[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hier wurde immer wieder von seltsamen Geräuschen einer der Lüfter berichtet, vor allem aber ab 50%+. In einigen Reviews ja auch.
Hab das jetzt mal angetestet mit MSI Afterburner, verschiedene %-Bereiche. Kann aber keine "seltsamen" Geräusche feststellen. Habe auch gelesen, es soll Rattern/Knatter/Schleifen oder sowas, aber merke davon nichts.
An der FE kann ich eigentlich nichts aussetzten, kein Spulenfappen bis jetzt (seit Einbau ist bei mir jeder frame limiter aus), keine Lüftergeräusche. Sie macht, was machen soll im erwartbaren Bereich.
Könnten die 4090 Besitzer mal in Ihren "eventvwr.msc" ausführen und schauen ob ihr auch solche Meldungen habt vom Typ 4101 und 0? Wäre interessant zu wissen.
Ja, ballert hier auch raus, weiß aber ned ob das mit dem OC zusammenhängt. Hatte mehrere black screens im Desktopbetrieb, vermutlich wegen VRAM-oc, bin dabei das noch herauszufinden.
auf wieviel Mhz boosten die FEs der FE Besitzer im Speedway hier im Thread? Meine taktet zwischen 2700-2715 hin und her. Kommt aber nach oben raus nicht mehr viel und bruscht auch für 2700 mindestens 950mV
Meistens 2745 ohne oc bzw 2880 mit oc.
Sehr interessant, dann war es bei den ersten Karten wohl doch ein Defekt und wurde nun behoben!?
4101 keinmal und 0 einmal, allerdings mit Dwminit als Quelle.
Hier nichts mit der Gaming OC bei O steht bei mir nur Edge Update Fehler und der andere nicht vorhanden. Dafür geht das Gigabyte Controller Center nicht (wollte nur das RGB ruhig stellen) und das Display Port Problem das den Monitor auf 85 Hz stellt passiert nur mit Sniper 5 und 200% Skalierung. Bei allen anderen nicht, allerdings mit der Gainward auch nicht. Irgendwo bios mäßig hakt da was sei es Windows oder was an der Karte...oder im Nvidiatreiber...
Hat irgendwer bei MM eben Glück gehabt mit der Kfa? Ich war mal 20min nicht online und dann dropped da eine...
Die war so fix weg das es vermutlich nur ein Rückläufer/Storno oder so war.
Hatte den gleichen Fehler mit meiner Suprim :)
RGB-Beleuchtung-Einstellung funktionierte nicht, stellenweise fuhr Windows nicht ordentlich runter oder ich hatte Start-Schwierigkeiten.
Hier die Lösung, ins Bios gehen und den TPM Chip aktiveren.
Am besten in Verbindung mit einem neuem Bios Update, würde es aber erst mal so versuchen (sofern das neuste, Windows 11 kompatible TPM-Setting vorhanden ist) Ansonsten wie erwähnt Bios Update
Gigabyte 4090 gaming OC
Die Grafikkarte ist selbst im Desktop Betrieb auf einmal komisch am laufen. Sie blinkt die ganze Zeit und wenn die Lüfter angehen sind es nur die ersten beiden oder hinten der dritte. Dabei macht sie auch komische Geräusche. Als ob es so Schaltgeräusche sind kurz bevor die Lüfter angehen und ganz kurz noch am Anfang beim andrehen. Unter last ingame gehen auch alle Lüfter an und Sie verhält sich normal. Trat erst grade eben nach einem Spiel auf. Metro Exodus wurde gespielt. Karte hat sich da gelangweilt keine Ahnung was auf einmal los ist.
Der Link zeigt es
Danke euch
Eine Frage: Welches GPU Tool wird bei Euch bevorzugt? Afterburner, Precision X1, ...
Du hattest doch eine 3090 FTW3. Imho solltest Du daher wissen, wie sich Spulengeräusche anhören.
Falls Dir da nichts aufgefallen ist, bist Du vermutlich immun. :d
Tuf non oc von MM für 2400 weg, wahnsinn was die Leute bereit sind zu zahlen... da werden die Preise nur weiter klettern
Ich frag mich dabei immer, ob sich Scalper nicht gegenseitig den Kram verkaufen und so die Preise immer weiter hochschaukeln.
2500 EUR ist das komplette Monatsgehalt (netto) von 75% der Bevölkerung. Lebenshaltungskosten gibt es ja auch noch.
Wieviel Spitzenverdiener (Leistungsträger, nicht Ex-"Cryptobros") sich wohl für Highscores in einem 3D Benchmark interessieren, nur um Internetpunkte zu sammeln. Gestört.
Was ist die Alternative, keine Grafikkarte kaufen?
Die Preise werden ohne hin weiter steigen, weil die Nachfrage deutlich höher als das Angebot ist und die Karten ständig ausverkauft sind.
Habe am Wochenende nun meinen Rechner aus dem Nebenraum (Abstellraum) in meinen Hobbyraum umgezogen. Wirds wenigstens Warm beim Zocken. :d Die Lüfter auf Standard gestellt. Bei Hohen 3 Stelligen FPS fiept die 4090 Founders Edition. Ist für mich aber nicht störend. Bin da nicht extrem empfindlich. Sobald Ton läuft, nihct störend. Max Temperatur der FE waren 69-70 Grad bei A Plague´s Tale. Trotzdem kommen die Lüfter der FE nie über 50%. Habe +200 auf Core sonst nix und max ~450 WATT auf der Grafikkarte. Gesamt-System mit nem i7 8700K OC (max 72 Grad) auf LUFT bei ~620 WATT.
Wenn ich die Gehäuselüfter auf MAX einstelle, ~59-65 Grad bei der FE, aber dann ist zocken ohne Kopfhörer nicht erträglich. .. Das ist dann wieder was, wenn der Rechner im Abstellraum steht und die Kabel durch die Wand geführt sind.. für den Sommer. In der aktuellen Situation ist das Heizen mit dem Rechner beim Zocken besser. :d
Also das Geld für die 4090 habe ich nicht in einem Monat zusammen gespart...
Aber ich glaube auch langsam, da das Scalper mit Preise von 3000€ rechnen und alles unter 2500€ aufkaufen...wenn sie es nicht innerhalb von 10 Tagen verkaufen, gehts zurück...
Ich persönlich Afterburner. Mit der aktuellsten Beta kann man auch die Spannung anheben auf 1,1 V .
Nutze es allerdings auch für Overlay Ingame. Beste kombi tool für mich persönlich.
was für Taktraten hast du im Speedway?
auch die non-OC für 2249,00, schon über mehrere Tage verfügbar....wer mehr zahlt ist selber schuld
@BJGucky wer kauft sich eine 4090 für 2300€ beim Scalper wenn er jeden Tag ohne Probleme eine auf eigenen Namen für den Preis haben kann. Scalping gibt es nicht mehr bei GPU. Das einzige was man noch kurz scalpen kann ist die FE und da gibt es auch nur wenige die für eine FE 200 - 300 € mehr bezahlen.
Wer noch etwas warten kann, der reserviert eine Karte hier
finde das Angebot echt gut, wenn ich nicht schon ne Karte hätte, wäre es ne Option.
Vor allem da es diesmal echte Silicon Lottery ist und das Boad Design jetzt auch nicht unbedingt ne Rolle spielt
Ähnliche Themen
