[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich gratuliere jedem, der eine 4090FE bekommen hat...aber ich will auch eine. :(
Wieso ruft Nvidia mich nicht an...
weil es Zufällig ausgewählt wird, stand in der News zumindest.
damit bist Du ja auch nicht alleine.
ich hatte mich auch für die Benachrichtugung zur 4090 damals eingetragen und habe einen Account und die Experience Software aktiv.
habe auch nichts erhalten bisher, ich möchte auch gerne eine kaufen, wird schon klappen auf dem ein oder anderen Weg.
ich kaufe auch keine andere Karte, ich möchte eine FE weil ich mit der 3090 sehr zufrieden war.
Stimmt aber. Das liegt daran, dass der Video-Clock direkt an der Voltage hängt. Das lässt sich (noch) nicht manuell einstellen. Daher hast du trotz UV+höherem Takt vs. reduziertem PT+niedrigerem Takt auch identische Performance bzw. mit letzterem sogar bessere. Weil dadurch die Voltage und dementsprechend auch der Video-Clock höher ist als wenn du die Voltage manuell senkst.
Verbrauch und Effizienz steigen mit UV aber natürlich trotzdem noch beachtlich.
So ist es. Die Karte ist sehr gut darin im zur Verfügung stehendem Power Limit sich selbst effizient zu steuern. Das gabs bei Ampere so noch nicht. Nur auf die GPU Clock gucken gehört der Vergangenheit an.
Nach einem Tag mit der FE kann ich nur gutes berichten. Kein Spulenfiepen, Max stabiler Takt bei 3120Mhz (leider kein golden Sample 😆) und Ram läuft ohne Fehler mit 1500mhz mehr. Standardmäßig verbraucht die Karte um die ~400Watt (Programmabhängig). UV bei 900mv und 2670Mhz (RAM +1557Mhz) hat die Karte einen Verbrauch von ~280Watt und ca. ~5% mehr Leistung als im standardbetrieb ohne Hand anzulegen. Andersrum bei 1,025v und 3030Mhz (RAM +1557Mhz) hat die Karte ~10% mehr Leistung zu standardbetrieb bei ~390Watt Verbrauch.
Man hat Entweder ~110% Leistung bei 97,5% Verbrauch oder ~105% Leistung bei 70% Verbrauch. Für mich ein nobrainer und die Karte läuft jetzt UV mit 900mv 🤙
Zu den temps muss ich denke ich nix sagen. UV war die Karte bei 40% Lüfter Leistung nach ner Stunde zocken 56 grad 🤟
Kann man mit dem Curve Editor auch weniger als 900mv einstellen?
Hier mal ein kleiner Test mit Timespy Extreme mit der 4090 Supreme (nicht auf Punkte optimiert):
Powertarget 100% - GPU Score: 19465 | Gesamt: 15598 | Verbrauch GPU max.: 444W | max. Takt: 2775 Mhz | Temp (Core/Speicher/Hotspot): 71°C | 74°C | 80°C
Powertarget 80% - GPU Score: 18656 | Gesamt: 15152 | Verbrauch GPU max.: 359W | max. Takt: 2775 Mhz | Temp (Core/Speicher/Hotspot): 68°C | 72°C | 77°C
Powertarget 80% + 200Mhz Takt - GPU Score: 19072 | Gesamt: 15390 | Verbrauch GPU max.: 360W | max. Takt: 2970 Mhz | Temp (Core/Speicher/Hotspot): 68°C | 72°C | 77°C
Spulenfiepen höre ich bei keiner Einstellung aus dem geschlossenen Gehäuse raus. Mit offenen Gehäuse ist es deutlich zu hören.
Meins ist Single Rail . Ist praktisch ein Ableger vom Seasonic Prime TX-1000.
Das Corsair soll sogar bis 1350 Watt aushalten können.
Im Menü waren halt 120 Watt GPU und 40 Watt CPU .
Finde ich halt bisschen komisch.
In CP2077 hatte ich 400 Watt GPU und 150 Watt CPU Package Power.
Habe jetzt mal Buchsen getauscht am NT und dann hielt es länger.
Ansonsten probiere ich mal den Nvidia Adapter.
Mal ohne der RTSS/Afterburner Beta probiert?
Das gute alte GTAV ist auch noch immer eine Augenweide. Jetzt neu in 5120x2880 downsampling und Ultra Gras (das hat bisher noch jede GPU in die Knie gezwungen). Läuft mal locker mit 130+fps.
Übertakten und ein pl setzen macht wenig sinn oder?
Leider ging nur 700mv und glaube noch 712mv zwischen 712 und 900mv nur Abstürze. Takt ging noch 2400mhz bei 700mv, hab das aber nicht ausgiebig getestet
Ziehst du auch die ganze kurve runter und ab z.b. 0.75v nach rechts flat?
Naja, warum nicht. Man hat mehr Leistung als wenn man nur PL setzen bei genauso wenig/viel Verbrauch. :)
Richtig eine flache Linie und keine Kurve mehr
Ich hab bei Afterburner ein Profil mit -500mhz damit fang ich immer an, sobald ich im Editor ein Voltpunkt hochziehe ist danach alles flach (durch die -500 vorher)
2400mhz bei o.7 muss wohl abstürzen. Lass mal die kurve wie sie ist u.d mache ab 0.75 nach rechts alles flat.
Was ist los, howt rain, ist immer noch verfügbar bei PC Scalp.
Wow! Das ist schon kurz. Meine gehen Stock bei 66°C an im Silent Bios aber dann schon höher vom drehen.
Hab jetzt ab 50°C-70°C nur 50-55°C Lüfter. Da sind sie schön leise und das reicht eigentlich auch. Sonst würde die immer an und aus gehen und das ist bei der Karte mit das lauteste. Da sie immer ein Brumm machen und dann anlaufen.
ja mal schauen wegen einer Lüftercurve oder sowas das die permanent laufen bei 800 oder was da geht!
Bei welcher fps, auflösung und refreshrate? Und wieviel kann der monitor an refresh?
UHD 120fps All max mit gsync( geht nur nicht). FG allein ohne dlss aber dlaa geiles Bild bei 117fps
Ich geh mal an PC und beweise dir den Gegenteil, genügen 5 Minuten witcher?
Was willste beweisen? Das es bei 0.7 und 2600 abstürzt?
Hast du die 117 in nvcp eingestellt? Ich dachte framelimiter sollen ruckeln bei fg? Sagen df und hardware unboxed.
Wieso geht gsync nicht?
Hast recht der Afterburner übernimmt den edit nicht wenn ich 700mv auswähle nimmt er zwar die max freq von 2,4ghz an aber nicht die voltage (die ignoriert er komplett und fährt standard 875mv).
Ist mir beim Testen nicht aufgefallen weil ich ich nur die machbarkeit einmal geschaut habe und das wie gesagt nicht richtig getestet habe. Dachte er hätte die voltage korrekt übernommen 💩 komisch das die Karte das ignoriert, würde aber wohl abstürzen sonst
Also FG mit gsync habe ich kein ruckeln gemerkt. Wenn ich aber Dlss ein schalte. Schmiert es wie Hölle. Ohne aber TOP Bild. Und ja FrameGrenze in NVCP eingestellt
was ist denn FG?
Ich denke 0.88 v ist minimum. Die nimmt sie sich auch im idle.
Also FG mit gsync habe ich kein ruckeln gemerkt. Wenn ich aber Dlss ein schalte. Schmiert es wie Hölle. Ohne aber TOP Bild. Und ja FrameGrenze in NCCP eingestellt
Du schriebst gerade
All max mit gsync geht aber nicht???
Frame generation
Werde meine Suprim wohl leider am Montag zurück schicken, weil das Coil Whine viel zu krass ist. Eben paar Runden Overwatch 2 und Doom Eternal gezockt mit 240FPS am 240hz Monitor. Da meint man wirklich ich hätte ein Hornissennest im Rechner. Es spielt keine wesentliche Rolle ob ich undervolte oder Watt limitiere. Normalerweise schicke ich Grakas nicht zurück wegen Spulenfiepen, sondern biete sie dann eher Privat an, auch mit dem Risiko von Verlust. Allerdings kann ich MSI ihr irreführendes Marketing diesmal nicht durchgehen lassen. Die Karte schafft es locker in meine Top 3 der schlimmsten coil whine Grakas ever. Es bleibt ein reines Glücksspiel je individueller Graka und ist nicht übertragbar auf die Serie oder Hersteller.
Wieso schmiert es? Muss ich mal testen wenn ich wieder nächste woche zuhause bin. Hardware unboxed oder df sagte ein framelimiter erzeugt krasses rucken bei fg.
Ähnliche Themen
