[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wer noch etwas warten kann, der reserviert eine Karte hier
finde das Angebot echt gut, wenn ich nicht schon ne Karte hätte, wäre es ne Option.
Vor allem da es diesmal echte Silicon Lottery ist und das Boad Design jetzt auch nicht unbedingt ne Rolle spielt
Aber da Gainward = Palit nehme ich an das PCB Design ist dass gleiche wie auf der Gamerock
Und Buildzoid hat da eine klare Meinung zu..
Ich benutze das Gainwardtool für die GPU Settings. Experttool2. Funktioniert gut und man kann auch das RGB etc. steuern, was ich ganz gerne mache. Lohnt sich natürlich nur für die Gainward GPUs würde ich sagen, sonst kann man auch einfach Afterburner nehmen.
Also ich hätte nie erwartet, dass die 4090 so schlecht verfügbar ist. Klar, bessere Verfügbarkeit als bei der 3000er Serie, aber dennoch einfach viel zu geringe Mengen. Und dies beim teuren Topmodell.
Will gar nicht wissen wie es bald bei der "günstigeren" 4080 sein wird, die ganz sicher viel mehr Leute kaufen möchten als die 4090.
Ich konnte mir zum Glück im Asus Eshop die Asus TUF 4090 für 1949€ kaufen.
Top Karte und mein 5900X CPU ist jetzt im MSFS der Bottleneck :d Die Karte wird selbst in Cyberpunk (1440p, alles Ultra, RT psycho) nie wärmer als 54-57°C im Corsair 4000D Gehäuse
Ich kenne das Video, er hat selbst keine 4090 und reitet eben auf dem Phasendesign rum.
Ich will ihm seine Skills auch nicht absprechen, aber realistisch betrachtet ist genügend Leistung für den Grafikchip vorhanden.
Das kannst du einfach ausrechnen:
16x50x1,10 max Voltage, also 880 Watt Leistung, was zur Verfügung gestellt werden könnte.
Das reicht locker. So viel dazu, wie huch wie konnte das Nvidia überhaupt freigeben :rolleyes2:
Das Einzige, was bei den Gamerocks nicht so gut ist, der brummende Lüfter dafür aber kaum CoilWhine, was man jetzt so hört.
Für die Phantom habe ich kein Bild vom Board im Netz gesehen, man weiß es also nicht wie das Board aussieht --> nur weil der Preis etwas günstiger ist, muss die Karte deswegen nicht mit den günstigsten Komponenten zusammengeschustert sein..
Und selbst die ach so tolle Strix hat ihre Schwächen, schaut man sich mal deren Elkos genau an,
und beschäftigt sich damit, bekommt man raus das diese recht günstig sind und nur 1-2 Jahre Dauerbetrieb auf dem Papier durchalten.
Colorful hat z.b gar keine klassischen Elkos mehr verbaut, Nvidia auf den FEs haben die teuersten genommen welche Serverstandard sind.. usw. etc..
Im Endeffekt sollte jede Karte ein paar Jahre halten, würde da kein so großes Fass aufmachen..
Naja schlecht verfügbar ist was anderes aber gut verfügbar auch. Die 4090 hält sich irgendwo dazwischen aber wenn man ne bestimmte Karte will, wird es halt schwierig.
Was sagt ihr zu dem Gerücht über den Produktionsstopp für die 4090 aufgrund der Priorisierung von Hopper?
Das Gerücht ( mehr ist es bisher noch nicht ) sagte nicht aus das es da gleich ein Produktionsstop gibt sondern nur das weniger 4090 Produziert werden sollen ( aber dennoch weiterhin noch welche )
aber von einem Produktionsstop war keine rede
Lese dir gern dazu mal die 3Dcenter News dazu durch :
Sehe ich auch so, kein Vergleich zum 30er Start.
Es gab genügend Chancen und die jetzt meckern, sind jene, die mit dem Kauf zögerten :fresse:
Oder bei MSI gelandet sind und jetzt einen Schreier im PC stecken haben ^^.
Wundere mich nur bei altenate, dass ich explizit ein RMA-Antrag (Defekt->Tausch) ausgewählt habe.
In meinen Begeleitunterlagen steht jetzt was mit Widerruf drin oO.
Buildzoid ist ein extrem Übertakter. Natürlich hat er ein etwas anderen Blick darauf als ein normalsterblicher Anwender. Wenn du aber ein normales Anwendungszenario hast, bist du mit der Karte selbst im Bereich bis 500Watt und etwas drüber vollkommen im grünen Bereich.
Vielen Leuten genügt auch günstiger Aldi Wein, ein feiner Sommeliere würden den aber sicher niemandem empfehlen.
Man spürt dass das Marketing der Hersteller bei den Casuals funktioniert. Kauft besser teure Karten mit 1 Millionen Spulen drauf, obwohl ihr überhaupt garkein Nutzen daraus tragt. Großartig.
Und mein bödes Displayport Problem samt der Monitorumstellung auf 85% passiert nur reproduzierbar bei Sniper 5 mit 200% und allen anderen Skalierungen incl 100% nach paar Minuten und nur mit der Gigabyte Gaming OC Alle anderen Games passen ohne Probleme sowie meine tripple screen racing games. Da ich ja da 3 Displayport gleichzeitig brauche und alles in Ordnung ist, kann es ja nur ein spezifischer Win/Graka/Game/Treiber Bug sein...
Dann wirst du wohl jetzt dein Geld wieder bekommen 😱
Lg
Nachricht gelöscht
Gigabyte 4090 gaming OC
Die Grafikkarte ist selbst im Desktop Betrieb auf einmal komisch am laufen. Sie blinkt die ganze Zeit und wenn die Lüfter angehen sind es nur die ersten beiden oder hinten der dritte. Dabei macht sie auch komische Geräusche. Als ob es so Schaltgeräusche sind kurz bevor die Lüfter angehen und ganz kurz noch am Anfang beim andrehen. Unter last ingame gehen auch alle Lüfter an und Sie verhält sich normal. Trat erst grade eben nach einem Spiel auf. Metro Exodus wurde gespielt. Karte hat sich da gelangweilt keine Ahnung was auf einmal los ist.
Der Link zeigt es
Danke euch
OK Karte ist eindeutig DEFEKT. Gigabyte hats klar gesagt und Alternate hat bestätigt das sau VIELE 4090 diese Schaden haben. Also die Serie ist für den ARSCH und das betrifft durch die BANK alle Hersteller.
Das nenne ich mal ein sehr schönes Layout.👌🏽
Lg
Joa, blöd wenns dann an Lüftern scheitert deswegen wäre mir ne Noctua edition direkt am liebsten. Noctua hat ja auf Twitter schon bestätigt das se für 40-Serie Editions haben aber ich bezweifle ne 4090.
Bin bei MSI (4090 Suprim X) gelandet und sehr zufrieden.
Mein Gehör ist nicht mehr das Beste, da bereits der 55+ Generation angehörig und von daher habe ich auch keine Geräuschprobleme. :d
Die Karte ist hochwertig verarbeitet und wesentlich effizienter als die 3080Ti Suprim, welche vorher in dem System ihren Dienst verichtete.
Macht einfach Spaß jetzt ohne große Leistungseinbußen auf einem 4K OLED / 120Hz FH5 oder F1 2022 zu daddeln. :)
Wenn jemand Alternate Cookies für eine der beiden Karten will bitte einfach melden :wink:
Grade ( 14:02 uhr ) gab es für etwa 2 sekunden 15 ( angeblich ) Asus Strix Karten bei Proshop .. alle nach 2 sekunden weg .. denke mal das is ne Verarsche beim Proshop
die haben auch immernoch 2 TUF auf Lager die man aber nich bestellen kann obwohl ja ab 14 uhr dort der verkauf starten soll
Abnormal wie schnell die immer weg sind. Von wegen zu teuer und so... Kann man dann sicher davon ausgehen das die nächste Generation noch teurer wird.
Grade gab es für etwa 2 sekunden 15 ( angeblich ) Asus Strix Karten bei Proshop .. alle nach 2 sekunden weg .. denke mal das is ne Verarsche beim Proshop
die haben auch immernoch 2 TUF auf Lager die man aber nich bestellen kann.
also ich hätte mir als Alternative eine Gaming OC überlegt. Der Button wurde grün, ich klicke auf bestellen und bekomme die Meldung alles wech. Krass.
Hab ich auch gerade zugeschaut
Gut zu wissen ...
Ich hole mir jetzt eine Schreckschußknarre mit zwei Patronen und halte die mir links und rechts neben das Ohr :ROFLMAO:.
Habe auch versucht eine zu bekommen und gleich auf Warenkorb geklickt, da perma F5 und es ging nicht, daher denke ich auch, dass es im System angezeigt wurde aber keine Karten verfügbar waren. Da pro Bestellung nur 1 Karte ausgegeben werden kann, kann es auch nicht wirklich ein Bot sein.
Gut ist nur, dass sie bei Alternate die Rückläufer nun als "B" Ware anbieten und nicht anderweitig vertreiben, das finde ich gut!
Quelle?
Lg
Viel zu viel beleuchtet. Das muß doch beim spielen/Arbeiten ablenken.
ja .. so schnell kann man garnich bestellen so schnell war die Strix bzw die 15 Strix die ProShop ja angeblich gehabt hatte weg ... Proshop verarscht hier nur die Kunden
sieht man ja auch bei der TUF wo immernoch 2 auf Lager sind ( schon seit letzter Woche .. wo man Freitag ja auch schon nicht bestellen konnte ) und die TUF kann man nun auch nicht
bestellen obwohl es nach 14 uhr ist ... ProShop verarscht hier nur die Kunden
Ähnliche Themen
