[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hier auch die Infoseite von BeQuiet dazu:
Der glaubt doch nur was er von seinem Support Ticket bekommen hat. Ich hatte ihm ja den Computerbase Artikel gezeigt.
Dann glaubst wohl meiner Support Anfrage.
PS. Aus deiner Anfrage geht hervor das du ein DP11 hast. Vielleicht kommt da ja nix für
ja ich habe das DP11.
Hm, wired.... mir wurde das so mitgeteilt.
ich habe nochmals nachgefragt, wenn es für das DP11 auch ein 12VHPWR gibt, wird das dann eben nochmal ersetzt.
Ich glaub dir e das vollkommen. Und ja es wird so sein das die sense brach liegt. Werd mir auf jeden Fall das Kabel kaufen.
Keine Panik.. das Kabel von Seasonic (für die "alten" bzw. derzeitigen NTs) verbindet jeweils 6 PINs der NT-seitigen 8-PIN Stecker auf den 12VHPWR und soll 600W erlauben. Da passiert also nichts anderes, als dass die Pins 1:1 vom NT zur Grafikkarte gehen und Sense ist da sicher nicht dabei.
KFA2 ist da recht eindeutig. Ganz unten bei requirement: https://www.kfa2.com/kfa2/graphics-card/40-series/4090-series/geforce-rtx-4090-sg.html
Der Adapter hat 4x8pin, du kannst aber auch 3x8 benutzen. Dann ist halt bei 450W Schluss.
Ja irgendwie so lese ich das nun auch aus deinem Link raus ... danke für die Aufklärung (y)
Bei der KFA is nur ein 4 x 8 Pin Adapter bei dabei :
Aber dennoch schreiben sie hier ja das man als Minimum 3 x 8 Pin brauch und das dann auch mit dem mitgelieferten 4 x 8 Pin Adapter geht.
und mir reichen die 450 Watt auch aus mehr will ich da eh nich verballern und damit bleib ich dann auch even mit meiner Aktuellen 3080 Strix die auch nen PT von 450 Watt hat
Also kann man auch dann mit dem 4 x 8 Pin Adapter nur 3 x 8 Pin anschliesen und 1 x 8 Pin offen lassen ( wichtig für Leute die eben nur ein Netzteil haben mit 3 x 8 Pin )
und die Karte läuft dennoch und hat dann ein PT von max 450 Watt
Schön dass sich bequiet endlich mal meldet, hört sich für mich so an als würde mit dem Adapter der den Karten beiligt erstmal alles passen. (vorausgesetzt die leistung stimmt)
Der Launch dieses. Jahr hat mal was erfrischendes, es geht nicht mehr 100% nur um den Preis sondern auch darum ob einem das Netzweil abfackelt. (y)
Ich bin sicher das man keine Probleme haben wird mit dem Netzteil, so lange man keinen China billig Schrott nutzt.
Vielleicht kurz nochmal zu dem Thema, was mit den 4 Pins beim neuen Stecker möglich ist:
Netzteil kann damit der Grafikkarte folgendes "kommunizieren":
Das mögliche Powerlimit beträgt xx Watt (aufgrund von 2 Pins -> 2²=4 unterschiedliche Spannungslevel)
Wobei in der Spezifikation noch unterschieden wird, ob gerade initial gestartet wird oder ob der Treiber schon geladen ist.
Aber bereits hier gibt es keinerlei Informationsaustausch, welcher Zustand gerade vorliegt.
Die Grafikkarte bzw. das versorgte Gerät kann dies mitteilen bzw. die folgenden "Fragen" mit Ja oder Nein beantworten:
Frage vom NT: Ist ein Gerät angeschlossen? Antwortmöglichkeiten: Ja/Nein
Frage vom NT: Ist Dein aktueller Verbrauch innerhalb des max. erlaubten Verbrauchs? Antwortmöglichkeiten: Ja/Nein.
Imho ist das nichts, was eine wirkliche Kommunikation darstellt.
Ein I²C-Bus könnte so etwas leisten. Schon seit längerem werden Bausteine auf Graka-PCBs darüber angesprochen/gesteuert.
Der Aquabus von Aquacomputer müsste auch ein I²C-Bus sein.
Falls das mit den 4 Pins doch unter Kommunikation fällt, dann hat das NT beim 8Pin-PCIe-Stecker auch schon mit der Grafikkarte "kommuniziert". :d
doch, hier zb:
Edit
@SH
da sieht man dann auch, das die Suprim X ebenso die 3 Gewindebohrungen am Ende hat.
Edit2
und hier:
Edit3
Interessanterweise gingen um 15:00Uhr Tests zu Intel Arc online:
Da fragt man sich, wer da gerade bei welchem Launch als Trittbrettfahrer unterwegs ist. :d
Sowohl der Asus GeForce RTX 4090 TUF OC als auch der Nvidia GeForce RTX 4090 FE liegen ein 16-Pin-auf-4×-8-Pin-Adapter. Das erlaubt es, aus vier für bis zu 150 Watt ausgelegten 8-Pin-PCIe-Anschlüssen an Netzteilen ohne neuen Stecker oder eigenen Adapter bis zu 600 Watt für den neuen 12VHPWR-Stecker zuzuführen
Und Igor sagt auch noch was zum 4 x 8 Pin Adapter das auch 3 x 8 Pin ausreichen :
Also 3 x 8 Pin läuft dann wunderbar damit und ich brauch kein neues Netzteil kaufen .. mir reichen ja die 450 Watt schon was eh schon recht viel is.
Also die MSI boostet auf 2625Mhz das lecker
Das macht für mich auch Sinn bei der FE, weil meines Wissens von nVidia gesagt wurde, daß auch die FE auif 600W übertaktet werden kann wenn genug Leistung über die Sense-Pins gemeldet wird. Und das setzt dann die 4x 8-Pin statt 3x 8-pin Adapter voraus, sonst wäre man ja ja gleich wieder außerhalb der Spezifikation.
Spekulation meinerseits:
Vielleicht scheren sich nur die Founders Edition-Karten etwas um die 4 zusätzlichen Pins (sprich, es wird entsprechend der beiden Sense-Pins das Powerlimit gesetzt) und bei den Customs ists den Karten egal und es wird freigegeben, was per Bios-Switch ausgewählt ist, ganz egal, welche der beiden Sense-Pins auf Ground gehen?
Gibt es auch schon Infos zur Frostbite wegen Powerlimit ?
bei allen anderen Karten müsste ich erstmal die Sondkarte rauswerfen weil sonst nicht genug Platz in der Höhe.
So wie ich das sehe, glaube ich jetzt irgendwie daran das die Karten nicht mehr mit TDP erhöt werden können, sondern das wird über den Kabel gesteuert. Igor hat an der MSI Suprem X nur 3 Pins angeschlossen und in dem Bios bild steht Max Power Target 450Watt ( was ja klar ist da nicht mehr über das Kabel geht ), aber Igor hat bei der FE 4 Pins angeschlossen und in dem Bios bild steht Max Power Target 600W
Und woher weiß die GPU wieviel Watt sie ziehen darf? Ich hab den neuen Stecker so verstanden: Neue 3.0PSU=Kommunikation zwischen GPU und PSU wieviel Watt geliefert werden kann. "Alte"-PSU=Die Sense Kabel werden so "verknotet", das die GPU "weiß" das Sie dauerhaft 600 ziehen darf. Daher wäre ich bei einem "nur" 12-Pin Kabel weiterhin skeptisch.
Wenn es nicht abgefragt wird - garnicht...
Aber die Ports an der GPU sollten pro Pin nur eine gewisse Leistung zulassen
@Brainscan1979
den Text, der hier und da zwischen den Screenshots zu finden ist, hast Du aber schon gelesen?
Diese Mutmaßung Deinerseits gibt Igor's Text nicht her. Das will ich sagen.
Der Switch stand auf der Stellung (vernünftige Variante), in der nicht mehr als 450W freigegeben werden und bei der die Lüfterkurve auf Leise getrimmt ist.
Da steht nirgends was davon, das es nicht mehr gewesen sind, weil nur ein 3fach-Adapter angesteckt gewesen ist.
ja , das hat aber überhaupt nichts mit meiner mutmaßung zu tun. Das was Igor hier zeigt ist eindeutig und verständlich. Ich mutmaße einfach nur 3Pin 450 Watt 4 Pin 600 Watt. Ob meine Mutmaßung richtig oder falsch ist wird sich am 12.10 Zeigen. Das man mit 3 Pins kein 600Watt ziehen kann ist mir auch klar.
Passiert heute um 16Uhr was?
was soll den noch passieren ?
Also Gamestar schreibt Test kommt asm 12.10 also werden ALLE anderen Seiten auch keine Test eher raushauen dürfen.
Und irgendwie muss es Trozdem, was zusammenhängendes sein. Da Igor schreib bei der FE es reicht aus das man nur 3 von 4 Pins anschließt. Und Ergo die Karte merkt das da sie ja Booten kann, sonst würde die Karte nicht Booten können wen man keine 4 Pins anschließt. Bei Customs also Bios Switch Silent Mode 450W und weniger RPM und VolleMöhre bios 600Watt. Ich kann mir auch vorstellen das wenn mann die Supreme auf VolleMöhre Bios stellt und sie mit 3 Pins nur anschließt das die Karte nicht Startet. Andersrum wenn die Karte es nicht Kontrollieren kann wie Igor schreibt, und ich die Karte nur mit 3 Pins anschließe knallt mir dann jedesmal das NT ab weil die Karte 600W will ? Fragen über Fragen :)
Wer den Größenvergleich mal sehen will.
Links Tuf 4090 Rechts Tuf 3090
Versteh nicht was ihr für ein Problem habt ? Mit dem 3 mal 8 kannst auch die 600 Watt ziehen , wenn deine NT es mit macht wenn du nicht genug hast auf der 12v Schiene Netzteil seitiges wird es abschalten . Ob 3 oder 4 juckt doch nicht der Querschnitt vom ja Kabel wird bei 3 schon reichen.
Ähnliche Themen
