[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe nun auch die Gaming OC bei Mediamarkt bestellt. Mal schauen ob die durch geht, aber so lange wie die verfügbar ist, gehe ich Mal davon aus.
Hat die KFA2 andere Spulen? Finde keine PCB Shots auf die Schnelle.
Evtl. wieder die höheren schwarzen wie die leisen 3090?
Also Reference Design bei den VRMs, also nicht mit billig, nur halt das mindeste was der Hersteller vorsieht und Gainward und Palit darüber hinaus mehr VRM.
Zotac skaliert dann eben vom Preis nach oben auch sein PCB, ist doch okay. Alle bringen trotzdem die Leistung die für das Produkt angedacht ist.
Und aktuell sieht es doch so aus, das die Karten mit besserem PCB und VRM Austattung nicht unbedingt besser sind. Siehe Fiepen bei Suprim, Strix usw.
Also ich bin mit meiner Palit zufrieden, kein Spulenfiepen, leichtes, sehr seltenes Rasseln und das zur UVP bzw. 50€ bei der OC drüber.
Nicht zu vergessen, dass die Palit in deiner Build echt sexy aussieht.
z.B. League of Legends nicht dauerhaft 120 fps erreiche wenn VSync an ist und wenn VSync aus ist die VPS beim über die map fahren zwischen 100-700 fps schwanken.
Vsync aus, und Framecap im Treiber oder per RTSS auf den kleinsten erreichten Wert, also ca. 100 FPS. Und dann ein paar Treiber-Versionen abwarten und ein Ticket bei NV aufmachen, damit die auch von dem Problem Wind bekommen. (Falls es nicht irgend eine Software bei Dir im Hintergrund ist, oder Du den Kühler der CPU beim Einbau gelockert hast), oder die Karte nicht richtig im Slot steckt und die Anbindung nicht passt, oder Du einen defekten Riser benutzt.
Alle drei Monitore laufen auf der gleichen Refreshrate? Kontrolliert? Auch unterschiedliche Refreshraten würden zu dem von Dir beschriebenen Problem führen können.
So FE über invite bestellt. Bin mal gespannt ob durchgeht.
Hau doch bitte mal noch paar Infos raus.
Vorher für die 4090 auf der Nvidia Seite angemeldet gewesen?
Aktiv Geforce Experience die letzten Wochen/Monate genutzt?
Welches System hast du aktuell?
Genau sind die schwarzen.
Schau mal in den Wakü Thread hab das PCB reingestellt und bei Alphacool angefragt wegen Ref Design. Antwort war das es leicht geänderte Bohrungen haben kann.
Erstmal unabhängige Tests abwarten, sah nämlich so aus das die 4080 16GB gar nicht so weit weg ist von der 4090, daher ist die vermutlich auch so eingepreist seitens NV.
16GB reichen aber völlig aus, die 24GB sind doch zu 99% gaga, die brauch Otto-Normalo selbst in 4K oder 5K nicht.
Zwecks vram Aulastung.
Auch wenns en Müllgame, müllengine ist.
CPU hab ich gecheckt und bei mini itx gibt es nur einen Slot, da ein Rückbau auf 1080ti das Problem auch fixt schließe ich das mal aus. Karte zeigt volle 16x lanes in GPU-Z an. Also Hardware Verbindung schließe ich als Ursache aus.
Alle 3 Monitore laufen auf der gleichen Refrshrate, habe ich kontrolliert und sieht man auch recht leicht in GPU-Z, da der RAM nicht runtertaktet bei unterschiedlichen Hz.
Mich würde halt vor allem interessieren ob irgendwer ein ähnliches Setup fährt und keine Probleme hat.
Die Benchmark-Andys sind echt lustig. Ungefähr so sexy wie Speedrunning, aber selbst die haben mehr Groupies. 😂
in diversen yt videos konnte man eine Art Dos like screen: - system font weiss auf schwarzem Background - sehen wo man diverse GPU Infos auslesen/ablesen konnte.. welches tool ist das?
Verpackung der KFA Karte ist bestimmt 30% größer, aber Karte ist minimal kleiner 😃
Moin Leute!
Ich habe mal auf meinem Kanal ein Video zum Thema UV OC PL gemacht. Ich hoffe es hilft hier dem einen oder anderen weiter um Lichts ins dunkle bzgl. der Effizienz zu bringen.
Teilen erlaubt und erwünscht...
Moin Leute!
gibts das auch in guter quali als 360p :)
ahh habe mal den MSI poppo burner installiert, mit dem ist 120% power target möglich.. dieser gpu tweak ist ja schrott!
kenne mich mit dem tool nicht aus, aber ist das meine default curve?
Meine TUF OC macht +260 Mhz Core Clock in TS Extreme mit. Ab +280 Mhz crasht sie.
was muss das muss. auch ich hab meine :d
aber kann nix machen. gehäuse kommt erst morgen
hab mal ein Video beim Belastungstest mit 3DMark Speed Way mit meiner FE gemacht,
meiner Ansicht nach absolut unafällige Lüftergeräusche, kein Spuhlenfiepen.
Wenn hier alle immer vom spuhlengiepen reden, wie extrem ist das? Hört ihr dad beim
Geschlossenen gehäuse und fas es quasi lauter ist als die lüfter?
Und kommt es mir so vor oder ist es beim msi suprim x am meisten? Oder kommt es mir nir so vor? Oder gibt es tendezen welche marken am
Meisten betroffen sind bzw welche versionen?
Ähnliche Themen
