[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
absolut richtig, wenn man bei diversen Ticket Portalen Eintritskarten im verkaufprozess hat funktioniert das
da könnten sich einige Shops wirklich mal gedanken über eine derartige implementation für GPUs machen.
aber solange die Ware verkauft wird, wieso sollte man da etwas umstellen, wäre ja Kundenorientiert.
GPU 73 Grad. Was hast du denn für eine RTX 4090?
Gigabyte Gaming OC. Im Phanteks Enthoo Pro 2. An der Front 3 Be Quiet 140 mm die reinblasen, hinten und am Deckel je 1 Be Quiet 140 mm die die warme Luft rausblasen.
Und ich sag ja, das Ding gehört unter Wasser...
Scalper und Botuser würde ebenfalls bestellen
Ka ob das hilft.
Einzige was hilft wäre pro Perso 1x fe je modell
So wüssten aber die Scalper, dass alle potenziellen Kunden selbst bestellen und keinen Bedarf an Scalperware haben.
Von mir aus Aushändigung nur mit Ausweis oder Abholung in Filiale. Wird trotzdem nicht viel helfen und Ebay KA wird bestückt...es ist wie es ist.
Das wäre Planwirtschaft!!!
Aber eine Karte mit MP anzubieten, heißt nicht, dass man sie zum Selbstkostenpreis abgiebt :P
Ich bin gespannt, wie weit die OC Version geht bei dir. Heute und Morgen kommen nochmal ein paar Karten. Hoffentlich eine OC Perle dabei :)
Was ist den bisher der Bestwert bei deinen getesteten Karten beim GPU Takt!
Hat jemand Bedarf an der Zotac AMP AIRO bei Alternate?
MfG
Edit: Ist aus dem Warenkorb gelöscht.
Verstehe die Aussage oder Frage nicht ganz :)
Was ist bisher der am höchsten erreichte Takt von allen Karten die du bisher getestet hast?
Und kann jemand was zur Strixx sagen im Quiet Modus mit wieviel RPM die Lüfter einsteigen aus dem Zerofan Betrieb?
Die Strix OC. Sie hat in SpeedWay 3135 MHZ erreicht und Speicher bei +1600 MHZ. Ich bekomme heute und morgen 4 neue Karten. Mal schauen, ob ich noch was anderes gutes finden werde.
Danke für den Indikator!
  • Danke
Reaktionen: SH
Die leute die Grafikkarten horten bzw. 4-5 bestellen um alle mal anzuschauen finde ich persönlich nicht besser wie die leute auf ebay.
Über die meckern alle, aber bestellen mehrere Karten nur weil eine dann etwas weniger pieps macht mit glück oder mehr Punkte.
Find ich auch unfair aber gut👍
Hat schon jemand eine Versandbestätigung aus dem Asus Shop für den Drop der TUF OC von gestern Nachmittag gegen 14.30 Uhr bekommen? Bei mir steht immer noch in Bearbeitung, Kohle ist natürlich schon abgegangen via PP Ex und wird morgen vom Konto abgebucht. Auf die Rückzahlung von PP fürs CP Storno der Suprim X warte ich auch noch. Langsam geht die Kohle aus und immer noch keine Karte unterwegs :LOL:
Über die meckern alle, aber bestellen mehrere Karten nur weil eine dann etwas weniger pieps macht mit glück.
Wahrscheinlich sind einige / viele genau jene auf Ebay :-)
@homelander
Falsche Aussagen werden leider nicht richtiger, je häufiger man sie wiederholt (Post #10.180). Eventuell denkst Du aber auch halbwegs richtig, schaffst es aber nur nicht, es verständlich/korrekt rüberzubringen.
Wer eine Stunde zockt, wird egal ob mit Wakü oder mit Lukü nach dieser Stunde zocken in etwa die gleiche Erwärmung der Raumfluft haben.
Und das der Temperaturverlauf der Lufttemperatur mit Wakü innerhalb der ersten paar Minuten ein nennenswert anderer wäre (Deiner Meinung nach würde der Raum ja sogar schneller erwärmt), gilt auch erstmal zu beweisen.
Grund: Bei einem wassergekühlten Rechner wird direkt nach dem Einschalten auch erstmal die Wärmeenergie dazu führen, das sich Kühler, Kühlmittel und Radiatoren aufheizen und entsprechend gibt es auch hier
einen Verzug, bis dann der Wärmeübergang voll an die Umgebung erfolgt.
Wie bei der Lukü brauchts hier ja auch ein gewisses Delta, damit der Wärmeübergangswiderstand überwunden wird.
Davor wird die Wakü hauptsächlich einfach nur wärmer.
Von daher stelle ich folgende These auf: Bei einem luftgekühlten System wird der statische Zustand schneller erreicht und entsprechend wird die Wärme früher an die Umgebung abgegeben.
Aber hängt natürlich auch wieder von der Wakü ab.
Kann jemand zur Lüftersteuerung der Strix im Silent Mode was sagen ?
Ich war sehr enttäuscht von der Master die bis 65C 0RPM sind ja Mega aber dann läuft die plötzlich mit knapp 1500 RPM an und das ist für mich unbrauchbar für 2370 € war absolut Nerv tötend für mich zu mal der Zustand beim Spielen in dauerschleife da war !
Bei der Suprim sagte mir ein Kumpel das die mit 800RPM anläuft was erstmal fabelhaft klingt!
Wie ist das bei der Strixx und Tuf gelöst ?
Steigen die auch so sanft ein oder holen die auch gleich den Hammer raus?
Komme halt von Wakü und möchte es leise falls ich nicht auf Wasser umbaue!
Wie ist das denn möglich? Bzw. warum ist das bis dato nicht aufgefallen...
Frage ich mich auch. Das sind schon heftige Werte. Grade bei RDR2 einfach mal 43 FPS mehr mit DDR5 und das nur mit lowspec Ram.
Das klingt schon zu gut um wahr zu sein. Ein Gegentest wäre mal nice. Frag mal jemand CapFrameX :d
Ja, 14:32 bestellt, 19:57 Versandbestätigung, Bestellnummer Endziffer 808, falls die fortlaufend sind.
Jetzt muss das Teil nur noch ruhige Spulen haben.
Ich war sehr enttäuscht von der Master die bbis 65C 0RPM sind ja Mega aber dann läuft die plötzlich mit knapp 1500 an und das ist für mich unbrauchbar für 2370 € war absolut Nerv tötend für mich zu mal der Zustand beim Spielen in dauerschleife da war !
Wie ist das bei der Strixx und Tuf gelöst steigen die auch so sanft ein oder holen die auch gleich den Hammer raus!
kannst du das nicht "überregeln" im afterburner?
Ich hab Endziffer 809 und nix tut sich :cry:
15 Uhr bestellt, noch auf Bearbeitung meine tuf. Hoffentlich geht die heute raus. Muss ein case bestellen.....endnummer 878
Nein konnte den Lüfter nur auf einen Festen Wert setzen und auch nur im OC Mod sonst hat die Steuerung verrückt gespielt !
Jedoch hab ich dann das Erlebnis gehabt als ich den Rechner aus hatte und wieder gestartet habe mit AB Profil 50% Lüfter und angefangen. habe zu spielen plötzlich 70 C dann 75C oha noch 0 RPM sofort Ab resetet und der Lüfter lief an das kann es halt nicht sein.
Da zu noch das leichte fiepen schon bei 375 W.
Zu guter Letzt ist die Material Anmutung für mich eine Frechheit für den Preis bei der Master!
Die Chipgüte variiert ja Extreme bei der 4090.
Ich hatte jetzt bereits 3 Strix eine TUF und 2 Suprim X und ne weitere Strix ist unterwegs gerade bei der Strix hab ich jetzt 2 Modelle die keine 3GHz gepackt haben und eine die Default 2985 MHz in ihrer Default Curve bei 1,1Volt drin hat und geht auf über 3.1GHz die andere geht nur bis 2970MHz und Default bei 1,1Volt gerade mal 2805Mhz. Die TUF liegt iwo dazwischen und die Suprime lagen beide bei ~2900 in der Curve.
Da reden wir von über 180MHz von einer Strix zur anderen …
Wie sehen denn eure Default Curves im Afterburner aus bei 1,1Volt?
Das ist jetzt nicht wirklich überraschend. Anus und MSI haben es einfach nicht geschafft zu erklären, was an der Strix oder Supreme +400EUR wert sein soll.
Wäre es die Chipgüte, dann hätten sie das sicher beworben.
Jetzt weiß ich warum ich keine strix bekomme die ganze zeit🤣
Ohman. Ich finds ja gut mit den Ergebnissen etc. Aber das ist so unfair gegenüber den anderen. Ich meine 90% der Leute hier bestellen nur um die karte zu testen.
Alle wirklich alle haben einen Schaden davon, der Hersteller, der shop der es Verkauft und andere die die Karte zum „jetzt haltet euch fest“ Zocken kaufen wollten BAMBAMBAMBAAAAM…
Naja ich sag dazu nichts mehr bevor ich mich unbeliebt mache^^
made my day…
Ähnliche Themen
Antworten
6K
Aufrufe
392K
