[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So meine Suprim X ist eingebaut und ich bin ein wenig zwiegespalten.
Die Karte ist ein unfassbarer Klopper gegenüber meiner alten 3080Ti Trinity.
Ich konne mein Fractal Meshify 2 mit dem Adapter ohne Probleme schließen, jedoch werde ich ein neues Kabel von Seasonic besorgen und so nen 90° Stecker sobald man die Dinger im Dezember kaufen kann.
Die Suprim ist extrem leise was die Lüfter angeht, meine Gehäuselüfter und CPU-Lüfter sind lauter in Spielen im Gegensatz zur Trinity, das ist aber keine wirkliche Überraschung.
Bei 70% PL verbraucht die 4090 mit ca. 320W das selbe die 3080Ti und verdoppelt meine FPS fast in Cyberpunk 2077 und A Plague Tale Requiem, auch sehr nice und wie erwartet.
Leider hat die Suprim starkes Spulenfiepen. Ich kann es aus dem geschlossenen Gehäuse und über die Gehäuselüfter in Spielen klar hören in meiner normalen Sitzposition am Schreibtisch. Bei meiner 3080Ti ist das nicht der Fall.
Jedoch gibt es auch hier ein aber. Ich kann es nur hören wenn ich komplett ohne Sound spiele und mein (offenes) Headset nicht aufsetze.
Das Headset aufsetzen ohne Sound genügt in 75% der Fälle bereits um kein Fiepen mehr wahrzunehmen und wenn dann der Spielesound am Start ist alles prima.
Und ich werde logischerweise keine Spiele ohne Sound spielen.
Aber für fast 2300€ erwartet man halt ne gewisse Qualität, noch dazu wenn MSI speziell damit wirbt das dieses Modell wenig(er) Spulenfiepen haben soll.
Ich werde die Karte in den nächsten Wochen mal "einfahren" in Plague Tale und Uncharted und schauen ob sich das gefiepe reduziert.
Ich gebe das einfach 1-1 weiter!
vielen Dank für Ihre Nachricht.
Gainward/Palit hat bei jeder GeForce Grafikkarte die Standards von NVIDIA erfüllt, um damit ein optimales Gamingerlebnis zu gewährleisten.
In wenigen Fällen, kann der Luftstrom der Grafikkarte lautere Geräusche verursachen, dies ist ein normaler Zustand und führt nicht zu einem Defekt oder einer verkürzten Lebensdauer der Karte.
Sie können dieses Problem beheben, indem Sie die Lüftergeschwindigkeit anpassen oder eine benutzerdefinierte Lüfterkurve mit einem GPU-Programm erstellen.
Sie können dafür unsere Expertool 2 Software herunterladen:
Sollten Sie oder andere Nutzer jedoch ein Geräusch wahrnehmen, welches auf ein mechanisches Problem hindeutet, senden Sie und bitte folgende Informationen zu:
  • Kopie der Rechnung
  • Seriennummer
  • Kurzes Video des bemängelten Geräusches
Wir werden dann überprüfen, welche weiteren Maßnahmen eingeleitet werden können, um eine möglichst kundenfreundliche Abwicklung zu gewährleisten.
Best Regards/Mit freundlichen Grüßen,
Support-Team
XpertVision GmbH
sowohl der link zum video (als bps) noch die über 10 SN nummern haben den support trotz ausdrücklichen hinweis auf die "enge" der sn nummern und das hier wohl eine ganze charge betroffen ist KEINE reaktion.
daher jeder der will und mag muss hier selbst handeln wie ihr der email entnehmen könnt. Tut mir leid bin da einfach nur ein zu kleines licht am fenster!
Gibt schlimmeres ;-) .
Meine TUF geht gerade so über 3Ghz, von 3.1 bin ich meilenweit entfernt.
Meine auch, aber über 3 schaffen sie wohl alle. Ging mir hier auch nur um den Punkt ob die +45mhz der OC-Version irgendwo eine Rolle spielen. Meiner Meinung nach nicht.
Ich habe meine TUF noch nicht auseinander gebaut, aber im Teardown Video fällt mir ganz klar auf das der VRAM nicht gut gekühlt ist. Die Vaporchamber hat ein Niveau und um Kontakt mit den unterschiedlich hohen Bauteilen herzustellen passt man es auf die GPU an und verwendet sehr dicke Pads um Kontakt zu dem VRAM herzustellen. Der fast nicht vorhandenen Druckstellen hinterlassen auch keinen guten Eindruck.
Gigabyte hat da so eine Bastellösung mit einem Hilfsrahmen über dem Vram der aber wohl deutlich mehr Kontakt hat und besser funktioniert.
Quelle: https://www.techpowerup.com/review/gigabyte-geforce-rtx-4090-gaming-oc/3.html
Im Vergleich mal ein gut konstruierter Wasserkühler (3080 Suprim) der dem Vram mehrere Millimeter entgegen kommt und dadurch viel dünnere Pads benötigt. Diese konstruktiv bessere Lösung kann locker 10°C bei den VRAM-Temperaturen ausmachen.
Anhang anzeigen 805072Anhang anzeigen 805073
Wird mal Zeit für nen schwarzen Noctua, wie sieht das denn aus mit dem alten braunen Ding da
die non OC tuf ist ne paperlaunch karte die nur dafür dienen soll dass asus eben auch eine karte auf uvp niveau "anbietet"
denn wieso kostet die non oc und oc strix fast gleich? :)
machen die dicken pads so viel aus?
damals bei Ampere sagten einige, dass das Spulenfiepen nach ein paar Tagen weniger wurde, evtl sogar ganz verschwand,
kann das sein?
Hat der Quiet Modus bei der Strix auch eine Auswirkung auf die Power der Karte?
Ich habe bei Timespy nur 24029 Punkte.
:d Alt trifft es, der NH-U14S ist fast 10 Jahre alt, aber warum etwas entsorgen das nach wie vor alles wegkühlt was ich ihm unter die Kühlplatte lege. Meinen 5900X hält es locker im Zaum und ich wette mit dem kommenden Ryzen 7000X3D wird es ebenfalls keine Probleme haben. Bei nem Intel 12000 oder 13000 wäre das natürlich ne ganz andere Geschichte.
  • Seriennummer
Support-Team
XpertVision GmbH
Vielen Dank für Deine Bemühungen - es war fast sonnenklar... Im selben Atemzug geht meine betroffene Gainward zurück (bis auf den Lüfter war sie einwandfrei und echt ok) und endlich kam die MM Versandbestätigung für ne Gaming OC. Damit ist dann hoffentlich das 4090 Kapitel abgeschlossen 🙏🙏🙏
PS ein super Thread für den Launch, gefällt mir echt gut, sind viele Infos die einem weiterhelfen. Viel Spaß mir Euren Grakas weiterhin.
Also ich finde die Temps absolut ok.
Hier mal HWINFO im Hintergrund .
BF2042 in UHD Ultra @ 144 HZ ( Framelimit)
2 Runden gespielt.
Leider hat Asus nach dem Thermalpaddesaster der 3090 nix dazu gelernt.
Da muss man wohl selbst wieder Hand anmlegen und evtl ein coppermod machen. Dünne Kupferplatten mit Wärmeleitpaste an den Kühler und dünne Thermalpads an die module. Echt traurig.
ists denn bei der gottgleichen strix besser?
Für die Temperaturen auf jeden Fall. Ich hab den Beitrag oben noch mal editiert und die Gigabyte Lösung hinzu gefügt. Mit dem Hilfsrahmen für den VRAM zwar etwas gebastelt aber sehr effektiv. Von allen bisherigen Konstruktionen scheint Gigabyte den besten Kontakt vom PCB zum Kühlkörper zu haben. Zeigen auch die Tests z.B. von hardware unboxed.
ASUS 4090
Gigabyte 4090
ASUS 4090
Gigabyte 4090
Immer noch besser als FE von daher nicht der rede wert.
Hab auch noch in. Asus Shop eine Bestwllung vom 18.10 offen. Auf Anfrage sagten die mir das erst am 11.11 wieder neue Karten kommen würden. Ich könnte auch stonieren .
Hab wirklich Pech.
Amp Extreme eingetroffen, der Klopper passt nicht in mein Antec 1200:oops:
Erstmal glückwunsch, aber hast du nicht vorher nachgeguckt?
Ich hab bei bequiet nachgeguckt wie lang die Grafikkarte für das Pure Base 500 sein darf und ich hab ca. 2cm luft. Musste aber von AIO auf Luftkühlung wechseln. :LOL:
Dito, meine non OC geht je nach Benchmark auf maximal 3060 MHz bei 1,1 V. Port Royal ist dabei am kritischsten, noch vor Speedway. Dort schafft sie auf den Kopf 3000 MHz.
Ansonsten bin ich super zufrieden (gekauft für 1949€). Spulenrasseln ab 420 Watt bzw 150 fps. Lüfter sind 1a.
Da ich eh mit 1775MHz @ 0,975V spiele und die fps bei 99 cappe, passt alles ( mein 32:9 hat zwar 120Hz, geht aber wieso auch immer nur bis 100 fps mit GSync).
Wobei sich Deine Graka ja auch 25% der Zeit langweilt^^
Klar da sieht man auch wie viel Power die hat .
Seit Windows neu installiert sind die 138 FPS bei BF2042 wie angenagelt.
Das hat die 3090 nicht im ansatz geschafft :)
Lass den Vram 76°C oder meinet wegen 80°C werden wenn man die Karte quält .
Das ist absolut im grünen Bereich . Natürlich wäre es sinnvoller gewesen , wenn da Erhöhungen wären und 1mm Pads drauf .
Da geht natürlich einiges mehr aber im Alltag hat man dennoch gute Werte und einen Luftkühler hat man eh nur für den Alltag.
purebase 500 und eine 4090. das nenn ich mal ne heise kombo
Ähnliche Themen
