsten sehr leise.
Darf man fragen woher du das Corsair Kabel hast?
Direkt von Corsair am Tag wo es das erste Mal verfügbar war. Die waren direkt ausverkauft nach ein paar Stunden oder so. Sollen aber wieder welche kommen.
Warum hast du auch so ein kleines Case?
Wieso hast du so ein großes Case? Ich bekomm in meinem 15l Gehäuse auch ohne Probleme nen i9 und ne 3090 FE gekühlt und muss mir so auch nix unter den Stehtisch stellen.
3090... bei GE im Normalfall nicht angemeldet; 2017 irgendwann mal registriert. Wie gesagt, würde mich wundern wenn da was käme, weil ich's im Prinzip nicht benutze.
Bei Spiderman funktioniert VSYNC in Verbindung mit VRR/GSYNC und DLSS3. Es vermeidet jegliches Tearing. Im Falle meines OLED, der 120Hz schafft, darf ich dann nur nicht an die 120Hz herankommen, denn dann greift VSYNC ein. Dann spürt man auch einen deutlicheren input lag. Bleibt man innerhalb der VRR-range sind es angenehme und perfekt spielbare 49ms. Wenn VSYNC reinkickt sind es 110ms. Ein Frame rate cap via MSI Afterburner/RTSS bringt nichts. Man muss die Settings so hochdrehen, dass man die maximale refreshrate des Displays stets unterschreitet. Reflex muss natürlich an sein.
Du musst nur so weit undervolten, dass du im vrr bereich bleibst.
Cool! Ist voll an mir vorbeigegangen. Welche GPU Länge passt max. rein?
mehr als die strix 3080ti geht nicht. ich stoße quasi vorne an.
die strix passt zwischen die beiden frontfans. oben 140. unten 120
wenn das nur klappt wenn man sich per mail hat benachrichtigen lassen ist das leider eher für die katz denn ich weiß es nicht ob ich mich da eingetragen habe.
Da bin ich ja jetzt mit meinen Torrent für alles gerüstet. Hab gefühlt noch 15cm Platz bis zum Front Lüfter und die Scheibe ging trotz Adapterkabel locker zu.
Na ob das der Grund alleine ist weiß ich leider nicht. 🤷‍♂️
Das wäre von nVidia dann ein Bullshit Versuch Gamer und jahrelange Nutzer von nVidia Karten damit auszustatten. Nicht jeder installiert diese Müllsoftware...
Nach einem Tag mit der FE kann ich nur gutes berichten. Kein Spulenfiepen, Max stabiler Takt bei 3120Mhz (leider kein golden Sample 😆) und Ram läuft ohne Fehler mit 1500mhz mehr. Standardmäßig verbraucht die Karte um die ~400Watt (Programmabhängig). UV bei 900mv und 2670Mhz (RAM +1557Mhz) hat die Karte einen Verbrauch von ~280Watt und ca. ~5% mehr Leistung als im standardbetrieb ohne Hand anzulegen. Andersrum bei 1,025v und 3030Mhz (RAM +1557Mhz) hat die Karte ~10% mehr Leistung zu standardbetrieb bei ~390Watt Verbrauch.
Man hat Entweder ~110% Leistung bei 97,5% Verbrauch oder ~105% Leistung bei 70% Verbrauch. Für mich ein nobrainer und die Karte läuft jetzt UV mit 900mv 🤙
Zu den temps muss ich denke ich nix sagen. UV war die Karte bei 40% Lüfter Leistung nach ner Stunde zocken 56 grad 🤟
Ich denke die nutzen die Software nur zur Benachrichtigung.
geht bei jemandem von euch die support seite?
da kommt nur gulasch bei raus.
ticket erstellen klappt gar nix. da öffnet sich nur eine andere seite.
Ähnliche Themen
