[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Dann ist das deine schuld wenn du deine Wunsch fps nicht erreichst weil du die regler nicht bedienen willst.
Daraus pauschal zu behaupten die cpu wird nicht zum problem ist leider dein Bier.
Wenn er das noch nicht gemacht hat, sollte er das tun
Die spannende Frage ist - braucht man max. Settings überhaupt, wenn man den Unterschied kaum oder garnicht mehr erkennen kann, aber unterm Strich mehr fps rausspringen
Wie bei ampere
Zotac wirft mit Karten um sich die keiner haben will, asus kriegt keine strix raus. Aorus Karten sind Einhörner.
Ach wie hab ich das vermisst
Hallo Leute,
habe seit Samstag eine Palit Gamerock OC. Bin soweit zufrieden, nur dieses Lüftergeräusch bei niedrigen Drehzahlen habe ich auch. Ich hatte auch bei Cyberport eine 4090 MSI Gaming X Trio bestellt gehabt (direkt per PP ohne Login). Auf Mails letzte Woche bzgl. Stornierung wurde gar nicht reagiert. Nun hatte ich heute plötzlich eine Versandmitteilung im Postfach. Meint ihr es lohnt sich auf die Trio zu wechseln? Sind immerhin fast 200€ Aufpreis zur Palit.
Das sind die Art von Menschen die es nicht ertragen können wenn sie einen regler von rechts nach links schieben müssen. 😅
Ich hab familiär und beruflich bedingt einfach keine Zeit um mich mit sowas wie Feintuning zu beschäftigen. 8-)
Jippie...Bestellung im Asus Webshop scheint durch zu sein, einfach zufällig die Artikel auf der Wunschliste in den Warenkorb gepackt und da war sie drin, gab ja nicht mal eine Verfügbartkeitsbenachrichtigung 🤪
Wollte zwar eigentlich keine Tuf OC, aber immerhin gibt es die dort zur UVP, so hat sich das Thema jetzt erledigt und ich kann in Ruhe weiter Fenster putzen 😁
Mfg
Kiryu
Dank Deinem Hinweis hab mir die Karte auch mal auf die Wunschliste gesetzt und konnte vorhin auch eine TUF OC bestellen.
Wie bei ampere
Was spricht eigentlich objektiv gegen die Zotac? Nach Registrierung fünf Jahre Garantie klingt ja eigentlich nicht schlecht, bin mit meiner 3080 Trinity absolut zufrieden.
Top (y)
Idee ist wie erwähnt nicht von mir, haben einige vor etlichen Seiten schonmal geschrieben, aber schön wenn es dir zu ner Karte verholfen hat!
Mfg
Kiryu
Und käsekönig ist wieder leergeräumt.
2 Minuten war das in spidermann. 3d Wolken aus, Sichtweite und Details 1 klick runter.
Cpu und gpu limit angehoben. 118fps ohne 99% gpu load. Optik nahezunidentisc
2 Minuten in tiny tina Wonderlands. Von 100 fps auf 180fps. Optikverlust? Minimal
Das sind Ausreden ;)
Ja es gibt Spiele in denen das settings finden schwerer ist. Bsp wäre da rdr2.
Hallo Leute,
Nimm die Karte, die am günstigsten ist. Die Karten haben alle noch irgendwelche Probleme. Das wird jetzt alles getestet und bei den neuen Chargen hast du dann eine Karte die keine Probleme hat.
Natürlich sinds Ausreden, das ist wie mit den teuren Rennrädern: Die meisten die sich die ultra leichten Räder leisten können sind die, die den Unterschied am wenigsten nutzen. Aber genau deshalb kauf ich mir aktuell keine 4090 außer ich bekomme ein gutes Angebot für die 3090 und eine 4090 für unter 2k.
Wenn ich das so rauslese machen die Karten von Gigabyte, MSI und Asus die wenigsten Probleme oder? Mal von der FE selber abgesehen.
Ne bisher MSI fiept und wird warm, Asus fiept ist aber sonst nice. FE hat Lüfterprobleme und fiept leicht und Gigabyte kA.
Endlich ist sie da! Phantom GS, übrigens keine Lüfterprobleme - zumindest nehme ich nichts ungewöhnliches wahr. Was für ein Monster...
Lass mal hören ;)
Also wieder etwas Lotterie mit 2000+ €... :d
Ich hab auch voll reingelangt in den falschen Eimer am Launchtag😂 FE im Warenkorb - zack weg. Dann auf die Schnelle rumgeschaut und die GS gekriegt und die kreischt aus dem Case raus😵‍💫 dann war nix mehr verfügbar 🤣trau mich gar nicht nochmal zu bestellen. Natürlich hab ich die 3090 schon abgetreten und freu mich dann bald auf die iGPU vom 12700k. Natürlich ist es super wenn die übrigen Karten 14 Tage bei ebay geparkt werden von anderen😬😬😬zu überhöhten Preisen. Bei der Kohle willst schon die Rechnung auf den eigenen Namen. Es ist wie es ist und weiterhin wünsche ich frohes zocken👉👍
Habe eben mit Alternate telefoniert warum sie die Karten nicht als nicht lieferbar Listen. Ich möchte mein Cashback von Gigabyte haben. Aber ohne Bewertung geht es nicht.
Habe Gigabyte angeschrieben die meinten ich soll mich an den Händler melden. Alternate meinte, soll mich an Gigabyte wenden. Da es ihr Problem ist.
Meinte andere Händler Listen die Karte trotzdem und Kunden können sie bewerten. Das kann doch nicht sein!
Ich soll mich noch mal melden. Der muss mit den Einkäufer sprechen.
Ich kann das schon abschreiben. Sind zwar nur 30€ aber ich wollte dir gerne 😮‍💨
Bei Alternate sind derzeit alle Gigabyte-Karten gelistet:
Ähnliche Themen
