[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Same here für Seasonic. Geht ja eigentlich allen so.
Vielleicht etwas Positives, der 4-in-1 Adapter ist wohl für alle gleich und kommt auch direkt von Nvidia. Der wirds zur Not ein paar Tage tun.
Ich nehme mal an, dass alle 4 angeschlossen sein müssen!?
Das AX1600i hat soweit ich weiß 10x PCIe-Stecker
Hab ich damals auch beim Byksky-Block für die Strix gesagt :d
Gibt wohl was neues .. 1440p Nativ :
Die 4090 ( 507 FPS ) is dort mehr als doppelt so schnell als ne 3080 ( 249 FPS ) ... kommt man also von der 3080 ( wie ich zb ) sollte es da schon nen ordentlichen Schub geben bei den FPS
Und meine 3080 Strix ballert auch bis zu 450 Watt raus genau wie ne 4090 @Stock ... für mich is da der einzige Negativ Punkt eigentlich nur der Preis
wo ist das Problem?
Die 4080/12 steht doch in etwa für die 3090/ti ...
Ich kann mir einfach nicht vorstellen, dass die 4080 sich gut verkaufen lässt.
Intel lässt es wirklich drauf ankommen.
Release 12.10 wie NVIDIA
Reviews 5.10 wie NVIDIA (wahrscheinlich)
507fps sind echt nett für Benches. Zum Zocken aber nix gut bzw. sinnfrei
Huch, morgen schon? :oops:(y)
@Stagefire Danke für die Folie. Deckt sich mit den aktuellen leaks und doppelter Leistung. Meine Wakü 3080 Suprim geht sehr gut und drückt grob 9500 im TSE https://www.3dmark.com/3dm/77752200 meine Entscheidung ist eh schon gefallen, aber wenn die 4090 die 20.000 packt, wie im leak würde mich das freuen... https://hothardware.com/news/geforce-rtx-4090-3ghz-trounces-3090-in-time-spy
Bei welcher News steht dieser Kommentar?
https://wccftech.com/ und ich glaube die nutzen Disqus als Kommentar System. Da wird aber auch sehr viel geredet bzw. geschrieben.
Eine für mich eher belanglose News zum B650 Board hat dort heute 1400 Kommentare: https://wccftech.com/msi-amd-b650-motherboards-official-msrp-leak-prices-start-189-us-up-to-329-us/
Es geht um die Prozentuale Steigerung von Neu gegen Alt ... denke mal in 4K währen es dann jeweils die Hälfte also 3080 ( 125 FPS ) und 4090 ( 250 FPS ) aber da schätze ich grad nur.
Es sind jedenfalls Doppelt soviele FPS bei der 4090 als bei der 3080 .. sinnfrei find ich das also überhaupt nicht sondern ansprechend da ich mom eine 3080 nutze .... nur der Preis is eher abschreckend.
Hatte von 2016 - 2020 ne GTX 1080 und es gab dann ne 3080 für mich das war schon ne Leisungsverdopplung für mich und wenn ich nun von der 3080 zur 4090 wechsel währe das wieder
ne Leistungsverdopplung ... nur leider diesmal eine sehr teure... die 4090 würde ich dann wieder für 4 Jahre behalten
Doppelte Leistung bezogen auf die 3080 aber nich auf die 3090 ... aber kommend von einer 3080 ( wie du und ich ) is eine 4090 sehr schmackhaft abgesehen vom Preis.
Verbrauch is ja ähnlich ... meine 3080 Strix zieht auch 450 Watt und ne 4090 die man @Stock betreibt zieht auch ihre 450 Watt is also even aber bei Doppelter Leistung der 4090.
Ich hader noch ... es is viel Kohle ( die ich aber auf dem Konto hab ) ... in sachen HDMI 2.1 Anschlüsse kommen für mich dann auch nur die Strix oder die TUF in frage.
Nur sind die leider recht lang und mein AGB is im Gehäuse im Weg ... da müsste ich mir was einfallen lassen... die Strix is 36cm lang ich hab aber grad nur Platz für 33cm
Und dann is da eben noch die Sache mit dem Adapter Kabel ... ich hab nur 3 x 8 Pin am Netzteil aber der Strix liegt ein 4 x 8 Pin dabei und ich weiss nich ob die Karte läuft
wenn man nur 3 x 8 Pin anschliesst und 1 x 8 Pin offen lässt.
Die Webseite kenne ich, danke :) aber bei genau welcher News wurde dieser comment geschrieben? 😃
@MADman Kann ich sehr gut nachvollziehen. Ich habe einen Kollegen der auch ewig auf dem Watercool Block für die FTW3 gewartet hat. So kann einem echt die Lust vergehen.
Yep, glücklicherweise bin ich nicht so Lärmempfindlich, zocke eh immer mit Kopfhörern, und ich muss mich jetzt auch nicht (gleich) in ne Benchmark Table eintragen, von daher bin ich da mittlerweile enspannter, die kann auch ne ganze Weile auf Luft laufen.
Das letzte Mal habe ich wie gesagt noch erst ne Weile abgewartet für welche Karte mein Lieblingsblock wohl kommt und dann hatte ich keinen Bock mehr zu warten und habe mir die EVGA geholt weil ich Cyberpunk zocken wollte damals :d Und letztendlich ist sie auf Luft geblieben weil es zu lange gedauert hat.
Dieses Mal hole ich mir ziemlich eine Karte die mir zusagt (FE oder Suprim X stehen vorne auf der Liste derzeit) und schaue dann, ob und wann es einen guten Block dafür gibt. Ich habe Ende des Monats 2 Wochen Urlaub und da möchte ich schön zocken und nicht immer noch auf die perfekte Combo warten.
Ich hader noch ... es is viel Kohle die ich aber auf dem Konto hab ... in sachen HDMI 2.1 Anschlüsse kommen für mich dann auch nur die Strix oder die TUF in frage.
Das kommt mir doch sehr bekannt vor. Damals wollte ich auch die Asus Strix 3090 (auch vor allem wegen den 2x HDMI) aber wegen dem AGB hatte ich nur 31,5cm Platz, die Strix aber über 32cm. Und den AGB zu verlegen war kaum möglich und mir auch zu stressig damals, weil ich dazu das halbe System hätte auseinanderbauen müssen. Also wurde es die EVGA 3090 FTW.
Diesmal war gleich klar, das außer der Founder keine Custom passen würde, also musste sich der AGB bewegen. Und da ich eh einen 7950X holen wollte und dafür alles auseinanderbauen musste, habe ich gleich den AGB versetzt. Jetzt stehen mir immerhin 34 cm zur Verfügung, mehr war beim besten Willen nicht drin und wo anders kann der AGB nicht hin ohne ein ganz großen Fass aufzumachen.
Also Liste checken...
Und wieder ist die Strix raus. Und die TUF :motz:Das schränkt meine Wahl doch ein. Die Suprim X müsste passen aber die da reinzuzirkeln könnte spaßig werden. Daher steht die FE bei mir ganz vorne auf der Liste aktuell.
Was den Adapter angeht...ich würde es nicht mit 3x8-pin versuchen, das Ding ist ein Monster und die Adapter sind eh schon kritischen Blicken ausgesetzt und mit Fragezeichen behaftet. Ich halte es für ein großes Risko. Technisch könntest Du Glück haben und die Karte merkt es nicht, aber dann würde ich mich höchstens mit Undervolting beschäftigen und zusätzlich das PT begrenzen.
Die FPS sind natürlich gaga, aber entsprechen ziemlich genau der +100% Steigerung im 3Dmark Timespy (DX12, 1440p). Damit wäre es schon ein Kunststück, die theoretische verdopplung der Leistung tatsächlich in einem Overwatch in Form von FPS zu realisieren.
Deine 3080 Suprim mit Wakü : ( 9.574 )
Meine 3080 Strix mit Wakü : ( 10.219 ) ... is aber nur 3D Mark stable aber nich Game stable.
Sollte ich ne 4090 kaufen hab ich 2 Möglichkeiten ... entweder ich nehme eine mit nur 1 x HDMI 2.1 die kleiner is und brauch dann aber nix umbauen oder ich nehm ne TUF Oder Strix
und mach ne Frankenstein Modifikation in meinem Gehäuse die alles andere als sicher is. Sieht dann scheisse aus und is wackelig aber das würde dann nur so lange so sein bis ein Wasserblock
für die Karte rauskommt.
Hab nen Vertical GPU Holder da pack ich die Seite mit den Monitor Anschlüssen drauf und dann schräge ich die karte etwas an sodas der hintere Teil der Karte etwas zu mir seitlich schaut und ich damit dann vor dem AGB komm und da pack ich was drunter damit die karte hinten auch halt hat und sie nich in der Luft schwebt ... muss halt nur schauen ob mein Riser Kabel lang genug is und ob ich nich doch überlege mein ABG für die 2 - 3 Monate mal umzusetzten ... bin da noch in der Überlegungsphase aber ich bin halt auch Prackmat ( was nich passt wird passend gemacht auch wenns dann nich mehr so schön aussieht )
Ich habe nich vor die Karte mit 600 Watt zu betreiben sondern mit Max 450 Watt wie seit 2 jahren meine 3080 Strix .. und dafür sollten 3 x 8 Pin ausreichen tun sie ja bei meiner 3080 Strix auch.
Die Frage is halt nur wenn nur drei von vier 8 Pins belegt sind ob die Karte dann angeht ?? .. weil wenn ich zb bei meiner 3080 Strix nur 2 x 8 Pin anschliesse geht sie auch nich an die brauch zwingend
3 x 8 Pin damit die angeht .. die Frage is halt is das dann mit nem 4 x 8 Pin adapter auch so und die karte geht nur an wenn alle 4 x 8 Pins belegt sind oder reichen 3 x 8 Pin und 1 x 8 Pin kann offen bleiben
und eben ein Power Target von 450 Watt und die karte läuft dann auch so ?
15 Uhr natoll da bin ich schon am arbeiten. Gibt 2 Szenarios
1. es gibt so viele Karten und nicht so viel Nachfrage das ich auch am 13. noch welche bekomme
2. es gibt zu wenig Karten, zu hohe Nachfrage, was dann auch schon wieder steigende Preise bedeuten dürfte und Wartezeit bis neue Karten eintreffen... :(
Eher 2, Lederjacke hat schon klar gesagt, dass die Produktionszahlen 2022 nicht so hoch sein werden, soll erst ab 2023 besser werden.
Die beiden HX 850 Gold/Platin haben 6x 6+8pin. Am NT geht pro Anschluss 300 Watt wo jeweils im Lieferumfang 2x8Pin pro Kabel dran ist . NT ist Single Rail mit 70 ampere .
Benötigt werden daher 2x8Pin Buchsen .
Krass wie viele hier das nicht verstehen :d
Ob das NT mal abschaltet , weil die Graka zu viel und lange sich was schnappt wird sich zeigen . Könnte aber noch hin hauen , aber muss man testen .Bei Multirail Netzteile sollte man dann mal in die Anleitung schauen für die bequiet Leute .
Ich sollte mit meinem Dark Power Pro 12 1500W glaub ich so gerade auskommen :) BeQuiet soll so langsam mal das dumme Kabel rausbringen :)
anschlüsse hab ich genügend :)
PS. "Adapter" sollte ich dann 4 Lanes nehmen mit jeweils 1 Pin zum Adapter oder langen 2 Lanes ergo 4 Pins zum Adapter ?
Die beiden HX 850 Gold/Platin haben 6x 6+8pin. Am NT geht pro Anschluss 300 Watt wo jeweils im Lieferumfang 2x8Pin pro Kabel dran ist . NT ist Single Rail mit 70 ampere .Benötigt werden daher 2x8Pin Buchsen .
Nich jeder hat ein HX850 Gold / Platin ob nun neu oder alt sondern ein ganz anderes Netzteil ... krass wie viele hier das nich verstehen :d
Ich habe ein Netzteil was mit ner 450 Watt GPU ( meiner 3080 Strix ) klar kommt und brauch also kein neues... es geht mir grad nur um diesen Dummen Adapter
aber ich glaub um eine antwort auf meine Frage zu bekommen muss ich auf die Reviews der 4090 warten.
lol was das denn für ein Ding? Selbst mein 700W passiv Netzteil hat 4. :fresse:
Bei meinem waren 2 x 8 Pin Kabel dabei und 1 x 6 Pin ... hatte mir für meine 3080 Strix noch 1 Extra 8 Pin Kabel bestellt.
Ich hab somit aktuell 3 x 8 Pin und das sollte für 450 Watt ausreichen .. tut es ja auch für meine 3080 Strix die nen PT von 450 Watt hat.
Wenn ich nun ne 4090 mit nur 450 Watt max betreiben will bräuchte ich dafür auch nur 3 x 8 Pin und die hab ich..,. is doch simple
Leider konnte mir da bisher niemand eine antwort drauf geben ob bei dem 4 x 8 Pin Adapter zwingend auch alle 4 x 8 Pin Kabel belegt sein müssen
weil ich brauch ja nur 3 x 8 Pin für die 450 Watt und nich 4 x 8 Pin.
Währ cool wenn jeder Karte 2 Adapter beiliegen .. einmal 3 x 8 Pin ( für Leute dennen 450 Watt genügt ) und einmal 4 x 8 Pin ( für verrückte die auf 600 watt gehen wollen )
Am Netzteil stimmt das auch aber welche Kabel verwendet wurden und ob die Reserven haben würde ich mich nicht automatisch drauf verlassen. Bei AWG18 wäre ich persönlich vorsichtig aber ansonsten sollte es schon gehen.
Ohne den Adapter aus der Nähe gesehen zu haben kann Dir das auch kaum einer beantworten. Ich spekuliere mal ein wenig für Dich herum: Man muss mit 8 Adern auf 12 Pins kommen, es bleibt also nicht aus, das nicht jeder Pin am 12-pol Stecker die gleiche Anzahl an Kabeln bekommen kann. Ob also evtl. einige Pins gar keinen Strom bekommen wenn man eine Buchse frei läßt, hängt davon ab wie es verdrahtet ist. Ich denke man versucht es so gleichmäßig wie möglich zu machen, also sollte es eigentlich gehen. Wenn Du den Adapter in der Hand hälst müsstest Du auch selbst nachverfolgen können welche Buchse die meisten Pins erreicht und kannst dann die frei lassen die eine möglichst gleichmäßige Restverkabelung ergibt.
Aber ob das alles stimmt weiß ich nicht und es wäre nichts was ich selbst ausprobieren wollte. Wenn man Dinge nicht spezifikationsgemäß betreibt, dann wird die Faktenlage meist etwas dünner ;)
Daher auch sinnvoll das Kabel dafür vom Hersteller zu nehmen welches dafür auf dem Weg gebracht wird .Dann sollte das auch mit dem Querschnitt passen. Ich käme aber selber auch mit Adapter auch erstmal klar und habe mir damals auch 4 gesleevte einzelstränge von Corsair gekauft und könnte dann jedes Kabel über eine eigene Buchse anschließen und zum Adapter führen . Wird so auch gemacht , wenn erstmal kein Kabel lieferbar ist .
Ich denk auch das ich da erst ne antwort bekomme wenn die Reviews drausen sind da wird sicher einer bei sein der sich mit dem Adapter beschäftigt.
Cool währe es wie gesagt wenn da einfach 2 Adapter bei sind einmal 3 x 8 Pin und einmal 4 x 8 Pin aber das dann auch bei jeder Karte so hätte jeder das was er brauch.
Nunja ich hoffe ja das ich eine antwort auf meine Frage habe bevor ich die Karte in den Händen halte bzw den Adapter ... weil das währe dann richtig bitter wenn ich merke das
ich zwar nun die karte hab aber sie nich anschliessen kann weil man 4 x 8 Pin zzwingend brauch und 3 x 8 pin nich aussreichen.
Aber zur not muss dann halt mal nen neues Netzteil her .. aber erstmal abwarten was bei den Reviews dazu zu tage kommt.
Dann aber direkt nen ATX3 NT😄
Aber immerhin wäre ein neues Netzteil im Zweifelsfall schneller zu bekommen als die Grafikkarte selbst wahrscheinlich ;)
Das mag stimmen aber da die GPUs so ungünstig Preislich liegen würde ich gerne Folgekosten vermeiden zumal mein jetziges Netzteil ja mit ner 450 Watt GPU seit
2 Jahren klar kommt ... früher oder später muss aber so oder so mal ein neues Netzteil her mein jetziges 850 Watt Netzteil is auch nich mehr das jüngste.
Aber eile hab ich nun auch nich .. ich muss nun nich direkt zu release die 4090 haben ( sofern ich sie überhaupt kaufe .. da hab ich mich immernoch nich entschieden )
Ich lass mir da noch bis November oder Dezember oder sogar Januar mit zeit ( je nachdem wann ich bei meiner Firma den Urlaub nehmen kann )
Ähnliche Themen
