• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nunja die FE Kühler sind deshalb ein wenig wärmer, WEIL die kleiner sind. :d Das ist halt Vor und Nachteil zugleich. Aber zumindest hat der FE Kühler keine direkten Schwächen wie die TUF mit dem etwas schlecht gekühltem VRAM.
:d
Du weißt aber schon das der VRam der FE Stock einige Grad wärmer ist als der von der TUF obwohl dieser ja mit den dicken Pads so im gerede ist - wobei ich das sowieso nicht verstehe hier wird rumgejammert wegen 70-80 Grad Vram Temps wie wenn das irgendwie ein Problem wäre.
350€ Zuviel. Heftig, wirklich heftig, obwohl die Karten wirklich besser verfügbar sind, als letzten Launch. Es beginnt von vorne. Mal sehen wenn die 14 Tage rückläufer zurück bei den Händlern sind.
Wenn ich sehe wie viele 4090 Founders bei Ebay Kleinanezigen drin sind werd ich echt ein bisschen mad :fresse2:
Bei Ampere war es ja noch was anderes, wenn man an Miner verkauft hat. Aber jetzt ist es schon sehr räudig.
P.S: Habe wieder zwei neue Cookies für die Gainward GeForce RTX 4090 Phantom. Vier User konnten schon erfolgreich versorgt werden :wink:
Alle bisherigen Kühler sind diesmal wirklich gut dimensioniert. Gott sei Dank gingen die Hersteller alle von 600 Watt aus. Darf gerne immer so sein.
Ich verstehe garnicht das so viele FEs in den Kleinanzeigen verkauft werden. So groß ist die Nachfrage danach doch gar nicht. Zumal es auch immer wieder Customs gibt die ordentliche Leistung haben und ordentlich kühlen.
P.S: Habe wieder zwei Neue Cookies für die Gainward GeForce RTX 4090 Phantom. Vier User konnten schon erfolgreich versorgt werden :wink:
Lederjacke hat das schon so eingeplant das auch die 4090 knappes gut sein werden.
Einfach abwarten... ich weiß, das Verlangen ist groß (ist es bei mir auch), aber die Karte läuft ja nicht weg... und es kann prinzipiell nur besser werden bzgl. Verfügbarkeit, da kein Mining-Boom. Einfach entspannt bis Anfang November warten und dann schauen, was der Markt hergibt. Sehe absolut nicht ein, für die ganzen Plastikbomber (abseits der TUF/SUPRIM/STRIXX) auch nur einen Cent mehr als UVP zu bezahlen...
Wenn ich das mit den anderen Ergebnissen hochrechne, liegen die 2.8xx MHz so im oberen Durchschnitt des GPU-OC.
Wie sieht das mit dem VRAM-OC ,aus?
Alles so im Bereich +1000-1500 scheint Standard zu sein bei dem was ich gelesen habe . 1500 mhz bekomme ich durch den bench , aber ist nicht stable.
Die Chips scheinen alle so + 250 mhz vom Stock wert zu können .
Unter Wasser gehen dann wahrscheinlich paar MHZ mehr und der Vram sollte auch etwas stabiler dann laufen , aber das wäre so Luft Bereich 50-60•C GPU Temps bei den meisten Kühler und aufgedrehte Lüfter .
Naja, die Scalperpreise haben sich ja schon von 3000 auf 2350€ gesenkt. FEs für 2350€ gehen auch nicht weg und wären noch da.
Lange dauerts hoffentlich nicht mehr.
Ich wollte auch die FE. Find sie halt wertig und gut verarbeitet. Die unboxing Erfahrung ist diesmal auch sehr schön. Die anderen, die Glück hatten, können das bestätigen. Aber besser ist die FE nicht. Aber wenn man sie bekommt, dann für 1949€. Die gamerock war leiser, aber bei mir leider eine Bananenkarte. :)
Durch die vielen Käufer steigen die Preise. Mal sehen was AMD bringt, vllt entspannt das den Markt bisschen. Oder das Gegenteil.
Ich hatte ja extrem Glück mit dem GeForce experience Link. So wie ich das hier auch im Forum mitbekomme, hatten nicht viele bisher Glück. :(. Nachdem ich die BananenGamerock zurück geschickt hatte, hab ich den einmallink zum bestellen bekommen.
Ich hoffe das andere auch ihre Wunschkarte für UVP, oder niedriger bekommen.
Habe gerade die Gigabyte Gaming OC bekommen und eingebaut.
Wirklich eine große Grafikkarte, aber im System nicht zu hören. Da ist mein CPU Lüfter lauter.
Ein fiepen höre ich auch nicht, wobei ich sowieso mit maximal 118 FPS spiele und das PT auf 80% reduziere.
Sollte man eigentlich die Treiber komplett neu installieren, auch wenn ich vorher eine 3080 hatte?
In "A Plague Tale" springt der Lüfter noch nicht Mal an, weil meine CPU zu langsam ist, aber mit dem Spiel bin ich auch schon durch. :d
Die Beta von "The First Descendant" ist hoffentlich noch nicht optimiert. Da habe ich 60 - 70 FPS und mit der 3080 hatte ich 30 FPS.
Ich freue mich auf jeden Fall und werde lange Spaß mit der Karte haben.
Die Halterung ist auch perfekt umgesetzt. Diese wird am rechten Teil vom Mainboard befestigt.
Das Plastik finde ich gar nicht schlimm, hängen halt 400-500 gramm weniger am Pcie Slot.
Hast n paar Bilder für uns und evtl. ne Soundaufnahme von den Lüftern?
Anscheinend hat nur die Gigabyte Master eine schlechte Lüftersteuerung wenn man hier so mit liest.
Oder hier laufen alle mit Ohropax rum?
Die Lüfter meiner Gigabyte waren nur mit 50% Top leider funktionierte das überschreiben mit dem AB nicht immer !
Der Silent Mode war für mich mega schlecht von der Lüftersteuerung her bis 65 C 0 RPM mit Zero Fan dann Lüfter Start mit 1450 -1500 RPM nach 2 min ca wieder 0 RPM nach 2-3 Mint 65 C wieder 1500RPm das ging mir aus ca 2,50m total auf den Geist .
OC Modus bis knapp 2000 RPM da kriegt man einen an der Waffel.
Fiepen Suren nur unter 400W okay aber immer noch minimal vorhanden wenn man nah ran ging .
Und die Material Anmutung OMG
Hier ein Bild von dem guten Stück. Die Karte wird natürlich auch schon gut von den Gehäuselüftern gekühlt.
Mit Sound kann ich leider nicht dienen. keine Ahnung wo ich das hochladen soll.
Den GPU Halter sieht man oben rechts. Dieser wird an zwei Mainboard-Schrauben befestigt und die Verankerung schraubt man rechts an die Grafikkarte.
Das ist für mich an der Karte das beste gewesen der Halter.
Wen ich die Kupferheatpipes wieder sehe wir mir schlecht!
Hast Du die Torrent Stütze auch dran oder nur die von der G OC?
Habe nur die Stütze von der Karte selber dran, da die bombenstabil ist. Soweit ich das bei der Torrent Stütze gesehen habe, schraubt man die nur rechts dran und schiebt einen Arm unter die Grafikkarte und ich weiß nicht ob das bei der Plastikabdeckung der Gigabyte so sinnvoll ist.
@Sturmwind80 das wird so sicher sehr gut funktionieren. Welches Torrent Gehäuse ist das?
Das Fractal Design Torrent Black Solid.
Ähnliche Themen
