[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Spielt ganz Oben mit. Aber ist vermutlich weniger von der Karte abhängig, mehr von der Chiplotterie.
Deine taktet out of the Box schon mal höher. Habs bei mir beim gleichen Szenario wie mit der Gainward gemacht. Statt 2775 eben 2730. Beim zocken merke ich ohne Afterburner keinen Unterschied. An der Lüfterkurve könnte man arbeiten aber insgesamt macht sie den Eindruck als sehr hochwertige Karte. Interessanterweise taktet sie zwar niedriger als die Gainward, wirft aber die selben FPS (evtl mal 2 FPS weniger gecapt auf 120 FPS) raus und verbrauchte in meinem Szenario (Assetto Corsa Competitione triple 7680x1440 mit 30 Gegner paar Runden im Monza) in der Spitze 20 Watt weniger lt. HWINFO 64.
Also ohne Messung merk ich keinen Unterschied. Zufrieden bin ich - Ende der Geschichte. Habe aber auch nur ein Szenario getestet.
MSI Karten bzw. Suprim X hatte bis jetzt mit die besten Chips schaut man sich die Bestenlisten an ist das die Karte mit der höchsten Chance auf nen guten Chip. Da der RAM aber mehr und mehr relevant ist, ist der Chip fast Nebensache und du kannst auch bei den günstigen Karten Glück haben.
Ich schaff mir meiner Suprim X 1800Mhz auf den RAM.
Welchen RAM meinst Du? Den VRAM? Der hat meiner Ansicht nach weniger Bedeutung als die GPU. Die 4090 hat größere Caches und ist darauf optimiert seltener auf dem VRAM zuzugreifen. Speicher, Interface...alles gleich wie bei der 3090ti. Das spricht nicht gerade für seine gesteigerte Bedeutung und ist auch mit ein Grund warum er sich so hoch takten läßt. Er hat einfach vergleichsweise wenig Last.
Alle meine Benchmarks und Spiele haben jedenfalls bedeutend stärker auf GPU OC angesprochen als MEM-OC.
Bei der OC Betrachtung CPU vs RAM liegt der RAM vorne aber nicht bei GPU vs. VRAM. Jedenfalls sagen das meine Messungen und Erfahrung.
War früher anders, ist jetzt offensichtlich so, dass es wenn dann nur noch "Sondermodelle" gibt, wo der Hersteller halt selbst ein binning macht.
Wobei ich nicht glaube, daß sich das noch lohnt wenn man dem glaubt was EVGA berichtet hat und auch was andere Quellen so über nVidias Preispolitik gegenüber den AiBs sagen. Das war früher auch anders.
Okay ich bin glaub soweit. Alles eingebaut. Loop ist dicht und System neu aufgestzt. Kann der Abend starten :)
So Gaming OC ist drin. Super leise kaum Rasseln und kein Fiepen. Die Lüfter sind mega im Vergleich zu meiner Gainward. Die Gainward hatte @stock immer 2775mhz angelegt und diese jetzt 2730mhz und bleibt ca 5 Grad kühler @stock schneidet sie etwas schlechter in Timespy ab - ca 600 Punkte, aber damit kann ich super leben (den Chip umlöten werde ich nicht 😂). Das Bracket Gedöns musste ich oben etwas abflexen damit die Halterung auf das Asus Strix Z690 A passt. Somit bin ich jetzt im Grakahimmel und könnte zufriedener nicht sein. Schönes Wochenende und viel Spaß und Glück mit Euren Karten. Wer sich noch überlegt eine zu kaufen - da kann man nichts falsch machen. Jetzt könnten sie den just buy it Slogan wieder raushauen.
Der Adapter ist grausam, da muss ich was machen. Auf dem Gigabyte Zeichen rechts war mal kein Aufkleber, beim Rest schon und der Mediamarkt Karton war offen, schon wieder nen leichten Herzinfarkt beim öffnen bekommen. Die Karte an sich ist versiegelt.
Auch bei high FPS und Load? Zum Beispiel Valorant mal ausprobieren ohne FPS Limit im Menü
Wie verhält sich den die KFA2 so vom Kühler bezüglich Lautstärke und Temperatur im Vergleich zur Asus Tuf und Gigabyte Gaming OC ?
Ich würde sagen irgendwo dazwischen. Gefühlt etwas besser als von der Gaming OC bzw. eine bessere Lüfterkurve. Von der charakteristik/laufruhe der Lüfter nehmen sie sich nicht viel.
verpasst habe ich die TUF nicht, da ich noch kein direktes Kaufinteresse habe. Absehbar wird es aber die Karte werden. Günstig, dazu kompatibel mit Wasserkühlern. Ich hatte nur bisher keine Verfügbarkeit der normalen TUF gesehen.
ich hoffe, in ein paar Monaten wird es die Karte mal normal geben
So, dass man nicht seine F5 Taste opfern muss, weil man den ganzen Tag vor dem Rechner sitzt und nur drauf hämmert.
Nachdem die FE mir am Releasetag wegstorniert wurde, hab ich während dem Training Abends bei Asus die TUF non-OC gekauft, nachdem mir jemand über Discord Bescheid gegeben hatte xD, die war ja immer wieder kaufbar an dem Tag... danach wurds leider weniger
Finde es auch nicht schön 2250€ für die TUF OC im Asus Shop bezahlt zu haben , wenn da praktisch die selbe Karte für 1950€ gab , aber die andere verlangen teilweise deutlich mehr und daher tut es momentan nicht weh . Immerhin zu Release eine Wunschkarte bekommen . Andere zahlen mehr und bekommen Karten mit kaputten Lüfter :d
Die Asus Karten sind eigentlich gut gelungen.
Ich lasse die Hype-Welle durchziehen. die 4080 kommt ja auch noch und dann wird die Verfügbarkeit bestimmt bei den 4090 besser.
bei mir wird das alles erst relevant, wenn die Wasserkühler von Watercool oder Aquacomputer verfügbar werden und ich von WQHD auf UHD umsteige. Grad lohnt sich die 4090 bei mir null. Ich hänge nur in Apex Legends rum und hab dort meine 160 Frames (3080/10G)
Kann gut sein … was Real halt hinten raus kommt ist das was zählt. Auch wenn man den Regler auf 1800 dreht kann es sein das auf Grund von Fehlern der reale Takt niedriger ist.
Den Schreck habe ich auch bekommen. Erst war der Karton offen und dann auch noch das Plastik mit dem Adapter-Stromkabel. Die Karte selber war aber versiegelt und auf dem Lüfter und der Rückseite waren auch Schutzfolien. :bigok: Aber im ersten Moment denkt man wirklich ... scheiße ein Rückläufer...
Der VRAM war gemeint … manches skaliert gut mit hohem VRAM und maches mit hohem GPU Takt kann man leider nicht so pauschal sagen.
Ähnliche Themen
