[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe ich mir auch angesehen... die MSI Suprim soll nur 12,3cm hoch sein... Techpowerup gibt aber 14,2cm an und MSI gibt auch 14,2cm an... irgendwas läuft da schief bei PCGH... :d Haben die nur den Kühler vermessen, aber nicht den PCI-E Slot?
Wäre also eine der kleisnten Karten...wäre die nicht eine der dicksten -.-... mit 78mm passt die nicht mehr rein. Und nicht zu vergessen ein Kreischer :d
Mein Geld von der Gigabyte Master ist gerade im Rücklauf von der Retour jetzt bin ich halt wieder am schauen .
Hab ja richtig Lust auf die Strixx mal schauen ob ich da kommende Woche vielleicht Glück habe ansonsten spricht mich keine Karte so richtig an.
Am aller liebsten wäre mir eine Wassergekühlte Karte mit 600 Powerlimit aber dahin gehend tut sich ja gar nix!
Ich hab bis her meine Karten zwar immer selber auf Wasser umgebaut aber bei so einer 2000 Euro Karte fühle ich mich mich einfach nicht Wohl wenn doch was damit sein sollte.
Hab ja auch mitgelesen das MSI und ASUS an sich da wohl kein Problem damit haben wen umgebaut wird und später original Zustand hergestellt wird.
Gar nicht mit bekommen, warum hast du die Karte nicht behalten?
Weil mir die Lüftersteuerung und das Fiepen auf den Kecks gingen und hin zu kommt noch das die Material Anmutung für 2400 Euro absolut nicht das war was ich mir vorgestellt habe.
Der Kühler ist echt Potent aber die Lüftersteuerung hat man nicht gut umgesetzt..
Von 0 RPM legt die Karte bei 66 C plötzlich mit knapp 1500 RPM los was ich klar gehört habe dann nach 2 min bei unter 60C wieder aus und 2 Minuten Später wieder mit 1500 Attacke und das obwohl mein 1000D fast 2,70m weg steht.
Im OC Bios drehte sie bis hin zu 1750-1950 RPM
Ich hab es auch mit festgelegter Drehzahl bei ca 900RPM versucht mit dem AB an sich ganz gut aber jedoch manchmal nach Win Start Start Total Ausfall bei der Lüftersteuerung 0 RPM noch bei 75C also auch keine Option und weg damit !
Ich spiele viel über Lautsprecher und das geht für mich halt gar nicht klar!
Meine Gamerock OC hat heute die Biege gemacht. Rechner gestartet, kein Bild. Rote Mainboard LED GPU. Ich so, okay, hast komplett umgeräumt und Rechner bisschen bewegt. Also alle Kabel überprüft und neu eingesteckt. Nix!
3080 rein und zack Bild. Hmmh, shit. Also mal zurück schicken und schauen wie lang der Spaß dauert. Die non OC läuft beim Bekannten, hätte ich mal behalten sollen :)
Naja, es gibt wichtigeres. Mal schauen ob ich ne Neue oder Geld bekomme. Dann sehen wir weiter. So lange darf die EVGA noch bisschen schaffen.
Beste Grüße
Beste Grüße
Jo das Perfekte Worst Case für Wakü Umbau.
Beste Grüße
Uh, das ist bitter. Aber Montagsgeräte gibt es ja leider immer und überall. Hattest du irgendwelche OC Settings?
Falsche Karte. :d Das ist die MSI Gaming Trio und nicht die Suprim, da ist 1mm Unterschied :d . Und "passen" ist eine andere Sache, die Karte wird von den Clips der Bodenplatte hochgedrückt. :d Da ist der eine Millimeter entscheidend.... Aber danke für den Link, das hilft mir bei der Planung.
Kein OC, sogar UV mit Standard Boost. Soll hier eigentlich arbeiten und Bilder Rendern. Da ist oc nicht interessant.
Bin da auch entspannt, komme aus dem produzierenden Gewerbe, es kann immer mal was kaputt gehen. Wie damit umgegangen wird zeigt dann ob eine Firma gut ist oder nicht.
Beste Grüße
Mal ein bissl Feedback.
Höchste Temperatur die ich erlebt habe bisher 54 Grad. Delta von Zimmertemperatur zu Wasser sind 9 bis 11 Grad. Von Wasser zur Karte sind 9 bis 10 Grad. Ich habe auch probiert mit PT zu arbeiten, habe aber mit UV bessere Ergebnisse erreicht. Aktuell läuft 0,9v mit 2670 Mhz stabil. Das ist besser als 70% PT und sparsamer als 80% PT. Maximal hat die Karte bisher 320 Watt gezogen, oftmals ist die aber unter 300 Watt.
Bisher soweit zufrieden.
kennt sich hier jemand mit guten cpu aio aus?
was würdet ihr mir für gute cpu aio empfehlen? stehe zwischen dem fractal design celsius+ 36 argb, alpenföhn glescherwasser sowie artic freezer ii 360 argb und corsair h150i elite capellix
würdet ihr mir eher den gigabyte m32u empfehlen oder den asus rog pg32uq? der asus hat ja hdr 600 sowie quantum dot...
Hast Du einen Verdacht, weshalb die Karte plötzlich defekt ist?
Ehrlich gesagt keine Ahnung. Hab Freitag noch ein paar Bilder gerendert. Keine Probleme gemacht. Hat ordentlich Geld gemacht. Dann heute morgen umgeräumt. Neuer Tisch usw. aufgebaut und dann ging nix mehr. Wie gesagt, kann einfach mal vor kommen. 4090 kommt auf jeden Fall wieder rein. Entweder Austausch oder neu.
Beste Grüße
Kann man nur hoffen dass die rma vzw der Prozess schnell geht.
Hallo Zusammen, hätte evtl. noch wer ein Cookie für Alternate und eine Gainward Phantom wie auf den letzten Seiten Mal erwähnt? Wäre super da meine Vorbestellung vom Händler storniert wurde...
Ich mach mir da keine Gedanken. Hab nen guten Draht zu Alternate was das angeht. Dauert eigentlich nie länger wie 7 Tage bis ich eine Lösung präsentiert bekomme. Bin da ein entspannter Kunde so lange ich informiert werde.
Beste Grüße
OK...ich habe mal nachgeforscht...
Auf Reddit hat jemand ne Liste gemacht:
Es scheint so, als würde der PCI-E Stecker NUR passen, wenn er tiefer liegt, wie es bei einigen GPUs ist. Die FE fällt hier durch, weil der Adapter warscheinlich zu dick ist...das ding von Cablemod sollte es aber regeln...
Oder man besorgt sich sowas :d
Man stelle sich jetzt vor man hätte die Karte bei eBay gekauft und der Händler wo sie gekauft wurde sagt lediglich Gewährleistung beim Erstkäufer zu .
Was für ein Radiator ?
Und wieviel Watt reingeblassen ?
Welche Paste oder Liquid Metal ?
Ich habe 3x360 intern verbaut. Meine Lüfter laufen auf kontanten unhörbaren 500 rpm.
Jo, dann wäre das Ganze etwas komplizierter, aber selbst da gibt es Mittel und Wege. Als early Adopter rechnet man eh schon mit sowas, daher alles entspannt. Die 3080 darf dann aus ihrer Rente heraus doch noch mal ran, altes Eisen hält doch am längsten. :d
Beste Grüße
Hoffentlich wird es schnell abgewickelt. Da drücke ich die Daumen.
Bei der Gigabyte Gaming OC drehen die Lüfter unterschiedlich von Haus aus oder...der eine mit 67% und der andere mit 70%. Dachte das wäre immer gleich im Afterburner @stock (es sei denn man hat ne eigene Lüfterkurve).
gut er braucht die karte beruflich somit sind die aufpreise der händler weniger das problem denke ich
Ähnliche Themen
