[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So die erste MSI 4090 Suprim X mal auf den Testbench geschnallt.
Läuft doch ;-)
nebenbei kann ich kein Spulenfiepen feststellen.
Wenn die 3090 in diesen settings weniger fps produziert als die cpu ist das auch klar. Das heißt aber nicht dass die cpu nicht vpn rt beansprucht wird..Das tut sie nämlich ziemlich stark. Reicht aber in deinem Fall dennoch für mehr fps als die 3090 kann. :)
Jo fakt ist aber, dass ich mit ner stärkeren Grafikkarte mehr fps bei gleichen Settings bekomme.
War das nicht der Fakeshop schon damals bei der 3000er???
Nur Kreditkarte möglich?
Würde da vorsichtig sein. Vor dem wurde beim letzten Mal gewarnt
ich kenne den Shop nicht, so wirklich unseriös wirkt der aber nicht auf mich. Bezahlen ginge per Vorkasse oder Paypal. Die scheinen wohl hauptsächlich Unternehmen zu beliefern und scheinbar auch halt so „Spezialgrafikkarten“ also keine so fürs Gaming. Das ist wohl nur ein kleines Nebengeschäft. Kann aber natürlich auch nicht 100% abschätzen wie seriös die wirklich sind. Tauchen halt aber ganz normal bei Preissuchmaschinen auf. Ich habe sie bei Geizhals gesehen.
Nunja bei einem Gehäuse steht es nicht immer fest. Außerdem weiß ich nicht wie weit ich den Adapter biegen kann, ohne ihn in der Hand zu haben.
Ich hatte zum Glück das Corsair Kabel bereits hie und konnte daher messen ab melcher Stelle ich es biegen muss, damit mein Gehäuse problemlos zugeht. Was etwa 4 cem hinter dem Stecker war. Passte echt alles wie geplant. Ich glaube ich hatte noch nie eine so gute Vorbereitung, welche den Einbau dann so problemlos gemacht hat wie es nur ging. Gute Vorbereitzung ist echt ne Menge wert und erspart viel Nerven.
Also meine 4090 hängt in CP2077 häufig im CPU Limit in 4k RT Psycho, gerade mit RT wird die CPU zum Flaschenhals.
Auch mit der 3090 schon, zwar nicht ganz so häufig aber definitiv vorhanden.
Mit der 3090 hatte ich auf 4k RT nur GPU LImit. Bei der 4090 habe ich noch nicht getestet, das mache ich im Laufe dieser oder der nächsten Woche. Ich habe allerdings auch DLSS Quality aktiviert und mittlerweile RT Psycho aktiviert. Mal sehen wie sich die Kombi aus 7950X und 4090 da schlägt. Der 7950X soll ja in Cyberpunk nicht so optimal performance wie das der X3D oder auch die aktuellen Intels tun würden. Aber mir ist am Ende auch irgendwo egal, der Benchmark hat schon gezeigt, daß ich mich auf flüssiges Spielen freuen kann :) Was für eine CPU kommt bei Dir zum Einsatz?
Echt noch keine mit den Thema Bios flash beschäftig?
Ich wüßte aktuell nicht warum ich es (jetzt) machen soll. Es bleibt immer ein Restrisiko und ich habe nichts zu gewinnen im Moment das es mir wert wäre. Aber vielleicht im Laufe der Zeit.
Würdet ihr die Karte zurückschicken ? Man hört dieses brummen des Lüftermotors durch das geschlossene Case.
Es sind alle 3 Lüfter die so brummen. Im Zotac Reddit Forum sind auch schon andere Leute die das selbe Problem haben.
Im Video muss man die Lautstärke hochdrehen, da es ziemlich schwer ist das brummen aufzunehmen.
Was auch auffällt ist das nicht die Lüfter brummen sondern die Motoren. Merkt man daran, das sobald ich die Lüfter stoppe im AB
das das brummen direkt weg ist, obwohl die Lüfter noch nachlaufen.
Krass, genau so oder zumindest sehr ähnlich hören sich die Gainwards und einige Palits auch an. Von den Zotacs habe ich jetzt auch schon 2-3 Meldungen gesehen. Sehr mysteriös. Meine Gainward hat das im übrigen ähnlich, aber werde die Karte erstmal nicht zurückschicken. Die Alternativen sind aktuell alle schlecht. Bei einem Direkttausch läuft man Gefahr den selben Fehler wieder zu haben oder ggf. noch schlimmer ausgeprägt und dauern tut es wahrscheinlich auch. RMA dauert noch deutlich länger und Geld zurück ist auch kacke, weil man für den UVP Preis den ich bezahlt habe aktuell kein anderes Modell bekommt und über 2K will ich auf keinen Fall ausgeben. Mal abgesehen davon, dass man sich jetzt wieder überall auf die Lauer legen müsste, nur um dann Rückläufer zu kaufen, die dann ggf. wieder andere Probleme wie extremes Spulenfiepen etc. haben.
Letztendlich stört es mich nicht besonders und ist im Silent Bios nicht wirklich auffällig bei mir. Daher bleibt die Karte, weil sie ja ansonsten echt top ist und wenn die 5080 oder 5090 drin ist mache ich ggf. ein RMA.
Ja ok. Aber ich habe mir die 4090 geholt um maxed out zu zocken. Wenn es nur 97fps in 4k sind bin ich mehr als zufrieden.
Das kannst du ja gerne tun aber du kannst darauf nicht von dir auf den rest schließen 🙂
Heute keine Karten, sondern nur Reste von drei Karten beim Proshop und anderswo Null.
Quasi keine Karten.
Asus wahrscheinlich auch nur Rückläufer.
Das was raus geht - sind sowieso nur Rückläufer.
Dazu kommen vllt. noch ein paar Rückläufer wenn die Ebay und Ebay Kleinanzeigen Verkäufer keinen Käufer finden.
Genau so schlimm wie vor 2 Jahren wo ich nur eine Karte bei Mediamarkt ergattern konnte.
Und Nvidia selbst hat sich doch gerühmt so viele Karten auf Lager zu haben.
Davon habe ich auch nichts gesehen.
Na ja, dann warte ich weiter ab.
Horrende Preise zahle ich auf keinen Fall und meine Strix 3090 läuft ja wunderbar.
Dazu die vielen Käufer die über Lüfterprobleme klagen - Spulenfiepen oder Klappern oder ....
Dann die nicht so hochwertigen Kartenhersteller....
Dann heute der Rückzug der kleinen RTX 4080.
Das ist kein Ruhmesblatt für die Hersteller.
Dann sollen von Nvidia ausgewählte Menschen bevorzugt die RTX 4090 FE erhalten.
Und dann die vielen Scalper und das bei diesen Preisen.
Wahnsinn.
Gerade Caseking Gigabyte Aorus und weg.
Was nützt es wenn die Grafikkarten nicht die Leistung der 4090 haben??? Dann würde ich eher auf eine 4090 warten als eine Karte zu holen die in 2022 immer noch nicht 4K mit RT kann.
Nvidia hat die Krone. Sie haben sie sich verdient. Und wer der Boss ist bestimmt halt die Regeln.
Die ganze AUfregerei nervt manchmal.
Ist doch alles easy. Wer Nvidia nicht mag oder dem die 4090 zu teuer ist kauft sie nicht.
Mehr isses nicht!
Den Rest erledigt die Marktwirtschaft von allein.
Falls heute jmand noch eine Karte braucht:
bullshit
niemand hat davon gesprochen das der RX 7000 stärker sein muss als die 4090. alleine wenn die gpu von amd die leistung von der 4080 erreicht gepaart mit einem niedrigeren Verbrauch, ist dies schon eine leistung für sich
amd wird den fokus auf die Effizienz und den Preis legen. das ist schon mal sicher. ich habe selbst die 4090 und trotzdem nehme ich die grüne brille ab. das solltest du auch tun.
also bei deiner Diskussionsgrundlage kann man jede Diskussiom vergessen. da ist die hypnose von der lederjacke ja extrem fortgeschritten
Genau deswegen werden die Karten auch irgendwann Richtung Dezember/Januar verfügbar sein.
Denken viele genauso wie du. Entweder reicht die 3090 noch und gar kein Grund für die 4090 oder man wartet einfach noch 8 Wochen. Man hat ja die 3090
Quasi keine Karten.
Bei Computeruniverse und im ASUS Webshop gabs einen Drop.
Hab mir gerade eine TUF OC im ASUS Webshop ergattern können.
bullshit
Die hypnose scheint bei Dir auch geklappt zu haben. Konntest ja nicht bis zur AMD warten :-)
Asus scheint echt Probs zu haben genug Strix zu fertigen ... zu 97 % isses immer nur die TUF und bisher gabs nur ganz wenige Strixe
Jippie...Bestellung im Asus Webshop scheint durch zu sein, einfach zufällig die Artikel auf der Wunschliste in den Warenkorb gepackt und da war sie drin, gab ja nicht mal eine Verfügbartkeitsbenachrichtigung 🤪
Wollte zwar eigentlich keine Tuf OC, aber immerhin gibt es die dort zur UVP, so hat sich das Thema jetzt erledigt und ich kann in Ruhe weiter Fenster putzen 😁
Mfg
Kiryu
What - wieviel Uhr?
Sofern ich mich richtig erinnere war das bei der 3090 am Anfang auch so.
Ja aber 2022 sollte ja eigentlich alles anders sein ( Ironie ) :ROFLMAO:
Bessere Lieferbarkeit , kein großes Mining mehr , für Scalper unatrakiver weil hoher Startpreis ... aber nunja .. is eigentlich alles genau wie 2020
Die Standart Karten dann und wann mal kurz für 30 sekunden - 1 Minute auf Lager ( wobei grad bei Caseking wohl immernoch welche da sind auch nach 3 min ) und von den Guten Karte Nada.
Habt ihr mal geprüft ob es ggf die Lamellen vom Kühler sind die ab einem bestimmten Luftstrom zu vibrieren anfangen?
Habe das heute an meiner FE festgestellt, Damit hat sich das Problem an meinem Auslasslüfter mit dem "Zirpen" scheinbar erledigt. Etwas die Lamellen gedrückt und dann wars wieder ruhig.
Naja wenn mein ganzer Tisch das vibrieren anfängt, glaube ich kaum dass das nur von den Lamellen her kommen kann.
Schau mal hier...
Hatte noch keine Zeit und Lust dort zu schauen
What - wieviel Uhr?
Laut Bestellbestätigung um 14:08. Wobei mehr als die Bestätigung kam bisher nicht an, aber ich bin mal Optimist 😁
War selbst überrascht, da ich einfach mehrmals täglich versuche, die Karte auf Verdacht vom Wunschzettel in den Warenkorb zu legen.
Und heute ging es völlig unerwartet, also gleich eingesackt.
Diesen Tipp hatte schonmal jemand gepostet, hätte aber nicht gedacht, dass es wirklich klappt.
Laut Store waren auch keine Karten verfügbar 🤷‍♂️
Mfg
Kiryu
So meine Karte von Cyberport MSI RTX 4090 Supreme X ist versendet kommt morgen. :banana:
Habe sie unter UVP bekommen.
Lg
danke nein .. ich möchte mein Geld nich Bunkern sodass ich dann nich mehr drann komme
sondern wenn ich Geld bezahle dann auch sofort dafür was bekommen ... und ich wusste garnich das die Asus Strix nun umbenannt wurde in Phantom :ROFLMAO:
Hier is die Strix von Alza natürlich nix mit vorbestellen und nochichmal ne Preisangabe .. https://www.alza.de/asus-rog-strix-geforce-rtx-4090-24gb-oc-d7439961.htm
Caseking is nun auch wieder ausverkauft .. waren immerhin so 6 min diesmal ... hätten sie die Strix da gehabt hätte ich sogar die 100 Euro mehr ausgegeben aber Asus möchte wohl
noch nich so viele Strixen rausgeben sondern erstmal alles in die TUF reinballern
Ähnliche Themen
