[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Werde meine Suprim wohl leider am Montag zurück schicken, weil das Coil Whine viel zu krass ist.
Heftig, meine Suprim ist klasse für mich. Bei 240fps hört man sie auch aber nur wenn man ans Gehäuse geht, keinesfalls durch meine Gehäuselüfter hindurch beim Zocken. Und da habe ich zudem immer KOpfhörer auf. Kann Dir nur die Daaumen drücken das es mit der nächsten besser wird, aber ich habe ehrlich gesagt meine Zweifel.
Werde meine Suprim wohl leider am Montag zurück schicken, weil das Coil Whine viel zu krass ist. Eben paar Runden Overwatch 2 und Doom Eternal gezockt mit 240FPS am 240hz Monitor. Da meint man wirklich ich hätte ein Hornissennest im Rechner. Es spielt keine wesentliche Rolle ob ich undervolte oder Watt limitiere. Normalerweise schicke ich Grakas nicht zurück wegen Spulenfiepen, sondern biete sie dann eher Privat an, auch mit dem Risiko von Verlust. Allerdings kann ich MSI ihr irreführendes Marketing diesmal nicht durchgehen lassen. Die Karte schafft es locker in meine Top 3 der schlimmsten coil whine Grakas ever. Es bleibt ein reines Glücksspiel je individueller Graka und ist nicht übertragbar auf die Serie oder Hersteller.
Du musst beim zocken auch mal den ton einschalten! Glaube kaum, dass man es dann noch hört. Oder ist dein gehäuse aufm tisch und voll mesh?
du glaubst gar nicht wie laut sowas werden kann
und gerade weil die gpus wegen dem dicken kühler und der effizienz so kühl bleiben und damit auch leise ist das mehr als kagge.
spiel mal ein schönes SP spiel mit lautsprecher. mal was ruhiges. eine graka die sich totpfeift ist der größte immersionkiller
Hattest du schon mal eine GPU mit richtig heftigem Coil Whine? Da spielen Ton und Kopfhörer keine Rolle, das ist so ein penetrant nerviger Ton, dass man wahnsinnig wird.
Ehrlich gesagt nicht. Jede erste gpu habe ich behalten. Und ich bin ziemlich störgeräusch sensibel. Nur ein netzteil hatte mal gezirpt wenn die graka powerte.
z.b. anno, cities skylines wo du nebenbei musik hören willst oder nen stream nebenbei laufen lässt und dann kreischt da unten die gpu um ihr leben.
hätte ich keinen bock drauf
Du haust Heute ja echt dicke Tipps raus Danke. Beim nächsten Beitrag schlägst du mir wohl vor mein Hörnerv operativ entfernen zu lassen?
Die Karte soll sobald ein Block zur Verfügung steht unter Wasser. Ich habe 2 externe Moras, von meinem PC hört man sonst sogut wie nichts.
Wenn man ein Silent PC hat, will man sowas einfach nicht in der Dimension hinnehmen. Das es auch anders geht, weiß ich ja. Meine 3090ti gibt kein laut von sich.
Wieso schmiert es? Muss ich mal testen wenn ich wieder nächste woche zuhause bin. Hardware unboxed oder df sagte ein framelimiter erzeugt krasses rucken bei fg.
Ich teste es gleich nochmal, und versuche Bilder zu machen. Bin aber gerade nicht zuhause
Ich wundere mich nur, dass hier viele über coul whine jammern. Das kommt mir dann so vor als wenn sich hier manche die suche nach der perfekten karte zum hobby machen. Bisher hat bei nie eine gekreuscht. War aber auch bisher nur bis 120hz unterwegs.
Was mich gewundert hat. Bei scorn 1440p. 48 Grad 800Mhz und 110W bei 1440p. Dachte das Spiel ist neu aber Wahnsinn. Die Karte ist echt ne Wucht.
Gleicher Verbrauch wie meine 3080 aber doppelte Leistung bzw. manchmal mehr 🤓♥️
Ich werd die Karte wohl behalten.
Wie sieht’s bei euch aus? Behaltet ihr eure Karten? Bei mir ist das Spulenfiepen durch UV fast weg.
Habt ihr ähnliche Erfahrungen?
Ich behalte meine tuf bis ich evtl. Eine fe bekomme. Scorn hat ja auch keine fordernden grafik gimmicks. Ist so flat wie doom.
Definitiv behalten, komme auch von ner 3080 und durch Verkauf dieser hat mich die 4090 effektiv etwas unter 1,3k gekostet 🤙 (man kann es sich auch gut reden 😂)
Roman hat ja auch festgestellt, dass UV etwas schlechtere Performance bringt als die Reduktion des PL. Hier auch nochmal ein Video dazu:
Jeder Mensch ist da auch individuell empfindlich. Was für die eine Person störend ist, macht der anderen Person garnix oder nimmt es gar nicht erst wahr.
Deshalb ist einzig und alleine das eigene Gehör entscheidend und weniger die Eindrücke von anderen Personen.
Ich will nicht wissen, bei wievielen die meinen ihre wäre leise, es für andere Leute aber störend hörbar ist. Deshalb stößt das Thema bei vielen auch auf Unverständnis.
Roman hat nur ein quick check gemacht. Guck mal tech city oder wie der heißt. Gibt auch andere videos die den vorteil von uv beweisen.
Naja, ich warte auf weitere Quellen. Aber werde wahrscheinlich sowieso beim PL bleiben, bin zu faul ein UV einzurichten für evtl. minimal bessere Ergebnisse.
Für den einen oder anderen ggf interessant bzgl NVIDIAs Weg zum Realtime ray tracing
Bei meinem testen bin ich auch zu dem Schluss gekommen das UV besser ist, ich kann mir aber vorstellen, dass das nur daran lag weil ich ram mit übertakte. Wahrscheinlich hat Bauer den RAM unangetastet gelassen🤷
Hatte hier im Forum bisher stumm mitgelesen, mir nun aber wegen der Palit Gamerock Theamtik doch mal einen Account gemacht. :d
Meine Karte hat ab der niedrigsten Lüfterstufe (30%) schon so ein Motorengeräusch, das ich bisher von keiner Grafikkarte oder anderen Lüftern kannte. Durch das geschlossene Gehäuse ists nicht so extrem, aber bei niedrigen Drehzahlen schon nervig. Trotzdem bin ich unsicher ob das der Defekt ist von dem ich hier immer las.
Habe mal ein kurzes Video gemacht. Leider etwas rauschig durch die Luftzirkulation.
Wäre mega wenn jemand bestätigen kann ob sich das für die Karte normal anhört oder wirklich defekt ist. Würde mich dann Montag mal bei Mindfactory melden.
Ansonsten ist die 4090 von der Leistung echt heftig:d
Nach einem Tag mit der FE kann ich nur gutes berichten. Kein Spulenfiepen, Max stabiler Takt bei 3120Mhz (leider kein golden Sample 😆) und Ram läuft ohne Fehler mit 1500mhz mehr. Standardmäßig verbraucht die Karte um die ~400Watt (Programmabhängig). UV bei 900mv und 2670Mhz (RAM +1557Mhz) hat die Karte einen Verbrauch von ~280Watt und ca. ~5% mehr Leistung als im standardbetrieb ohne Hand anzulegen. Andersrum bei 1,025v und 3030Mhz (RAM +1557Mhz) hat die Karte ~10% mehr Leistung zu standardbetrieb bei ~390Watt Verbrauch.
Man hat Entweder ~110% Leistung bei 97,5% Verbrauch oder ~105% Leistung bei 70% Verbrauch. Für mich ein nobrainer und die Karte läuft jetzt UV mit 900mv 🤙
Zu den temps muss ich denke ich nix sagen. UV war die Karte bei 40% Lüfter Leistung nach ner Stunde zocken 56 grad 🤟
Mit was hast du übertaktet? Afterburner? War das Gehäuse offen?
Das Programm habe ich und ich schaffe nur 12,6 Gbit hab ich schon getestet.
Heute nochmal den Treiber mit DDU deinstalliert,beim neustart ohne neuen Treiber hab ich im GPUz x16 4.0 auslesen können.
Dann Geforce Experiense mit neuen Treiber installiert und die 4090 hat wieder nur PCIe 3.0.
Langsam gehen mir ale Ideen aus denke wirklich schon da ses an der Karte liegt.
Bios Reset gemacht. ggf ne alte SSD rumfliegen und auf die mal schnell Windows schmeißen um auszuschließen dass bei dir nicht inen Tool da was verändert hat.
Ja und ja (um genauer zu sein hab ich kein Gehäuse sondern ein eigenbau)
Bin vor nem Monat ins eigene Haus gezogen und PC hängt nicht mehr an der Wand. Momentan sieht es provisorisch noch so aus 😅
Warum gibt es hier so Unterschiede beim Max Power Limit?
Im OC Forum schreiben sie davon, dass Asus derzeit wohl Karten binned und eine eigene "Kingpin" Karte releasen wird!
Sie binnen 4 verschiedene Qualitätsstufen und nur die letzten Beiden werden wohl für die Strix OC/non OC verwendet. Das würde die ähnliche Leistung der TUF/Strix erklären.
Der vorteil bei uv ist ja auch, dass die karte kühler bleibt und der ram mehr oc verträgt.
@cHio wie ist die TUF die du bekommen hast? Ich muss ehrlich sagen das ich hin und weg von meiner bin, habe ganz vergessen wie leise so ein System sein kann.
Schon heftig mit den ganzen Suprims hier, war eigentlich meine Wunschkarte.
Weiß nicht wie lange es her ist als man von den Kingpin Karten noch ein echten Performance Vorteil hatte...aber es ist lange her.
Bei den letzten Kingpins hat man genau der gleichen Chip Lotterie unterlegen wie bei jeder anderen billo Karte auch. Wenn du Pech hattest hat die günstige Palit deine Kingpin komplett zersägt. Da haben dann auch eine Mio Phasen nix dran geändert.
Selbst wenn ASUS, anders als EVGA zuletzt, starkes Binning betreibt, von was sprechen wir da? 50-100Mhz mehr als der Durchschnitt? Die Karten werden nur interessant sein wenn sie das Voltage Limit von 1.1V überbieten können und man ein externen Power Mod fährt.
Die Serie hat nämlich sonst nurnoch einen Zweck, den dummen Leuten noch mehr Geld aus der Tasche zu ziehen.
@Matadil kam Heute noch nicht dazu.
Ist ja alles interessant aber bei seinem Vergleich fehlt einfach die Gegenüberstellung der Performance zu Powerlimit. Er vergleicht nur Stock zu UV/OC. Interessant wäre zu sehen wie es sich mit PL verhält und das lässt er völlig außer Acht.
@Dampfkanes
Habe gesehen, dass du mit dem MSI Afterburner DEV gesprochen hast. Weißt du, wie das jetzt geht mit der Voltage und bringt es was? :)
Mit der Version 4.6.5 Beta 2 vom 15. September ist dann der "Core Voltage"-Regler nicht mehr ausgegraut.
Bei Port Royal musste ich bei meinen Tests am Donnerstag etwas runter gehen bei den Offsets (Core: +180 VRam +300) im Vergleich zu vielen anderen Benchmarks (Core: +200 +300), damit es stabil durchlief.
Heute mit erhöhter Spannung lief dann auch Port Royal mit +200 +300.
Für 3,5% mehr Takt (laut 3dmark-Log) gabs aber nur 0,8% mehr fps.
Ich hab dann noch 3dmark Speed Way gebencht. Hier hat sich das Ergebnis sogar leicht verschlechtert.
Ich habe mir dann die effektiven Taktraten in Relation zur angezeigten Taktrate angeschaut:
Mit erhöhter Spannung ist der angezeigte Takt um 60MHz hochgegangen, während der effektive Takt nur um 18MHz gestiegen ist.
Und das sind jetzt nur die Max-Werte vom Benchmarklauf.
Wenn man sich über ein Logging alle Werte während des Zeitraums, in dem Last an gelegen hat (im Screenshot ist auch der Zeitraum dabei, bei dem der Benchmark nur geladen hat), auswertet, schauts vielleicht noch ungünstiger für die Spannungserhöhung aus.
  • Danke
Reaktionen: SH
Ähnliche Themen
