• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
mal ne frage - steh zwar nicht drauf aber würds gerne wissen: wie kann man die farben der leds der strix ändern? muss ich da wieder bloatware installieren?
armory crate sicherlich. oder eventuell auch über icue. aber auch hier müsste glaub armory crate installiert sein
wenn der benchmark die cpu mit einfließen lässt, dann ja.
Also sind es eigentlich schon zu wenig Grafikpunkte, denn die müssten ja theoretisch ca. gleich sein bei jeder Strix?
frisches windows?
die top leute benchen mit einem frischen system ohne tonnen von isntallierter software etc..
danke ich glaube dann wird die karte bei mir nie was anderes als blau roten farbwechsel zeigen .. armory crate um gottes willen ^^
frisches windows?
Nein, aber ich bin ja nicht mal richtig im Durchschnitt, sondern ein gutes Stück drunter.
Ich möchte ja nicht mit den ersten Plätzen konkurieren.
Bei meiner Strix 3080 war ich mit dem selben System zumindest im Durchschnitt.
hält die karte denn ihren takt durchgehend? ich benche sehr selten.
ist firestrike nicht besser für gpu benchen?
Gratulation :)
Und ist bei deinem hintere "Durchzugs" Lüfter das selbe ab 70% etwas lautere höherfrequente Geräusche als normal?
Was sind so deine Temps im geschlossenen Gehäuse @Stock und Volllast?
Danke, jap selbes Geräusch. Dieses etwas hochfrequente Turbinengeräusch. Hatte meine 3090 FE nicht. Aber alles gut. In dem Fall ist das bei den 4090er FEs so.
Also die Karte surrt doch vor dem Herren...das Fiepen kommt dann bei höheren FPS. Also da brauch ich keine FE. Die 3090 war aber schlimmer. Also sehr subjektiv das ganze. Das Surren/Rasseln ist aber stark unterschiedlich ausgeprägt und haben alle Karten
Ich kenne mich da auch nicht so aus, aber bei firestrike schaut es auch nicht besser aus.
Bei durchschnittlicher Taktfrequenz steht 2582MHz.
http://www.3dmark.com/fs/28623844
Ja irgendwas kann da bei Dir nicht stimmen. Anbei mal meiner von gestern im stock.
Hast du G-Sync noch an?
Hast du in der Nvidia Systemsteurerung noch nen FPS Limit drin?
Haste das Powerlimit Afterburner runtergesetzt?
Vsync könnte auch noch das problem sein... falls global aktiviert
Die gigabyte gaming oc die ich bekommen habe ist fast lautlos zur 3090fe und zur 4090 tuf non oc die unerträglich gefiebst hat :)
Zeig mal einen screenshot des curve editors!
Wieviel V zieht die GPU während des Benches?
Wie hoch ist der VRAM Takt?
Wie hoch ist das Powerlimit im Afterburner?
Ich werde das morgen mal machen.
Habe jetzt nochmal ohne V-Sync und G-Sync getestet, schaut aber gleich aus.
@SH Berichte mal von der KFA2 was macht die Karte so?
Das stimmt doch überhaupt nicht was Du das hier in den Raum wirfst
ich konnte das in Fall meiner FE nicht bestätigen, es wird bei mir nicht mehr auch nicht bei höheren FPS.
Es ist schade das hier offenbar sehr viel daher geredet wird und anderen inform von pauschalen Aussagen suggeriert wird
Es ist schade das hier offenbar sehr viel daher geredet wird und anderen inform von pauschalen Aussagen suggeriert wird.
Hmm Spulenfiepen habe ich bei meiner FE auch nur sehr schwach und kaum wahrnehmbar.
Einzig das mit Lüfter fand ich auffällig, schien aber nix mechanisches und nach den Berichten hier und deinem Video ists wohl normal. Bis 50% Lüfterspeed ist es im Gehäuse eh nicht wirklich wahrnehmbar
Ich meinte auch eher das Rasseln / Surren das ich im Video hörte. Ich dachte die FE ist wirklich da super leise. Mit geschlossenem Case ist dann Ruhe, wie gesagt da reagiert jeder anderweitig darauf. Natürlich wünsche ich Dir viel Spaß mit der Karte.👍
Es gab zur eigentlichen Geräuschentwicklung bei meinem Video auch Störgeräusche die überhaupt nicht von der Grafikkarte kommen, sry
Meine kam heute auch an.
War mir ja schon klar das sie von der Länge nicht ganz passen würde mit dem Ausgleichsbehälter. Gut dass das darkbase 700 vorne noch lüfter vorsieht und ich den mit dem guten alten Unterlagsscheiben noch nen cm rausholen konnte 😅
Ist meine erste Asus. Aber im Vergleich zur EVGA Ftw3 muss ich sagen. Hut ab Asus das Teil ist wirklich gute Qualität. Find sie sogar besser wie die Ftw3.
OC Themen und was die kann muss ich erst nochmal nachlesen mit den 1,05 V😂. Bisher immer nur über Powerlimit und Takt gemacht
5DF1737E-A844-4B9E-AA51-CAC9BE7DEF24.jpeg 437EBD3A-0A31-49E0-BEE7-1D2599245E80.jpeg
hast du 3 kabel dran?
Ich meinte auch eher das Rasseln / Surren das ich im Video hörte. Ich dachte die FE ist wirklich da super leise. Mit geschlossenem Case ist dann Ruhe.
Ahhh hmm ggf mal die Lamelle von Kühler beim Auslass etw mitm Finger abtadten während die Karte auf 70% Lüfterspeed ist.
Stimmt ich weiß jetzt nicht obs im Video war aber ein "Rasseln" hatte ich beim Auslasslüfter. Hat sich sehr nach Zirpen von Spulen angehört und ich dachte es wäre was vom Lüfter. Bei mir war es aber ne Kühlerlamelle die ungünstig stand und mitvibriert und so ein Rasselgeräusch erzeugte.
Installier auf keinen Fall Armory Crate, das wirst du nicht mehr los ohne Windows neu zu installieren.
Gibt dafür ein programm namens openRGB, damit kannst du so ziemlich alle deine LED's steuern.
Ähnliche Themen
