[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
KENA ist mal eine lustige ausnahme wo tatsächlich bei steigender auflösung bzw reduzierter auflösung sich die fps abseits vom GPU limit verändern (somit cpu)
warum? keine ahnung
720p > 1080p > 1440p > 3440x1440
Kena-Win64-Shipping_2022_10_20_20_47_48_387.jpgKena-Win64-Shipping_2022_10_20_20_47_32_371.jpgKena-Win64-Shipping_2022_10_20_20_48_20_848.jpgKena-Win64-Shipping_2022_10_20_20_48_39_233.jpg
nochmal anderer blick ohne DLSS
720p > 1080p
FPS verlust obwohl gpu nicht am limit. theoretisch dürften die fps nicht runtergehen. tun sie aber dennoch
Kena-Win64-Shipping_2022_10_20_20_55_36_701.jpgKena-Win64-Shipping_2022_10_20_20_55_54_050.jpg
wenn da jemand ne erklärung hat, gerne her damit :)
So, so langsam müssten die Scalper auf ebay wieder den Rückversand starten.
Bei NBB liegen Karten auf Lager... Keiner ist mehr gezwungen eine 3000€ Karte zu kaufen
Geht wohl doch schneller als erwartet
Nachricht gelöscht
Gibt schlimmeres, wie z.b. ein Scalper, der alle Gebote streichen lässt und dann die Karte aus Ebay entfernt, nur um die bei Ebay-Kleinanzeigen zu verkaufen.
Hmm...da ja die Gebote rechtlich bindend sind und ein Missbrauch strafbar ist...
Edit: Ich meinte den hier:
Das scheint es schon irgendwie komisch...
Der selbe hatte auch eine Anzeige in Ebay-Kleinanzeigen...die ist nun auch weg...viele fahren zweigleisig...
Gibt es da nicht eine Möglichkeit ihnen ein paar Steine in den Weg zu legen? :d
Auf ebay melden. Die verwarnen den sofort und drohen mit einer Strafe wenn man auf ebay und EK gleichzeitig einstellt.
Gratulation :)
Und ist bei deinem hintere "Durchzugs" Lüfter das selbe ab 70% etwas lautere höherfrequente Geräusche als normal?
Was sind so deine Temps im geschlossenen Gehäuse @Stock und Volllast?
hab mal ein Video beim Belastungstest mit 3DMark Speed Way mit meiner FE gemacht,
meiner Ansicht nach absolut unafällige Lüftergeräusche, kein Spuhlenfiepen.
Danke, jap selbes Geräusch. Dieses etwas hochfrequente Turbinengeräusch. Hatte meine 3090 FE nicht. Aber alles gut. In dem Fall ist das bei den 4090er FEs so.
warum? keine ahnung
Anhang anzeigen 805178Anhang anzeigen 805181Anhang anzeigen 805177Anhang anzeigen 805180
720p > 1080p
Anhang anzeigen 805187Anhang anzeigen 805186
hast du dir doch schon selbst erklärt. ISt dann wohl die CPU. Oder habe ich was falsch verstanden?
Gratulation :)
Ich hab die Lüfterkurve nicht verändert.
Bin noch am UV Profil ausloten, mit 2.7Ghz bei 0.925V UV bin ich bei ca 60Grad.
Bei vollast mit Max Leistung hab ich glaub so ca. 70-74Grad gesehen vorhin.
Die Karte kommt schlussendlich aber eh unter wasser was dann nochmal einiges an Optimierungen zu Folge haben wird.
Ist das bez. der Spulen dein Ernst? Die Karte surrt doch wie Hölle, sogar trotz der Lüfter stark zu hören.
Mal ein Beweis mehr wie sinnlos solche subjektiven Useraussagen sind. Danke aber für das Video.
Falls du das dauer-"Sägen" meinst dürfte das der Lüfter sein. Ab 60% geht das los und ab 70% ganz deutlich zu hören und bei 100% Lüfterspeed schon etw. nervig.
dann düfte sich beim verändern der auflösung aber die FPS nicht verändern.
ich schiebe das in dem fall mal auf die engine denn das ist nicht die regel :)
in spider man passt es wieder
720 > 1080 > 1440p (16:9)
Spider-Man_2022_10_20_21_09_39_439.jpgSpider-Man_2022_10_20_21_09_21_606.jpgSpider-Man_2022_10_20_21_08_34_945.jpg
Apropo Spiderman
Reflex ist bei mir ausgeraut? Ist das den 4000er vorbehalten? :)
Meine auch, aber über 3 schaffen sie wohl alle. Ging mir hier auch nur um den Punkt ob die +45mhz der OC-Version irgendwo eine Rolle spielen. Meiner Meinung nach nicht.
Ich habe meine TUF noch nicht auseinander gebaut, aber im Teardown Video fällt mir ganz klar auf das der VRAM nicht gut gekühlt ist. Die Vaporchamber hat ein Niveau und um Kontakt mit den unterschiedlich hohen Bauteilen herzustellen passt man es auf die GPU an und verwendet sehr dicke Pads um Kontakt zu dem VRAM herzustellen. Der fast nicht vorhandenen Druckstellen hinterlassen auch keinen guten Eindruck.
Gigabyte hat da so eine Bastellösung mit einem Hilfsrahmen über dem Vram der aber wohl deutlich mehr Kontakt hat und besser funktioniert.
Quelle: https://www.techpowerup.com/review/gigabyte-geforce-rtx-4090-gaming-oc/3.html
Im Vergleich mal ein gut konstruierter Wasserkühler (3080 Suprim) der dem Vram mehrere Millimeter entgegen kommt und dadurch viel dünnere Pads benötigt. Diese konstruktiv bessere Lösung kann locker 10°C bei den VRAM-Temperaturen ausmachen.
XD "Bastellösung" Ja das habe ich bei der Gigabyte auch gedacht... noch immer bestellt da einer rum. Warum bekommen die das nicht wie Asus oder Nvidia hin???
ja der screenshot war falsch. war am rumstellen
normal ist vsync auf on. fps per rtss auf 118.
bleibt ausgegraut. morgen werd ichs sehen ob das simple switchen von ampere zu lovelace die option freischaltet lol
wäre schon ziemlich frech denn reflex gibts auch in anderen games und da funzt es
ok, das passt aber auch so mit meiner zusammen. ^^
welches ist schöner von der Grafik UNCHARTED Legacy of Thieves Collection -- a plague tale requiem...?
Lg
Lg
Plague. Uncharted sieht man teilweise sein alter an. Der Tauchlevel sah super aus aber an Land wirkt alles etwas flat. Aber finde das Spiel besser als Plague. Da wirste von einem Abschnitt in den anderen geschickt und musst mit dem Feuer knobeln.
*peinlich aber, wie bekomme ich beim Curve Editor mehr als 3GHz zu sehen?:oops:
Man muss halt damit leben das eine verbockte Kühlermontage im schlimmsten Fall einen >2K€ Briefbeschwerer ergibt...
Sowas kommt doch nicht oft vor. Du machst ja kaum was außer den alten Kühler runter und den neuen drauf. Das sind am Ende 4 Schrauben. Ich hatte damit bisher noch nie Probleme, davon ab aber auch noch nie einen Garantiefall einer Grafikkarte.
Du musst mal oberhalb vom Monitor gucken. Die stehen da etwas über.
Hm, verstehe ich nicht? :unsure: Kann da nix höher machen, kann nicht darin scrollen, rein oder rauszoomen, es endet bei exakt 3GHz.
Schon jemand hier mit nen 13900k(f) hier unterwegs? Und kann was zum CPU Limit in uhd sagen?
Was soll ich dir sagen... das Teil brennt :-)
Hatte BF2042 MP vorher mit einem i5 12400 gespielt. In 4K und alle Regler ohne Sinn und Verstand nach rechts so bei 90-120fps gewesen, nun bei 180-210 :-) Bin in fast jedem Spiel mit dem i5 an die Grenzen gestoßen (selbst in 4K).
das ist völlig normal. das war schon immer so.
die gesteigerte IPC reicht um die in games genutzten kerne die bei beiden cpus in etwa gleich sind, zu überbieten
glaube aber du bist im thread verrutscht ? :d
Such in der .cfg hiernach. Normal sind da 3000 eingetragen.
VFCurveEditorMaxFrequency = 3500
mal ne frage - steh zwar nicht drauf aber würds gerne wissen: wie kann man die farben der leds der strix ändern? muss ich da wieder bloatware installieren?
Ähnliche Themen
