[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ach dann hab ich mich verlesen mit der Angabe der 4090 zum fiktiven Vollausbau. Dachte es wären mehr als die 12%. Aber bestimmt Platz für ti und titan. Bin gespannt wie sich alles weiter entwickelt. Jetzt muss ich nur noch meinen eigenen Hype unterdrücken.
Etwas Lekütre für Sonntagmorgen. In der direkten Aufstellung sieht auch die 4080 12G gegenüber der 3080 12 GB gut aus. TFLOPS bzw. RT TFLOPS ca. +55% bei gleicher UVP.
Wegen dem Powerlimit würde ich mir keine Sorgen machen. Die werden wohl alle die 660W bekommen. Mit Alphacool habe ich gesprochen, den Wasserblock haben sie bis 800W getestet. Galax 4090 Ti Hall of Fame incoming? o_O
Bis 800W getestet…?
Dann sind 1.000W mit gechilltem Wasser möglich :d
@Dwayne_Johnson
NDA.... aber soviel... der Reference Kühler musste in Tests über 800W wegschaufeln.
Halte ich für machbar. Es werden ja noch Karten oberhalb der 4090 erscheinen. Anbei mal die Karte ohne Inno Branding.
Alphacool_Eisblock_Aurora_Acryl_GPX-N_RTX_4090_Founders_Edition_mit_Backplate_1023221_06.jpg
Zotac legt ja unterschiedliche Adapter bei.
Entweder 3x 8Pin auf den 12/16Pin oder 4x8Pin.
Von daher würds mich nicht überraschen, wenn bei der Karte mit dem Adapter, der nach Spec. nur 450W kann, auch ein niedrigeres Max-Powerlimit hinterlegt ist als bei der Karte, bei der ein 4er Adapter beiliegt.
Langsam wird das Posten des Inno Blocks zum Meme. Hier nochmal für alle die noch nicht gesehn haben wie kurz tatsächlich das Pcb der 102 is
Zumindest können jetzt die Bios ausgelesen und gespeichert werden für Zukünftige Bios Flashes.
Wird ein PT Krüppel sein!
Was hat Inno3d eigentlich mit der karte gemacht um sie unter ihrem Namen zu verkaufen? Die Logistik gemanaged? :fresse:
Ich warte immernoch auf nen "Full Size" Block, kann mich mit dem Alphacool ding so garnicht anfreunden, sieht aus wie ne GTX 970
Also als ich die ichill x 4 hatte ( leider) hatte die 3090 einer der kleinsten PT die es gab. Die Frostbite die danach kam also die 3090 Frostbite hatte exakt das gleiche bios drauf wie die ichill x4. Ich geh auch davon aus das es bei der 40er nicht anders sein wird, und kein größeres PT bekommt. Also referenz im Kleid.
So sieht es aus der Name Frostbite steht nicht für ne super Dupa Karte sondern für ein Ref PCB vielleicht auch FE in der kleinsten Ausführung mit Wakü Block den man sich Fürstlich bezahlen lässt!
Wen überhaupt war es eine Seahawk damals die etwas höheres PT anbot aber immer noch nicht auf dem Level wie eine Strixx.
So richtig tolle Karten mit Wakü Block konnte man sonst noch von EVGA erwarten oder da halt mit Garantie die FTWs fit machen!
Bei Ampere war es ja das Problem das die Referenz Boards nur einen 2x8pin Stecker bekommen hatten. Größere Powerlimits gab es nur mit 3x8pin wie bei meiner umgebauten Suprim. Durch die 12+4 Stromversorgung ist das aber kein Thema mehr.
Dann muss es wohl ne Strixx werden, einen PT "Krüppel" will ich nicht :geek:
Echt Schade das EVGA raus ist....:unsure:
Das wird schön durch das Bios limitiert!Du kannst da auch 6*8Pin haben wenn das Bios das nicht erlaubt dann ist das egal.
Nur weil der Stecker das kann heißt es noch lange nicht das der Rest da mit spielt!
Wird derzeit von keiner Karte verwendet
Vermutlich ist der Yield einfach noch nicht so dolle bei dem neuen Prozess.
Hoffentlich bringt AMD paar starke Karten, damit Nvidia uns nicht erst über ein Jahr nach dem Launch mit einer RTX 4090 Ti oder Titan mit einem (nahezu) AD102 Vollausbau beglückt.
Gab es irgendwo eine Info wie hoch die FE geht? Auf einigen Seiten habe ich gelesen bis 600W sind kein Problem. Das wäre mit persönlich genug. Limit auf 450W via BIOS wäre nicht so toll.
Techpowerup erwähnt es:
While the RTX 4090 operates at 450 W by default, the power delivery capability allows you to increase the power limit up to 600 W for overclocking.
In dem Infomaterial von Nvidia habe ich jedoch nichts diesbezüglich gefunden.
Meine Glaskugel sagt jede Karte kann 660 Watt. Andere Kugeln nicht.
Hi, hatte zufällig jemand die RTX 3090 der verschiedenen Hersteller durchgetestet?
Ich habe die 3090 FE und deren Kühlleistung ist echt super. VRAM i.d.R nicht mehr als 90°C. Das Teil ist ein Backstein und total stabil
Da 4k OLED 120Hz TV werde ich vermutlich eine 4090 anschaffen.
Ich hatte letztes Jahre die 3090 Strix und MSI Trio bei mir und war bzgl. der Stabilität echt enttäuscht. Keine der Karte war wirklich gut gegen Verbiegen der Platine gesichert . Auch die Temperaturen waren nicht wirklich überragend (Kühlkonzept der FE war effektiver im geschlossenen Gehäuse).
Wenn ich mir nun die Gigabyte 4090 Aorus Master anschaue und das ca. 0,5mm Backplate Blech für 2300€ habe ich das Gefühl dass sich da bis auf den teureren Preis nichts ändern wird.
Die 4090 FE wird wieder ein Backstein und super stabil + gute Kühlleistung. Custom Designs halt wieder "wabbelig" und je nach Kühler mal minimal besser oder schlechter als die FE.
Finde es bei den Preisen schon sehr ärgerlich wenn man dann nach 1 oder 2 Jahren verzogene Platinen hat. Bei 2,5k € muss man das doch echt mal hinbekommen (siehe Nvidia FE).
Am Ehesten scheint mir die MSI 4090 Suprim noch was zu werden. Ggf auch die Asus Strix mit ihrer metal frame Konstruktion (da fehlen leider noch weitere Infos).
MSI scheint ja die Kühlerdemontage zu erlauben. Gigabyte hat halt die 4 Jahre Garantie was ich bei dem Preis schon wirklich gut finden (gerade bzgl Wiederverkaufswert) und sie natürlich zum Board passen würde.
Weiß nicht warum alle so geil auf die Anus Nixx nOC Edition sind wenn es so geile Modelle wie eine Suprim X gibt wo die Quality Control besser ist und die Karten schöner aussehen und kein Spulenfiepen haben
Hmm dieses "die-cast metal frame" bei der Strix könnte wirklich noch was werden. Falls nicht nur heiße Marketingluft.
Der Durchlass auf der Rückseite ist gerippt wodurch die Backplate vermutlich selbst auch nochmal besser gekühlt werden wird.
Die MSI Suprim sehe ich gerade scheint leider gar kein Gesamtfame zu haben. Dafür aber zumindest ein Frame direkt auf die Platine montiert wobei natürlich das "Backstein" ähnliche Prinzip der Stix da auf den ersten Blick stabiler wirkt.
Suprim X finde ich auch Mega denke mal die wird auch ein großzügigeres Powerlimt haben als so manch andere Karten.
Im Test konnte der Kühler der Suprim X die 3090Ti schon gut unter Kontrolle halten.
Also, mein Aktueller Plan sieht so aus. FE ( wenn sie die 600W PT bekommen sollte ) mit nem Phanteks WB ( in den hab ich mich nämlich schon verliebt ) :)
Wenn die FE kein 600Watt PT mitbringt, wird es eine Supreme X , aber erst dann wenn es hoffentlich nen Phanteks WB dazu geben wird. Die Strix ist diesesd Jahr raus. Nicht das ich sie Hässlich finde, finde die eigentlich richtig lecker, sondern weil der Kühler eh abkommt und ich aktuell es nicht einsehe 400€ aufpreis zu zahlen. Und es auch echt weh tut, wenn man dieses geile Design auseeinander Baut wegen dem WB. ^^
WB = Waterblock :)
Von Bykski nommt einer.
Ähnliche Themen
