[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe meine nicht lieferbare Bestellung bei CU storniert und anschließend wurde eine Karte wieder als Lieferbar gelistet.
Wie geht denn das?
Warum hast Du das nicht vorher ausgemessen? Meine Kaufentscheidung wurde maßgeblich von den Abmessungen mit beeinflusst. Also habe ich sorgfältig gemessen gerade weil es so knapp war und dann passte sie wie ein Handschuh.
Es gibt unvorhersehbare Probleme und es gibt leicht vermeidbare Probleme ;)
Ich Yolo das...sollte die FE nicht passen, also das PCI-E Kabel :d, dann suche ich nach einem Adapter, Winkelstecker oder neues Gehäuse. Hab da bei allen dreien schon was im Auge...
Richtig eine flache Linie und keine Kurve mehr
Ich hab bei Afterburner ein Profil mit -500mhz damit fang ich immer an, sobald ich im Editor ein Voltpunkt hochziehe ist danach alles flach (durch die -500 vorher)
Man soll eigentlich nichts hochziehen sondern via Offset auf Zieltakt bei Zielpunkt und dann nur runterziehen und die Linie begradigen lassen. Sonst gab es beim Curved Editor schon immer einen Leistungsverlust, auch bei Ampere. Einfach mal in den damaligen Sammelthreads gucken, da wurde das zu Hauf besprochen.
Habe gerade eine TUF OC getestet... die sollte Retoure gehen, da ein Kollege ne TUF aus dem ASUS Shop ergattert hatte.
Die TUF OC macht 2745 / 2760 vs 2685 / 2700 non OC.
Ein bisschen mager für den bitteren Aufpreis...
Ist das Stock?
Mich würde interessieren, was die TUF OC maximal in TimeSpy Extreme macht
Meine non OC macht stock 2780
Er munkelt, dass Nvidia möglicherweise zu viel Geld für GPU und Speicher verlangt und Palit deswegen diese freche Budget-Karte raushaut.
Oder das Palit darauf spekuliert, dass die Leute die Karte trotzdem kaufen, weil die Leute froh sind, überhaupt eine zu bekommen.
Was hatte sie nochmal gekostet?
Die TUF Non-OC hat einen Budget-Preis - wie fällt da das Fazit über PCB und Teile aus?
Falls es wen interessiert: Der ASUS Shop hatte heute, beim Redrop der OC TUF, 4 Karten in Stock.
Lohnt sich eine RTX 4090 mit einem Ryzen 3700X für Gaming in 1440p? Bremst dort dann nicht eher die CPU?
Ich bin mir am Überlegen nun günstig eine 3090 zu holen (im Moment habe ich keine Grafikkarte) und dann eventuell später auf eine eventuelle RTX 4080 TI zu wechseln (zwischen der 4080 und 3090 scheint es ja noch viel Platz zu geben) und dann eventuell einen 4K QLED Monitor zu holen oder den Samsung Odyssey G8.
Werden die einzeln per Brieftaube importiert? Sind das nicht normalerweise ganze Containerladungen?
Wie kommen denn solche Zahlen zustande, Asus wird sich ja kaum selber per einzelnen Karten beliefern 🤔
Mfg
Kiryu
Die bremst dich nicht die gpu
Erreicht deine cpu deine Wunsch fps kannst du jede gpu reinknallen
Ist die trotz erreichen deiner Wunsch fps nicht ausgelastet, ist das dein Bier.
Settings hoch oder nächstes mal weniger graka Power kaufen. Mit der cpu hat das nichts zu tun denn du hast ja deine Wunsch fps erreicht
kommt drauf an wohin du willst.
die leistung der cpu kennst du ja bzw. kannst du ermitteln in den gewünschten spielen.
wie groß dann die differenz zwischen cpu und gpu ist, kann man auch ermitteln und dann weiß man ob es sich lohnt oder nicht.
Ob es sich lohnt, musst Du am besten wissen.
Spiele in 4K-Auflösung dann limitiert die CPU nicht so sehr. Ansonsten abwarten bis der 7800X3D erscheint.
Doch tut sie. Nämlich dann wenn man die settings so weit lockert bis man kns cpu limit knallt.
Man wird ja gerade bei eine etwas schwächeren cpu schauen was maximal an fps geht.
4K ist kein pauschales gpu limit. Schon gar nicht mit ner 4090.
Entscheidend ist am Ende jedoch nur eines. Reichen mir die fps die von der cpu lommen aus oder nicht.
Da saß bei jedem Spiel unterschiedlich ist, lässt sich sowas ohnehin nicht pauschal beantworten.
gwahhh, wer kennt sich mit DHL und Problemen aus?
Meine 4090 die Samstag im Zustellfahrzeug war und kommen sollte und dann nicht kam, verändert ihren Status auch heute nicht... :rolleyes2:
Jeder murks den man bestellt kommt pünktlich, oder früher als geplant, aber das was ich so sehnlichst will weil ich Urlaub habe, bleibt hängen.
Wenn der 3700x z.b 90fps bringt und du die 90 halten willst, dann hast du ein cpu limit. Settings hoch geht ja nur bis zu en 90 fps, also bist du wenn deine Wunsch fps 144 sind, jedoch cpu immer noch limitiert.
Settings hoch bringt im cpu limit natürlich nicht wirklich was.
Mfg
Kiryu
Vielleicht Stornierungen oder Retouren.
Viele haben ja mehrfach Bestellungen gemacht .
Schließe ich mich an. Spider Man Remastered lastet meine 4090 in 4k@120hz nicht aus... die dümpelt so bei 60% rum und liefert auch nur 60-90FPS. Erst DLSS3 und Frame Generation liefert an die 120fps, aber noch immer voll im CPU Limit mit nem 5900X
Komisch. Habe das gleiche Setting. Bekomme auch nur 80-90 FPS nativ in 4k. Aber die gpu läuft auf 99%. Also ist die GRAKA ausgelastet.
Bei Alza kann man ne Phantom für den ersten November mit einem guten Preis vorbestellen
Vielleicht für jemanden interessant, welcher noch keine abbekommen hatte..
Alza bietet noch andere Karten an
Ähnliche Themen
