[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
10k€ übrig für Grafikkarten, aber an einer vernünftigen Satzstellung scheitert es schon. Glückwunsch!
Neidisch ;-)
Hatte mir mal nen Paket deutsch gekauft hat aber auch net gehilft ;-)
Hmmm das kann sein aber es gibt dafür auch viele Modelle die deutlich besser gehen … durchgerutscht?
Dazu müssten die anderen die Ihre Karten testen etwas mehr schreiben … eigentlich sieht man sehr einfach in der VF Curve ob die Karten was können.
Wie gesagt, so als Richtwert ne gute Karte hat bei 1,1Volt 2890MHz in der Default V/F Curve und mehr …
ich hab bei meiner Surpim X in der Default Curve bei 1.1V @2865Mhz. Schrott der Chip ?
Pendeln sich dann aber auf 1000 unhöhrbare RPM ein.
Top das klingt mega gut Danke !
Wie gesagt würde da noch gerne was über die Strixx erfahren vielen Dank Leute für den schnellen Input!
Wow echt 600 setzen die ein das ist schön sanft !
Ist wichtig für UV Profil für mich !
Danke!
Hat jemand noch Info zur Strix wie das da ist?
Also ich hab meine TUF noch nie unter 30% (1000 RPM) drehen sehen, vielleicht schau ich aber auch immer zu spät :d (außer der Fanstop halt) (Quiet BIOS, hat das Performance nie gesehen :d)
Ach und Stock Takt bei 1.05V ist 2715-2730 MHz
Von der Performance brauchst DU bei der STrix nicht mehr erwarten. Alles Chiplotterie. Bei dieser Serie entscheidet der Preis oder das Design.
Hat jemand auch gestern ne FE mit paypal bestellt (ohne Kundenlogin) und noch keine AB erhalten? Nur die BB ist da.
Hat das hier schon jmd. gemacht?
Also ich würde gerne auf meiner Suprim ein Strix Bios probieren, um auch in den Genuss von 600 Watt PT zu kommen. ;)
Warte doch lieber ab. nicht zu vergessen das die strixx 2 hdmi ports hat, und ich ned 100% weiß ob das mit ner karte die nur 1 port hat zu problemen fphren kann.
Laut Igor soll doch bald von MSI nen BIOS kommen.
Pass ein bisschen auf! Wenn der sich auf sein Portemonnaie stellt, ist er größer als du.
Alos ich würde gerne auf meiner Suprim ein Strix Bios probieren, um auch in den Genuss von 600 Watt PT zu kommen. ;)
Hab’s nicht gemacht der MSI fehlt ein 600 Watt BIOS total ärgerlich… wie schon immer die riskieren nix bei MSI
Die Chipgüte variiert ja Extreme bei der 4090.
Ich hatte jetzt bereits 3 Strix eine TUF und 2 Suprim X und ne weitere Strix ist unterwegs gerade bei der Strix hab ich jetzt 2 Modelle die keine 3GHz gepackt haben und eine die Default 2985 MHz in ihrer Default Curve bei 1,1Volt drin hat und geht auf über 3.1GHz die andere geht nur bis 2970MHz und Default bei 1,1Volt gerade mal 2805Mhz. Die TUF liegt iwo dazwischen und die Suprime lagen beide bei ~2900 in der Curve.
geht es da um die angezeigten Taktraten oder um die effektiven Taktraten?
Ich habe die Spannungen nicht genau ausgelotet, ich habe einfach die vollen +100mV gegeben und dann geschaut was sie so schafft. Maximaltakt waren dann 3.150 MHz, diese sind aber nicht in allen Benchmarks bzw Durchläufen stabil und mehr habe ich auch nie gesehen. Die Firestikes haben sich aber so zwischen 3.100 und 3.150 bewegt.
3.100 MHz konnte ich noch problemlos durch den Timespy bringen, auch Cyberpunk Benchmark auf 4k RT Psycho mit DLSS Quality läuft stabil bei 3.045-3.075MHz durch.
Gehe ich mit der Spannung auf Stock, dann geht sie mit den gleichen Settings auf 2.965 MHz runter in Cyberpunk, bleibt aber stabil. Mehr Spannung scheint also automatisch ca. 150-200 Mhz mehr Potential freizusetzen, wieviel davon auch ohne Spannungserhöhung geht habe ich ebenfalls nicht getestet, rockstable wäre das dann höchstwahrscheinlich eh nicht.
VRAM ging +1500 auf 1.500 MHz(12.000 MHz), die gehen aber in jeder Lebenslage bisher, auch mit Stockspannung, kein Benchmark oder Spiel ist da bisher abgestürzt oder hat Grafikfehler gezeigt. Das ist ziemlich beeindruckend.
Temperaturen sind deutlich niedriger als bei meiner 3090, die hatte in Cyberpunk über 80°C, die 4090 Suprim ist so zwischen 60-65°C dann. Auch Lüftertechnisch ist sie deutlich leiser als meine 3090 zuvor, vor allem aber weil sie eben niedriger dreht.
Hier sind noch ein paar 3DMark Vergelichswerte zwischen meiner alten und neuen Karte: https://imgur.com/a/R33bQ1Y
Danke für deine Rückmeldung. Ja, ich denke, da sind unsere Karten bzgl. Core MHZ ca gleich. Nur komisch, dass ich nicht mal annähernd auf diese VRAM Werte komme. Aber ich muss zugeben, es kann auch eventuell daran liegen, dass ich der Karte nur 1.000 V bereitstelle. Da müsste ich nochmals mit Stock bzw. mit 1.100 V testen. Darf ich noch fragen bei welcher Leistungsaufnahme du die 60-65 °C hast und bei wieviel % die Fans drehen? Danke im Voraus!
Ja ich weis normalerweise müsste man sogar eine FE in Betracht ziehen auch richtige Technisches Meisterwerk und auf ihre Weise schön aber wie ein Einhorn zur Zeit !
Die Strixx find ich so schön 😍 da geht es mir mal gar nicht um Max OC sondern die Qualität!
Die Tuf ist ja auch eine solide Karte !
Suprim ist da auch noch mit vorn dabei!
Scalpfactory
Meine war um 14.44 Uhr und ist auch nicht umgesprungen bis jetzt...
Hat schon jemand eine Versandbestätigung aus dem Asus Shop für den Drop der TUF OC von gestern Nachmittag gegen 14.30 Uhr bekommen? Bei mir steht immer noch in Bearbeitung, Kohle ist natürlich schon abgegangen via PP Ex und wird morgen vom Konto abgebucht. Auf die Rückzahlung von PP fürs CP Storno der Suprim X warte ich auch noch. Langsam geht die Kohle aus und immer noch keine Karte unterwegs :LOL:
same hier. Bis jetzt kein DHL auch 14:45
Ah, interessant, hatte ich noch nicht gehört.
Hast du einen Link zu Igor, wo er darüber berichtet? :)
oha da hat aber MF die preise gut angezogen bei der Suprim.
BQ Kabel eben angekommen, 13900k unterwegs.. fehlt nur noch das MB und das We kann kommen
Ähnliche Themen
